TomInAlaska Samba Member
Joined: June 02, 2007 Posts: 478 Location: Anchorage, Ak
Posted: Sun May 04, 2025 8:28 pm Post subject: Re: An Alaska NSYNCro build |
uberaudi wrote: |
That's incredible! Love the old school look to it. Does it actually play cassettes too? |
Haha, nah, it doesn't really play cassettes. Disappointing, I know. There is a USB port behind that flap, though, so its not completely for looks. _________________ '73 Super Beetle (formerly resto-mod/rally look with a healthy 1776, currently in another round of resto with a 1641)
'84 GL adventure van project [sold] (1.9L, 4speed) https://www.thesamba.com/vw/forum/viewtopic.php?t=755844&highlight=
'86 Syncro tintop (2.0L Eurospec/ABA engine swap) https://www.thesamba.com/vw/forum/viewtopic.php?t=800194&highlight= |
Posted: Wed May 07, 2025 3:12 pm Post subject: Re: An Alaska NSYNCro build |
Today was the day I do something about the box of brake parts I've been tripping over for a month.
Upacking the Small Car kit:
Stock brakes:
And throwing on the GoWesty cv protectors while I had things apart:
And done:
It all went together without a hitch. All the old bolts and line fittings and things came apart as easy as you please and the new stuff went into place smooth as butter. I was able to reach in to press the pedal to bleed by hand on the driver's side but mostly relied on gravity for the passenger. The pedal feels a tiny bit softer than before (might be better if I do a proper flush and bleed all the way around, the fluid in the reservoir looked like it had been in there a long time) but the stopping performance is massively improved! Definitely one of the better upgrades I've done so far. _________________ '73 Super Beetle (formerly resto-mod/rally look with a healthy 1776, currently in another round of resto with a 1641)
Posted: Fri May 16, 2025 6:07 pm Post subject: Re: An Alaska NSYNCro build |
Another work session, another seemingly unrelated issue pops up.
Yesterday I was finally able to set aside enough time on a nice day to get the stainless steel coolant pipes and new radiator hoses installed. I also flushed as much of the remaining coolant system as possible and got lots of old looking yellowish green coolant out of the radiator and heaters and engine. New pipes and hoses went back in without too much fuss and then came time to refill and try to get as much air as possible out. I used a combination of filling the pressure tank, then pressurizing it with the gowesty hand pump to push coolant into the system, then cracking the bleeder on the radiator to let the air out up there. The van was parked on a slight incline with the nose up for all this, by the way. Anyway, after I got about 3 gallons pushed in like that, I cranked the engine and let it idle to cycle the coolant and build pressure for further bleeding. This was going pretty well, maybe 20 minutes of idle time, until the engine got up to temperature per the gauge and then started running really rough. Idle speed dropped way down, misfiring like crazy, not immediately responding to throttle, then it would 'catch' and rev like normal then settle back into a normal idle for a minute then run rough again. It almost felt like it was running out of gas, but per the gauge and miles since fill-up, it has about half a tank. I checked as many electrical connections I could, including the fuel pump relay (which looks to be factory). Pulled the plugs and they look fantastic. Cap and rotor had a little crud on the contacts which I cleaned, but I've seen way worse. No loose hoses or any obvious sources of vacuum leaks, either.
Today I was back at it, and found it would crank and run fine for a couple of seconds then completely die. Like it ran out of gas. I am beginning to suspect the pump itself. Like the relay, it looks like it might be factory. I do have a spare pump I'll try tomorrow and see if that changes anything. But if anybody has any other ideas though, I'm all ears. _________________ '73 Super Beetle (formerly resto-mod/rally look with a healthy 1776, currently in another round of resto with a 1641)
Posted: Sat May 17, 2025 12:02 pm Post subject: Re: An Alaska NSYNCro build |
I'm fairly confident that's the factory fuel pump. I'm also cautiously optimistic that it's still in good working order and that the issues I was seeing were due to bad connections and/or dirt in the gas. I did pull a sample and saw a tiny amount of dirt or something.
