raygreenwood Samba Member
Joined: November 24, 2008 Posts: 23229 Location: Oklahoma City
Posted: Tue May 20, 2025 10:50 am Post subject: Re: Jeremiah's 73 412 restoration project |
Jeremiah Berger wrote: |
raygreenwood wrote: |
Ok so what about the VW stamp in the pulley? Is that just coincidence that this lines up with tdc in that quadrant? Or do any of the other pulleys have a VW stamp like mine?
Also considering what you are saying the weight is actually in the same quadrant in each instance correct? Let's call it 730-1030...
If I put my logo mark at bottomdc I get my weight at about 930.
That is some consistency I guess being all in the same quadrant? |
Forgot to look for the vw logo. Checking later.
Ray |
Thanks Ray, I'll check back in a bit. |
Ok.....I looked at three of the four fans I have handy. One is disassembled and in hindsight I should have checked it as well because if it has bus timing mark on the pulley as well a 0 for the 411/412 timing it would have been one more indicator.
It literally took me 30 minutes to find ANY VW stamps and no two were the same size/diameter. Very faint. One hidden by aftermarket paint and the other two were shallow and rusted over.
So....
Fan #1 is off of my engine. It is a spinner style with the rubber nosecone. It's positions are known to be factory. It has the "0" for TDC and the red mark for 27°BTDC....and the bus timing mark on the pulley......and it has the VW logo corresponding to "0"/TDC.
Fan #2 is a flat faced bus style fan from a bus. It has no "0" for TDC like those used on 411/412.....but placing it with the locating pin at about 10:30 and counting fins over to find where TDC is.....you can see the bus timing mark on the pulley at ~10:30-ish.....and yes....there is a VW logo at the 12:00/ "0" position.
Fan #3 is kind of a mess. It has been disassembled....and painted black all over including the aluminum section. It has the spinner style, cone shaped aluminum section and it has a "0" for TDC so it was originally a 411/412 or 914 fan. But, it has a timing mark in approximately the right position for the bus but it's not a factory made mark. It also has one at 180° to the bus timing mark so someone had made marks to be able to find TDC on all four cylinders.....and its VW logo is at ~3:00 position.
So I would call this best intelligent guess from two data points that the stamped VW logo on the pulley should be at 12:00/TDC.
A great way to get a good cross section of data points is to ask the guys in the bus forum to put their engine at TDC by the timing scale and see if a VW logo appears on the pulley at 12:00.
I will also add this information to both of my threads on type 4 fans. One thread is all about all of the different timing marks and the other one was linked here already about recentering the fan pulley.
If this turns out to be a common item.....VW logo at 12:00 TDC....it can help a lot of people.
Ray |
Jeremiah Berger Samba Member
Joined: September 16, 2018 Posts: 173 Location: MAINE
Posted: Tue May 20, 2025 11:24 am Post subject: Re: Jeremiah's 73 412 restoration project |
Ok, well I in the meantime have talked to my machine shop vw guy about rebalancing it and he wasn't really set up but could send me with a crank to the place that does his balancing or something...but he then says he's got piles of fans if I want to come get one and can have one.
So I saw you response and called him back and he said I could come look through them all I want.
If I find out they are all stamped at tdc then I'm good to go.If not I will just grab a new fan.
I also have a type 2 bus parts guy real close and I can see if he has any fans I can look through if I'm indecisive with what the machine shop has to look through. He said he has piles of them, so we'll see.
I might be able to do that tomorrow so I'll post an update afterwards. Thanks again for the help. |
Posted: Tue May 20, 2025 1:23 pm Post subject: Re: Jeremiah's 73 412 restoration project |
The other way to look at this is ...that if you get the pulley back on very well centered with the dial indicator....and you then have a noticable imbalance....ther are ony 4 positions that there could be.
I would just loosen it back up, take the pulley off and rotate it 90*....recenter it....and run it again. Yes, its tedious but it can get you back to where it ws when it left the factory.
If you end up having to do this with the engine in the car....thesimplest way is to make a bench top board with three dirt cheap skate bearings on a piece of MDO board with the dial indicator mounted on the board.
Once you get the hang of this you can put a fan on the board and get it recentered in roughly 10-15 minutes of work.
An even easier method if you set up this board...once you get one fan perfectly recentered, but three fixed pins on the board that bear against the pulley ring at 120* apart so you can take a fan bolted to its hub....put it in the bearings with the four bolts loose and the three fixed pins around the perifphery will push the pulley ring the center position the econd you put the fan in the jig...and then just tighten the four bolts. Done. Ray |
Posted: Wed May 21, 2025 8:32 am Post subject: Re: Jeremiah's 73 412 restoration project |
Well after climbing through an attic full of vw parts and looking at a good 10+ fans I can conclude that the VW emblem is not an indicator of tdc.
