Torsion arm clips- source?
sctbrd
sctbrd is offline
PostPosted: Tue Jul 01, 2025 11:47 am    Post subject: Torsion arm clips- source? Reply with quote
My tire rubs the inner wheel well because the torsion arm stop is worn or was ground down in the past.
I just finished centering the steering box and doing the alignment, so I am sure there is nothing with the tie rod setup.
The stop is reduced on both sides.
The Bentley shows a clip that can be used to stop the rubbing.
Is there a source for a clip like this, before I try a more creative solution?
Bobnotch
Bobnotch is offline
PostPosted: Tue Jul 01, 2025 12:43 pm    Post subject: Re: Torsion arm clips- source? Reply with quote
I don't know of anybody selling them (maybe ISP is). You might want to look thru the "local manufacturing" book to see if they show them there. It doesn't look to hard to make one. I'd also look thru the Samba classifieds to see if anyone is selling them (maybe the type 3 detectives?).
Bob 65 Notch S with Sunroof
Tram wrote:
Tram wrote:
squaretobehip
squaretobehip is offline
PostPosted: Tue Jul 01, 2025 3:32 pm    Post subject: Re: Torsion arm clips- source? Reply with quote
I've never really seen these during my time at ISP. I also can't remember the last time I've seen any come up for sale.
The local manufacturing book might be a good start. I can do a quick glance when I get some time.
1963 Notchback - Ruby Red
1963 Squareback - Pearl White
1965 Squareback - Baltic Blue
Follow ISP West on:
Bobnotch
Bobnotch is offline
PostPosted: Wed Jul 02, 2025 10:00 am    Post subject: Re: Torsion arm clips- source? Reply with quote
Yeah, those were my only thoughts on them or who might have them. I've never seen them in the wild in person either.
Tram wrote:
Tram wrote:
sctbrd
sctbrd is offline
PostPosted: Wed Jul 02, 2025 10:05 am    Post subject: Re: Torsion arm clips- source? Reply with quote
Mario has them listed, might have a pair left, hopefully... Smile
https://type3headquarter.de/epages/7b2adfc2-5ed3-4...3HQ4_05185
Bobnotch
Bobnotch is offline
PostPosted: Wed Jul 02, 2025 10:20 am    Post subject: Re: Torsion arm clips- source? Reply with quote
Yeah, I thought he'd probably be one of the few places that might have them, if anybody did.
They're not really commonly used.
Tram wrote:
Tram wrote:
squaretobehip
PostPosted: Wed Jul 02, 2025 11:21 am    Post subject: Re: Torsion arm clips- source? Reply with quote
Nice!
Follow ISP West on:
mdege
mdege is offline
PostPosted: Wed Jul 02, 2025 10:51 pm    Post subject: Re: Torsion arm clips- source? Reply with quote
You can also try Typ3 Conny he is advertising repros:
http://www.typ3-konny.de/Seiten/anschlagbegr.htm
I know his page is very funky retro Very Happy But, he is well known in the community.
- Michael
1963 Typ3 Notchback project
1988 Multivan Magnum 112i
sctbrd
sctbrd is offline
PostPosted: Thu Jul 03, 2025 4:58 am    Post subject: Re: Torsion arm clips- source? Reply with quote
Mario has a set for me, thanks, might help the next person.
KTPhil Premium Member
KTPhil is offline
PostPosted: Thu Jul 03, 2025 8:07 am    Post subject: Re: Torsion arm clips- source? Reply with quote
A long while (decades) back, I needed them on one side. Turns out I had a bent torsion arm, and when replaced, I didn't need it anymore. I'm pretty sure I chucked them a couple of moves ago. Really hurt the turning radius for u-turns.
Maybe a large thick worm clamp could add a little help there? You could add thin rubber under it to "tune" the thickness.
Current Fleet:
- '71 Fastback
- '69 Westfalia
Retired:
- '67 Beetle
- '65 Beetle (x2)
- '65 Bus
- '71 Squareback
Bobnotch
Bobnotch is offline
PostPosted: Thu Jul 03, 2025 8:46 am    Post subject: Re: Torsion arm clips- source? Reply with quote
KTPhil wrote:
A long while (decades) back, I needed hem on one side. Turns out I had a bent torsion arm, and when replaced, I didn't need it anymore. I'm pretty sure I chucked them a couple of moves ago. Really hurt the turning radius for u-turns.
Yeah, that was my thought, along with having a beetle rim (wrong offset on that side).
Tram wrote:
Tram wrote:
sctbrd
sctbrd is offline
PostPosted: Thu Jul 03, 2025 9:01 am    Post subject: Re: Torsion arm clips- source? Reply with quote
[quote="KTPhil"]A long while (decades) back, I needed hem on one side. Turns out I had a bent torsion arm, and when replaced, I didn't need it anymore. I'm pretty sure I chucked them a couple of moves ago. Really hurt the turning radius for u-turns.
The next part of the Bentley page says that is the turning radius is too large with the clips, you can grind the stops down, but to be careful of the clearance.
It looks to me a PO may have done this, since both sides look to be ground down and the same amount.
Unless they constantly slammed the steering against the stop on both sides very hard and wore them down that much!!
I wanted the clips, and if there is some reason they are too much for turn radius, Ill add a spacer of some other kind- the hose clamp is a great idea.