Maybe the fact that I was idling the engine without moving let enough of whatever shmoo is in the tank to settle and get picked up by the pump and partially clogged it? In any case, I sprayed the intake and output of the pump with brake clean, sanded the contacts and very slightly squeezed the female spade wire ends to get a better connection, and put it back in place. It does seem to be running normally so I'll take it for a drive later today to see if how it acts. I will keep my spare pump and everything to swap it out in the van just in case. _________________ '73 Super Beetle (formerly resto-mod/rally look with a healthy 1776, currently in another round of resto with a 1641)
Sodo Samba Member
Joined: July 06, 2007 Posts: 10639 Location: Western WA
Posted: Sat May 17, 2025 12:21 pm Post subject: Re: An Alaska NSYNCro build |
TomInAlaska wrote: |
It all went together without a hitch. |
Dang but that was a nice hitch
Next on the list in addressing the driveline vibrations.
it felt like it was trying to shake itself apart above like 15 mph.
----> Imagine my surprise when I found that the u-joints were out of phase! No wonder it was shaking so bad! I quickly unbolted the rubber donut from the main propshaft body and rotated the u-joints to be in phase. I did drive it a few miles yesterday and the vibrations were vastly improved, |
interesting.... the angle is only ~4° so it surprises me that the pulsation could be noticeable.
Of course the phase should be corrected.
No stone un-turned in the pursuit of Syncronicity
While I had the propshaft out, I scrapped and cleaned as much of the unevenly sprayed on rubberized undercoating off as possible.
Its probably not enough weight to throw the thing out of balance but every little bit helps, right?
Now I'm gonna go the other way and opine that the weight of that undercoating is more than enough to throw off the balance.
I wonder how many other vehicles suffered that undercoater's blessed touch.
YouTube university shows driveline vibration affected simply by the weight of the worm-drive-screw on a hoseclamp.
I was going to try that but didn't have a long enough hoseclamp,
so I put two together and clamped peice of scrap steel in the middle.
Try and imagine the glee when the vibration disappeared on the FIRST TRY!
I think I'd better test again to be certain it wasn't my imagination.
I will report back if the vibration is still there.
Today I was back at it, and found it would crank and run fine for a couple of seconds then completely die. Like it ran out of gas. I am beginning to suspect the pump itself. Like the relay, it looks like it might be factory. I do have a spare pump I'll try tomorrow and see if that changes anything. But if anybody has any other ideas though, I'm all ears. |
Got any pressure gauges in your toybox 0-50psi? Conjure up a fuel pressure test rig. _________________
....KTMs, GasGas, SPOT mtb |
Posted: Sat May 17, 2025 12:58 pm Post subject: Re: An Alaska NSYNCro build |
Sodo wrote: |
Got any pressure gauges in your toybox 0-50psi? Conjure up a fuel pressure test rig. |
I do have a fuel pressure test gauge but haven’t yet figured out how to hook it up. I did find the regulator yesterday while crawling around under there tucked up partially inside the intake manifold (at the end of the fuel rail of course). There’s probably a test port like on a waterboxer, but I haven’t seen it yet.If I still have issues I think actually testing the pressure is the next step. _________________ '73 Super Beetle (formerly resto-mod/rally look with a healthy 1776, currently in another round of resto with a 1641)
Posted: Sun May 18, 2025 12:05 pm Post subject: Re: An Alaska NSYNCro build |
Just got back from a ~5 mile trip to West Marine for a handful of new hose clamps (the good kind without cutouts and with rolled edges) to replace the old ones I had to reuse on the coolant pipes to engine adapter pipe to ABA hose sections. They're holding, but better safe than sorry. Anywho, apart from a few sputters at the end of the driveway which I assume was a little air in the lines, it ran great. Hard to say for certain, but I feel like it idles smoother and maybe even makes a couple more horsepowers. More miles will tell if I actually fixed anything or not but so far so good.
I've also got a new fuel filter on order, but I've been toying with the idea of a spin-on type filter with water separation. Being a syncro, locations to put it are somewhat limited. Maybe high up in the wheel well? With a sheetmetal guard for rock protection? _________________ '73 Super Beetle (formerly resto-mod/rally look with a healthy 1776, currently in another round of resto with a 1641)
Posted: Fri May 23, 2025 7:46 pm Post subject: Re: An Alaska NSYNCro build |
Today I tackled rehabbing the sliding door with the rebuild kit from GW:
Apart from the cover panel that needed a generous application of WD40 along the rubber strip and soft face mallet, the only real problem was one of the bearings on the rear hinge mechanism. It was in very bad shape and fell apart when I tried to pry it off. I had to get a little creative to get the inner race off. I cut a part of a washer and a drift punch.