In fact I was able to find a total of 5 since so many where rusted or painted I couldn't even find the stamp on them.Of those five three where at bdc one was at 3 o'clock and I believe one was at 9 o'clock as well ...
So it seems like it is by chance that the ones you have are lined up at tdc...
It's a 1 in 4 chance.
So the pulley was likely stamped on the line all in the same spot, but then that was taken and matched to the aluminum fan. At this point there was a 25% chance that it could end up at tdc so not surprising that you have some and a good chance there are a lot out there that it does line up
But I would conclude that it is not an indicator.
I got a new fan. It has the 0 and the type 4 timing mark.Its in the sonic cleaner...I will paint it without taking it apart and move forward....
Moral of the story...DONT DISCONNECT THE FAN FROM THE PULLEY. |
Posted: Wed May 21, 2025 11:19 am Post subject: Re: Jeremiah's 73 412 restoration project |
....unless you mark it!
I have concluded though that somewhere either near the end of 411 or in the middle of 412 production....they started making fans that would work on more than one vehicle....like buses and 412's or maybe even 914's.
Hence why over the years I have found more than a few fans that have both:
1. the engraved marks on the aluminum fan portion....various combinations of the 0, the red 27* BTDC mark, sometimes another black mark correspsonding to something in between the two, some fans with no 0 and only a black or red mark.....and....
2. Also having a "0/TDC" mark at approximately 10:30 position on the pulley ring that cooresponds to the offset bus plastic or metal timing scale.
If you can find a fan like that....or just put the bus TDC mark or the 411/412 TDC mark on the pulley ring yourself.....you will never again have an issue with disassembling it and getting it out of balance.
Oh...and do yourself a favor. Go ahead and set up the dial indicator and make sure the pulley ring is concentric to the fan casting of your "new" fan.
The problem is that over the years, so many owners could have done so many things.
Also, if you can....get a good spare fan.
My original 412 fan is missing two blades. One was me doing the stupid and one was something that fell into the fan. They are 180* apart so I will do a others have done and smooth off the nubs and/or knock out two more to keep it balanced in all four quandrants. I will keep it as a spare.
It can happen to anyone. Get a spare fan. They will get less and less available as time goes on.
also if you have not seen it....here is a good thread about type 4 fan timing marks from the 911/914 forum.
https://www.thesamba.com/vw/forum/viewtopic.php?p=8776292&highlight=#8776292
Also in that thread is a guy with a fan that has no "0"...but also has the VW symbol at TDC.
I cannot tell if I am halucinating but it almost looks like a small "0" symbol hiding in the rust above his VW symbol????
Ray |
Posted: Sat May 31, 2025 3:51 pm Post subject: Re: Jeremiah's 73 412 restoration project |
Finished the engine today! Just need to put the exhaust on and it's ready to mate to transmission and install....
I am back to where I was 10 years ago and in need of the first part I ever tried to find.. if anyone has one let me know. I had some ideas of using other materials but it is a tricky piece because it has to flex into place and have the flat section where it is sandwiched between the intake and lid.
Posted: Thu Jun 26, 2025 6:24 pm Post subject: Re: Jeremiah's 73 412 restoration project |
Man I've been waiting on fuel hose... ordered the wrong stuff. Waited more..got it today and everything is all ready to go and finally got everything ready to do break in and hoping to do it this weekend. I am currently home with three kids for the summer 4,9&11 so I'm super busy but committed to getting this thing driving this summer
But while I'm doing my summer thing of boating and fishing with the kids we decided to get our recreational lobster license and get a couple traps this year
Well this is too crazy of a coincidence to not share ...
These are the tags for our lobster traps.
Also some pics of progress...
Posted: Sat Jun 28, 2025 12:25 pm Post subject: Re: Jeremiah's 73 412 restoration project |
Well it's not going so well ..
I am not getting signal to the injectors during cranking.
I tested them by disconnecting the fuel rail and have the ignition on and open the throttle to see that the injectors are working when throttle is engaged but nothing during cranking...
The wiring harness has been gone over completely and repaired correctly where needed.
All the connections have been double checked. Grounds are connected
The injector points have been adjusted and within spec.
Really at a loss as to why it's not working.
