What did you do for your Bus today?
Page: Previous  1, 2, 3 ... 688, 689, 690, 691  Next
VWAdam
VWAdam is offline
PostPosted: Tue Jun 24, 2025 5:23 pm    Post subject: Re: What did you do for your Bus today? Reply with quote
Do you have a make a custom length throttle cable?
All he needed was a wheel in his hand and four on the road.
'59 Euro Beetle ragtop
'63 Standard Microbus
Come to my show! www.volksjam.com
Looking for badge/sticker/frame from Western Motors in Great Falls, Montana
thom
thom is offline
PostPosted: Wed Jul 02, 2025 9:25 am    Post subject: Re: What did you do for your Bus today? Reply with quote
More polishing and assembly
-Thom
1956 Single Cab
1957 Porsche 356A Sunroof
1957 23-Window Deluxe
1963 Unimog 404
1965 E-Type
thom
thom is offline
PostPosted: Wed Jul 02, 2025 9:54 am    Post subject: Re: What did you do for your Bus today? Reply with quote
No - it works with the stock cable
-Thom
1956 Single Cab
1963 Unimog 404
1965 E-Type
70bus Premium Member
70bus is offline
PostPosted: Wed Jul 02, 2025 10:12 am    Post subject: Re: What did you do for your Bus today? Reply with quote
Usually. On my 65 truck, I needed a different year cable; I ended up with a shorter one being the best fit. Possible the J bracket was not in correct place after all the truck had been through, though.
Also, make sure that nut holding the pedal to linkage is tight! A shop took mine apart to remove the mat, failed to tighten it, and it fell off and dropped pedal to floor while driving. Luckily I had a splash pan to catch nut and fix things.
Irony is shop laughed and said that wouldn't have happened if you'd stayed stock!
Despite that, I highly recommend installing these.
Craig K
70 Neunsitzer
65 Pritschenwagen
Raul the 65 singlecab
Karl the 70 nine-seater
thom
thom is offline
PostPosted: Wed Jul 02, 2025 10:25 am    Post subject: Re: What did you do for your Bus today? Reply with quote
Usually.
How about "it works with whatever cable you're currently using" - the geometry is identical, so the cable length would be identical
-Thom
1956 Single Cab
1963 Unimog 404
1965 E-Type
70bus is offline
PostPosted: Wed Jul 02, 2025 11:18 am    Post subject: Re: What did you do for your Bus today? Reply with quote
Truck had no cable when I got it! :) Stock cable I ordered was too long, for whatever reason. Just a note that starting from scratch may introduce variables. Baywindow had no issues when I put in linkage with same cable used on stock.
Craig K
70 Neunsitzer
65 Pritschenwagen
70bus is offline
PostPosted: Fri Jul 04, 2025 6:41 pm    Post subject: Re: What did you do for your Bus today? Reply with quote
Thanks to Corey at Der Deutsch Polster and Dominic Puccinelli, I added the correct tools AND the correct cloth bags under my seats. I met Dominic at Woodburn, and he dug through his stash to find an original tool roll in mesh grey: DDP supplied the new jack bag. This week I swapped my round-head Bilstein jack to Always VDub for the appropriate 'doghouse with no tooth' jack.
Hopefully I never need any of these!
Craig K
70 Neunsitzer
65 Pritschenwagen
thom
thom is offline
PostPosted: Sat Jul 05, 2025 2:54 pm    Post subject: Re: What did you do for your Bus today? Reply with quote
Got the door windows assembled - and broke one of the vent wing windows
-Thom
1956 Single Cab
1963 Unimog 404
1965 E-Type
Stocknazi
Stocknazi is offline
PostPosted: Sun Jul 06, 2025 5:59 am    Post subject: Re: What did you do for your Bus today? Reply with quote
"doghouse with no tooth jack"???
WANTED:
Thomas Jefferson
70bus is offline
PostPosted: Sun Jul 06, 2025 9:23 am    Post subject: Re: What did you do for your Bus today? Reply with quote
Early bay 'doghouse' jacks have a triangular stop on the arm that keeps it from going over horizontal.
Craig K
70 Neunsitzer
65 Pritschenwagen
BarryL Premium Member
BarryL is offline
PostPosted: Sun Jul 06, 2025 6:30 pm    Post subject: Re: What did you do for your Bus today? Reply with quote
'67 jack has that too as well as the rubber bumper.
thom
thom is offline
PostPosted: Tue Jul 15, 2025 10:11 am    Post subject: Re: What did you do for your Bus today? Reply with quote
Sent it out to get the headliner installed
-Thom
1956 Single Cab
1963 Unimog 404
1965 E-Type
jmmj
jmmj is offline
PostPosted: Tue Jul 15, 2025 11:41 am    Post subject: Re: What did you do for your Bus today? Reply with quote
Went to adjust the valves on my mystery bus engine, and i was treated to a surprise!
Golden glitter!!
New project!! Brazilian Split!!
63 Panel Van Project (Sold)
71 Bay window Devon Camper (Sold)
79 Brazilian Bug / Fusca
LAGrunthaner Premium Member
LAGrunthaner is offline
PostPosted: Sat Jul 19, 2025 6:42 am    Post subject: Re: What did you do for your Bus today? Reply with quote
Once again, what did my bus do for me today?
Yep I borrowed my 67 Westy Interstate battery for my daily driver Very Happy
When I started to shop around for a replacement at the local NAPA store I was asked why I have such a high cold cranking amps for both my bus and my truck and I could not recall why I went with an 800. Is that a good choice of 800 CCA for my 1600 DP engine? BTW I love Interstate batteries but pricey.
Maui Roadsters VW Logo
www.mauiroadsters.com
http://www.oacdp.org
Lind wrote:
ricekooker
ricekooker is offline
PostPosted: Mon Jul 21, 2025 4:22 pm    Post subject: Re: What did you do for your Bus today? Reply with quote
I made my apron less red. I thought light grey was hiding under the red but it was just another coat of paint. Turkis is hiding under that…
Buskraut Premium Member
Buskraut is offline
PostPosted: Mon Jul 21, 2025 6:20 pm    Post subject: Re: What did you do for your Bus today? Reply with quote
Finished up my interior today… ready for Monterey car week!
Erik S
'65 Type 251 / Deluxe
'03 Eurovan MVWK
Da TOW'D
Da TOW'D is offline
PostPosted: Mon Jul 21, 2025 8:10 pm    Post subject: Re: What did you do for your Bus today? Reply with quote
Beautiful ^^^^
'57 type 1 Blackberry
'58 SC Ruf
'62 type 3 Notch
'92 Eurovan Willy
'99 Eurovan Winnie
and NUTS
BarryL is offline
PostPosted: Tue Jul 22, 2025 6:09 pm    Post subject: Re: What did you do for your Bus today? Reply with quote
That thing is absolutely Cherry.
BarryL is offline
PostPosted: Wed Jul 23, 2025 6:40 pm    Post subject: Re: What did you do for your Bus today? Reply with quote
Reinstall Westy Hitch for my new boat trailer.
thom
thom is offline
PostPosted: Thu Jul 24, 2025 1:13 pm    Post subject: Re: What did you do for your Bus today? Reply with quote
I have one for my deluxe, but when I went to install it, I said to myself "Ok, are you *really* going to tow anything? Or are just going to bang your shins on this thing?"
-Thom
1956 Single Cab
1963 Unimog 404
1965 E-Type
Page 689 of 691