New bearings and nylon guide wheel installed:
The under the panel area cleaned up and track hit with a coat of bare-metal primer:
The rest went together without a hitch and now the door is noticeably smoother and quieter. Great success.  _________________ '73 Super Beetle (formerly resto-mod/rally look with a healthy 1776, currently in another round of resto with a 1641)
Posted: Wed Jun 11, 2025 9:22 am Post subject: Re: An Alaska NSYNCro build |
Since the last update, I haven't really had to do much to the van lately besides put gas in it. Yesterday though I decided to start working on freshening up the rust proofing/undercoating that someone very generously applied to pretty much the entire bottom of the van. That is one of the major reasons I think its still in such good shape, btw. Anyway, while scraping loose and peeling up bits of the old undercoating off the bottom of the front cab area, I found a hole in the middle of the passenger floor. Not rust, but drilled and pried up oblong hole that somebody then filled and sealed with a huge glob of silicone. (no 'before' pics and I was distracted with multitasking cleaning the washing machine so it will drain properly and not leave our clothes sudsy) Needless to say, I grabbed a wirewheel, a piece of scrap sheetmetal, and my trusty mig welder and went to work:
It got a coat of etching primer and then some (almost correct) touch up paint but I didn't bother to get the surface super smooth and finished since its under the carpet and pad. I did generously spray the underside with new rubberized undercoating. I plan to continue freshening up the undercoating around the van and getting something like Eastwood internal frame spray inside the "frame rails" to give this thing the best chance it has of continuing to have a mostly rust free life. _________________ '73 Super Beetle (formerly resto-mod/rally look with a healthy 1776, currently in another round of resto with a 1641)
Posted: Thu Jul 03, 2025 9:22 pm Post subject: Re: An Alaska NSYNCro build |
Since its been a few weeks I figure I should put an update of some of the things I've done to and with the Van.
Its served as an amazing bicycle transport to rides and races:
In that pic you can also see the new awning from Van Cafe (which I, sadly, haven't used in anger yet):
One issue I've been chasing around lately is a wonky odometer. The shaft that holds the number dials with the gear that is turned by the worm gear kept sliding out of the other side of the housing which made it no-worky-worky. I pushed it back in place a couple times but decided to try what is hopefully a more permanent solution:
If that works, I'll post the 3d printer file. (fingers crossed)
But for the most part, I've really just been enjoying driving it:
Just today I drove down to Turnagain Pass to ride part of the Iditarod National Historic Trail. My longest drive in the NSYNCro to date, it ended up being a little over 100 mile round trip. Mostly 55-60mph along Turnagain Arm and a few miles up the aforementioned pass. All the pressures and temps seemed normal, coolant never got above the LED, oil pressure stayed steady at 40ish psi cruising at 3000-3200rpm (around 60mph indicated), and transaxle temp (very) slowly climbed up to 130* by the time I got to the base of the pass and then topped out up to a little over 140* at the top, about 900' of elevation gain in about 6 miles. By the way, I was able to maintain 55-60mph in 4th gear for all but the steepest little section of the climb where I dropped down to 3rd to keep the speed up. There is still an annoying drone from the exhaust between 60 and 65, but around 55mph it just cruises down the road smooth as silk and relatively quiet. All in all I am extremely happy with the NSYNCro and can't wait to go on more adventures. Will it get to the Arctic Circle this summer? Maybe over the McCarthy Road to see the Kennicot Mine? Anybody down for camping on the Homer Spit? Stay tuned to see!  _________________ '73 Super Beetle (formerly resto-mod/rally look with a healthy 1776, currently in another round of resto with a 1641)
Posted: Thu Jul 10, 2025 8:08 pm Post subject: Re: An Alaska NSYNCro build |
I've been monitoring a slight leak of gear oil around both CV flanges on the transaxle for a while. Nothing serious, but a new spot or two on the driveway every day seems like something that should be fixed sooner rather than later. Anyway, I finally got the time and motivation to do something about it today.