Is there a way to further diagnose what is going on? |
Posted: Sat Jun 28, 2025 1:11 pm Post subject: Re: Jeremiah's 73 412 restoration project |
Ok....so when the key is on and you open the throttle by hand you can hear that long series of clicks during the throttle opening stroke....that tells you the injectors are opening due to the TVS action...right?
If so, this tells you that you are getting power to the EFI system and basic ground to the system.
So, do you have a new harness or an original repaired one?
You say the injection trigger points have been "adjusted"? By whom and how?
The most probable three items that can cause this:
1. The grounding point under the intake plenum where the ground wires from the injectors plug in may not be making connection to ground....or....the main ground to the combined engine case and transmission (which would be the ground strap at the transmission tailcone) is not making connection.
2. The most common issue with trigger points is one of the three female connectors in the three pin plug is not making contact. If nothing injects....its usually the center one which is ground for both. This plug is the single worst contact plug in the car with D-jet.
You can wiggle that plug around and when it works intermittently you know you have a blad plug body or bad female connector inside.
3. The trigger points themselves may not be opening...or on some systems....one trigger may not be opening and that means that the other channel never gets "armed" so neither one works.
Its worthwhile to connect your fuel rail back up, pull two injectors on one side and place their tips in a rag. Disconnect the positive wire to the coil so you have no spark. Then crank it and be absolutely sure you get no injection.
Also, check the plugs on the MPS, TVS and especially the CHT/TS2.
Ray |
Posted: Sat Jun 28, 2025 2:53 pm Post subject: Re: Jeremiah's 73 412 restoration project |
[quote="raygreenwood"]
Thank you Ray, it was the connector for the trigger points. As soon as I read that I recalled how flimsy it was. I removed the connectors and pinched them down a little and reinstalled and fit nice and snug.
I then removed the injectors and placed on towel and they worked!
I had got a repair kit for the harness from 914 rubber and replaced a lot of the connections and wire where needed with the correct pigtail connectors and did not replace any of those because they where in food shape and far away from heat damage.
I got a tool a long time ago from Norbert Fischer a Porsche guy I believe.He made it. It mimics the size of the distributor cam and let's you set the points...
Anyways I got it to fire an pop and almost start and now the battery is dead and my jumper pack from me cranking it all day..
Hopefully I just need to get it charged and the timing adjusted a touch and it will fire up .. |
Pepperbilly Samba Member
Joined: April 08, 2017 Posts: 1090 Location: Seattle, Wa
Posted: Sat Jun 28, 2025 4:29 pm Post subject: Re: Jeremiah's 73 412 restoration project |
My wife and I were in northern BC and the Yukon for a month so I wasn’t following the internet very much. Your progress looks wonderful!
Getting these engines to run right away after major work is a challenge. Ask me how I know. Good that you found the loose trigger points plug. I actually had to install a new set of triggers that I luckily found, NOS, from a guy close by that had stored away from the 80’s! I did use my original wiring harness that I made some repairs to. I found it’s the connections that you really have to pay attention to.
Other problems I ran in to… I had to rebuild my MPS with a new diaphram kit from Tangerine Racing. Also the head temp sensors are tough to source for correct good ones. Finally found a NOS Porsche sensor that fit the bill. Bad sensors will drive you crazy. Then also for a while I had a cracked spark plug that gave me fits. One of the last issues was very fine debris that contaminated my original fuel injectors. Thought I had cleaned the fuel tank well enough. Nope. Had to open it on top and vacuum out those silty particles. At that point I ordered 4 new SMP injectors and never looked back. I do have a box of fuel filters and do change without hesitation if they show any debris.
Took me a few weeks to get it all sorted. Wonderful outcome though…purrs like a kitten and Goldie is such a joy to drive.
Good luck getting her running. It may take a while but you will get there.
Bill |
Posted: Sat Jun 28, 2025 5:36 pm Post subject: Re: Jeremiah's 73 412 restoration project |
Pepperbilly wrote: |
Bill |
Thanks Bill, I am thinking i will go over the other connectors and do like I did with the trigger points one. And make sure they are all nice and snug.
The thing is the fuel injection was all working before I took it all apart and had already figured out things like temp sensors and overall had dialed the system in, so in reality it should all be all the same besides the wiring and connections so hopefully I will get this figured out and running without anymore issues.
Thanks for the positive input, I need it after today....
I swear I new it was the trigger points or in reality considering everything else was good that was what everything was pointing to, but I was looking at the trigger points themselves and making sure they where adjusted and cleaned correctly and never even thought about that connection.
