Lift points
namvet6872
namvet6872 is offline
PostPosted: Mon Jul 14, 2025 1:45 pm    Post subject: Lift points Reply with quote
Which lift point would be the safest location? I want to raise rear end on a recently purchased '63 Beetle. My first classic and don't want to break something. I've found conflicting answers while searching.
Bobs67vwagen
Bobs67vwagen is offline
PostPosted: Mon Jul 14, 2025 2:30 pm    Post subject: Re: Lift points Reply with quote
I have always used (50 plus years) the small circled wishbone area with a block of wood between it and the jack. In the rear the bottom of the shock housings is also good if you want 2 points. Good luck-Bob
shano63 Premium Member
shano63 is offline
PostPosted: Mon Jul 14, 2025 3:26 pm    Post subject: Re: Lift points Reply with quote
I have always used the bigger circle. So, take your pick..lol
63 T1 Ragtop Gulf Blue
20 Toyota Corolla 6spd
22 Wrangler 6spd
78 F250 4x4 4spd
Chris
namvet6872
PostPosted: Mon Jul 14, 2025 3:41 pm    Post subject: Re: Lift points Reply with quote
Thanks guys, at least I now know that either spot will work...
runamoc Premium Member
runamoc is offline
PostPosted: Tue Jul 15, 2025 7:45 am    Post subject: Re: Lift points Reply with quote
I use the bottom shock 'arms' or under the torsion bar 'plates'. Then again I use two jacks. When I only had one, I put it under the Y 'Yoke' but it ended up getting dented that's why I started using two jacks. Never jack it up using the engine/transaxle cross support.
Daily driver: '69 Baja owned 45 yrs - Plan B: '72 Ghia
Yard Art: 2 Sandrails
Outback: '69 Ghia - '68,'69,'70,'72 Beetle - '84 Scirocco, GTI - Pair of '02 Golfs- '80 Rabbit Diesel
VW Wiring = It's just wires
namvet6872
PostPosted: Tue Jul 15, 2025 11:16 am    Post subject: Re: Lift points Reply with quote
Thanks for the warning, Runamoc...
67rustavenger
67rustavenger is offline
PostPosted: Tue Jul 15, 2025 11:28 am    Post subject: Re: Lift points Reply with quote
You can use the yoke jacking point just forward of the trans to lift the car.
The trick is, place a 1.5' 2x6" on the floor jack center pad, to spread the load.
I do that all the time when I need to get under one of my beetles.
Buy Once, Cry Once!
GFY's Xevin and VW_Jimbo!
Bruce
Bruce is offline
PostPosted: Tue Jul 15, 2025 4:12 pm    Post subject: Re: Lift points Reply with quote
This is why it's common to find the rear trans bracket all bent up.
shano63 is offline
PostPosted: Tue Jul 15, 2025 4:48 pm    Post subject: Re: Lift points Reply with quote
So, why is this so wrong? I've had my car for 30 plus years and no issue that I'm aware of.
22 Wrangler 6spd
78 F250 4x4 4spd
Chris
EVfun Premium Member
EVfun is offline
PostPosted: Tue Jul 15, 2025 4:49 pm    Post subject: Re: Lift points Reply with quote
Yes, but I can buy another one using the classifieds here on theSamba. It is a bit more of a PITA if you bend the frame tunnel under in front of the torsion housings.
Wildthings wrote:
Bobs67vwagen
PostPosted: Tue Jul 15, 2025 6:26 pm    Post subject: Re: Lift points Reply with quote
Just to the rear of the small circle in the op photos with a stout wood block like 2x8 where you span the 2 rear horns will not bend anything and has worked for me for over 50 years.
Bruce
Bruce is offline
PostPosted: Wed Jul 16, 2025 12:28 am    Post subject: Re: Lift points Reply with quote
It's easier to use a piece of wood as described above to spread the load at the front of the trans than it is to replace the rear trans bracket.