First I drained the oil and checked the magnet:
Its only been about 1000 miles since I checked it the first time, so I didn't expect anything, but nice to see a clean magnet in any case.
Next the CV joint got removed and broken plug seal revealed. I actually rtv'ed it back together soon after I got the van when I discovered the cv boot full of gear oil and leaking all over the place. Needless to say, new ones were ready to go back in.
The right-side flange has some damage from ...something? No idea how that happens. Its doesn't seem to affect the mating surfaces or runout, so <shrug>? Maybe I'm seeing things, but does it look like scars from a cutting torch? Which, now that I think about it, might also explain something else I found (see the last pic)
I was hoping the seal surface was good, but there are definitely some small grooves. Maybe the new seals will hold, but I'm assuming I'll have to go back in and add some speedy-sleeves. Oh well.
I initally tried to gently pry the seal out but was afraid I was going to damage something expensive and annoying to fix, so I grabbed the make-shift tool I made when I rebuilt the 4speed in the previous van and quickly unscrewed the adjuster ring. After punching a mark to get it back in the same spot, of course.
A new seal was installed and the adjuster went back in
And here's the pic that definitely shows evidence of excessive heat. Could somebody have torched the bolts to get the CVs off at some point? There was definitely years and years of dirt and grime on both plastic keepers so whatever happened was a long time ago. Interesting.
Anyway, both sides are back together and the gearbox is refilled. I even used new bolts and serrated washers on the CVs. Was actually easier than I expected and only took a couple of hours. Could probably cut that in half next time. Which, like I said, I'll probably be doing to install speedy-sleeves. So it goes.
Or, and hear me out here, I use this as an excuse to go with 930 CVs  _________________ '73 Super Beetle (formerly resto-mod/rally look with a healthy 1776, currently in another round of resto with a 1641)
AndyBees Samba Member
Joined: January 31, 2008 Posts: 2637 Location: Southeast Kentucky
Posted: Thu Jul 10, 2025 8:18 pm Post subject: Re: An Alaska NSYNCro build |
Yeah, I suspect someone got carried away with a cutting torch.
Were the seals hard?
Does a speedy sleeve requiring milling with a Lathe for fitment? _________________ '84 Vanagon Tin-top, ALH TDI, two trips to Alaska, 2014 & 16. 1989 Tin-top unmolested.
1983 Air-cool, 225k miles, 180k miles mine, seven trips to Alaska from 1986 thru 2003. 1975 Bay hopeful. |
Posted: Thu Jul 10, 2025 8:44 pm Post subject: Re: An Alaska NSYNCro build |
AndyBees wrote: |
Does a speedy sleeve requiring milling with a Lathe for fitment? |
Or somebody saw the triple square heads and didn't want to bother getting the correct tool. <shrugs>
The one seal got pretty mangled in my failed attempts to pry it out, but I'll check out the other tomorrow. It came out of the adjuster ring intact. I did see VW/Audi marks on them so they were almost certainly factory.
And as far as I can tell, there's no machining with the speedi(sp?) sleeves: they just slip fit onto the sealing surface and are secured/glued in place with a retaining compound. Looks like they're very thin, like 0.15mm, which gives a new surface for the seal to ride on but not thick enough to adversely affect the function of the seal. Maybe I try to use those, maybe I get new flanges. We'll see. _________________ '73 Super Beetle (formerly resto-mod/rally look with a healthy 1776, currently in another round of resto with a 1641)
uberaudi Samba Member
Joined: June 24, 2013 Posts: 627 Location: Hi-top Country
Posted: Thu Jul 10, 2025 9:38 pm Post subject: Re: An Alaska NSYNCro build |
Speedy sleaves work great and just 'press' on. They are definitely a viable option but with the rest of whats going on with that flange I'd say you're better off to save it as a spare and source a better condition one. _________________ '84 Adventurewagen 1Z TDI, '08 Audi Avant Quattro 6spd BHW TDI |
dobryan Samba Member
Joined: March 24, 2006 Posts: 17153 Location: Brookeville, MD