I had been over the whole system and checked everything over and over and was pulling my hair out ...
Now I'm where I should have been first thing this morning but with a dead battery...
I decided to just relax and pick it up in the morning ...
I'll go over everything. AGAIN with a fresh brain and hopefully it will start up for me in the morning.
I |
Posted: Sun Jun 29, 2025 6:18 pm Post subject: Re: Jeremiah's 73 412 restoration project |
Today was a success! Got it started and broke in the cam.
Set the timing and got it running well for the most part. Well, really good on the top end but definitely still have to dial in the idle.
It seems as if my TVS needs adjustment. Even though I've set it and double checked the adjustment.
The symptom is a high idle...or more or less an intermittent idle...but not a quick pulse like I've dealt with before it's more like it just doesn't want to drop down to idle some times and takes up to 20-30 seconds to drop down to what is then a low idle that gets it pulsing a bit ...
It also seems to sometimes drop when I manually return the throttle, stronger then the spring..but sometimes it doesn't.
I am suspicious of the TVS still and think maybe it needs adjustment still.
I used a voltmeter to check resistance between 12&17 and adjusted it to just as throttle opens but did that with the throttle body out of car and it seems that with everything hooked up and running that the throttle doesn't quite return that far on normal operation.. at least that is my theory to test for now..
It seems as if the engine is creating so much vacuum that it doesn't allow the throttle to close all the way.
I know the TVS doesn't necessary solely control the idle speed and could be other influence and maybe that has more to do with it then the TVS itself.
I swear I think have a good understanding of this fi system, but when it comes to the idle it hurts my head and seams like Vudu magic is needed sometimes.
Other than that it had no leaks, no smoke, no ticks or weird noises..oil pressure good. Charging good. Overall a good day.
Plan on doing some more fine tuning and try to get it on the road next and test the rebuilt transmission... |
Posted: Mon Jun 30, 2025 6:23 am Post subject: Re: Jeremiah's 73 412 restoration project |
A couple items:
1. In reality, the TVS has nothing to do with idle unless either due to adjustment the forked switch is in contact with the on/enrichment pin and even then it has to be out of the padlomg area for the wiper arm tip.....which would/could happen if the throttle is not closing all the way. But if that is happening, the real cause of idle issue is slightly open throttle.
The TVS is an enrichment function only when it's moving.
2. The 1.7L throttle bodies have always had some issues with closing all the way with age.
What I have had to do is make sure the throttle cable is taut and also add some spring tension. If you leave the cable slightly loose to combat this....it will drive like it has a flat spot.
The other item is that with the throttle body off, look at it with light behind it. I have found that with age and a little wear, I have to crack the screws on the throttle plate and be sure it's centered.
3. So, the issue with that trigger points adjusting tool....more precisely, my issue with it. Somewhere in the forums I have added some of this opinion in a discussion but I have never actually spoken out for or against this tool. Because.....even though I think it has some issues, I do not yet know if these issues make a big difference or cause a problem.
The issues I see:
That tool is basically mimicking the MAJOR circle of the shaft along with its 180°cam. This part I do not see as wrong. At the very least it allows you to set up/adjust to account for points rubbing block wear.
But, to get the combination of moving point LIFT, duration/dwell and TIMING correct....takes a little more thought.
Part of the issue I see is that the tool guides off of the center fork of the points plate. But, the distributor does not only or mostly guide off of this center slot or fork. If you swap the same set of point between three different distributors with the same part # and then turn the engine around by hand using a test light to see if each point is opening/closing in the same reference to crank and valve position....you will see variation. Is it enough to be q big problem? No not q big problem but it depends on what other issues it is stacked up with.
The other issue is that the jig sets both points up the same....but they actually wear at different angles and rates because one opens trailing and the other leading.
This angle change can change lift and dwell. Ray |
Posted: Mon Jun 30, 2025 7:15 am Post subject: Re: Jeremiah's 73 412 restoration project |
Okay I think I will focus first on #2, it seems as if this is certainly a part of the issue. I considered a tighter spring, and will add one.
There is definitely a lot of what you explained going on with the throttle cable force and had been playing with that.
I'll keep trying to adjust that and keep you updated with my findings.
For the trigger points I see what you mean especially the part of where the tool mounts vs where it mounts in individual distributors...
For the most part I barely made any adjustments to them. I believe they where pretty close to being in spec when I originally adjusted them 10 years ago ..and this time around I just checked them after I cleaned up and serviced the distributor. They where still good.
Just of curiosity what would be a common symptoms of the trigger points NOT being adjusted correctly? |
Posted: Tue Jul 08, 2025 9:08 am Post subject: Re: Jeremiah's 73 412 restoration project |
Nice job on dressing out that engine. By the way, I noticed you painted the cooling fan housing. What product did you use?
So have been thinking about the idle inconsistency. I noticed from your photos you did not secure your intake runner fabric connectors with any clamps. When I put my engine together I paid special attention to the runners. I had to realign the runners to the throttle intake plenum because they were off quite a bit. I modified attachment mount holes and repositioned everything to get a perfect align. I finished it by using sealant on both ends of the fabric connectors and adding some clamps. This assured me of a tight leak free intake. I have nice stable and consistent idle. I would double check that on yours. Just another suggestion…
Bill |
Posted: Sat Jul 12, 2025 11:28 am Post subject: Re: Jeremiah's 73 412 restoration project |
Well soon after my last post I had a major discovery that one of my injector seals had fallen off in the excitement of getting the injectors working and the car running.
After fixing that massive vacuum leak and starting over that switched to low intermittent idle...played around a bunch just trying to get an idle and having it crash out whenever it would ever come down....
Decided to go back over everything and check for leaks and check each part of the system..
I hadn't checked my MAP sensor since doing the whole rebuild and should have probably checked it before putting it all together. Although I am suspicious that I gave it the final blow with alot of vacuum or a backfire when trying to original get it started ( I actually hooked up the wire wrong for. A few cranks and backfired before realizing.)
Anyway the sensor did not hold vacuum very much at all at this point and upon disassembly found that it has a big tear in the diaphragm like they all get ...
Glad I figured it out, but now what? Looked around and seems like someone made some diaphragm at one point but I don't see any available for sale now?
And the price for a refurbished one is absolutely insane..
What are my options? Is there someone I can send it to to get it fixed?
Obviously a used one is likely shit or on its way out.
And a repaired one is going to then need to be dialed in and adjusted right?
Any suggestions on how to proceed? |
Posted: Sat Jul 12, 2025 1:15 pm Post subject: Re: Jeremiah's 73 412 restoration project |
Been down this road with Goldie so I know exactly what you are up against.
The first thing is it has to hold vacuum. Vacuum loss can be one of 2 things or both. Like you discovered the diaphram is ruptured so it will not hold vacuum right off the bat. Also, if the 2 halves of the MPS body have a faulty seal that will also cause a vacuum leak. In some cases it is both, like it was for me.
I went ahead and chose to rebuild. If you choose this route it is very important to not alter the diaphram depth setting in its body. Hopefully you have not scraped out the epoxy for the large screw plug and altered it. The factory has set this depth and it is important when rebuilding, to know and measure this setting. That's why the factory filled the plug with epoxy, they wanted no one to monkey with the adjustment.
I ordered my rebuild kit with diaphram from Tangerine Racing. They are located in Manchester, Conn. which is not that far from you. They are 914 racing specialists. The kit comes with several pages of instructions and the parts you need. I would also get the adjustment tool that they have but is an extra order.
Last question. Do you know if your MPS is the original to your car? The original ones have the body halves that are riveted together, not bolted together. If in its original condition the diaphram has the factory depth setting which is what you want to duplicate.
Bill |
Posted: Sat Jul 12, 2025 1:52 pm Post subject: Re: Jeremiah's 73 412 restoration project |
Thanks for the feedback bill. Yes the MPS appears to be original and had the original rivets that I removed. I did mess with the adjustment screw when I was trying to figure out if I could get the diaphragm off of the center hardware wich I'm guessing is part of the instructions and parts?but I counted the threads and returned it to where it was.
I did notice that there is a secondary screw that the screw goes into and that had moved upon reinstalleding it, so hopefully I didn't move that screw unknowingly I'm pretty sure I returned it to where it was. But I should probably get the tool, and imagine that as to either hold the one while turning the other or are there two adjustments?
I had already seen that kit and couldn't find it on their website so I sent them an email. If anyone has a link for the kit on their site that would be great. The one I had was expired . Thanks |
Posted: Sat Jul 12, 2025 2:05 pm Post subject: Re: Jeremiah's 73 412 restoration project |
Well that's a bummer.....this is the email I got back
Hi Jeremiah,
That's an image from my old website.
I produced the repair kits for more than 10 years, but last year my stamping supplier stopped making the diaphragms for me. I'm currently working on making them available again before the end of this year.
Chris Foley
Hopefully I can find something else or an old one to use for now or maybe someone has an extra kit that they didn't use ... |
