Tesla Tech? In a VW Bus?? Oh yea!
Page: Previous  1, 2, 3  Next
Abscate Premium Member
Abscate is offline
PostPosted: Wed Jul 16, 2025 4:22 pm    Post subject: Re: Tesla Tech? In a VW Bus?? Oh yea! Reply with quote
Good to hear from you, Man of Kent….
SGKent Premium Member
SGKent is offline
PostPosted: Wed Jul 16, 2025 5:03 pm    Post subject: Re: Tesla Tech? In a VW Bus?? Oh yea! Reply with quote
Gracias senor Abscate, Y tu?
Balidas
Balidas is offline
PostPosted: Wed Jul 16, 2025 6:13 pm    Post subject: Re: Tesla Tech? In a VW Bus?? Oh yea! Reply with quote
lil-jinx wrote:
a L-bracket and a hose clamp instead of welding ,would be adjustable,
Absolutely that will work. Thanks.
Balidas
Balidas is offline
PostPosted: Wed Jul 16, 2025 6:29 pm    Post subject: Re: Tesla Tech? In a VW Bus?? Oh yea! Reply with quote
KTPhil wrote:
Most mechanical brake switches mount inside the car, and therefore are not sealed from the elements.
This is true and the thought had crossed my mind briefly but I have yet to look into this more deeply.
KTPhil wrote:
Also, some had a reaction of the switch contacts to (I think) teflon in the switch body, causing early failure.
I was not aware of this.
KTPhil wrote:
If I used an electric vacuum pump, I'd add a '80s-vintage vacuum reservoir to assure me of multiple powered stops should the pump fail, or I was forced to turn off the ignition (like stuck throttle).
https://www.summitracing.com/parts/sum-g1464b?seid...RYEALw_wcB
That would make sense. When we installed an electric vacuum pump in my buddies car, because of the cam he was using, I don't remember ever installing a reservoir. He may have done so later on but I don't know.
Balidas
Balidas is offline
PostPosted: Wed Jul 16, 2025 6:33 pm    Post subject: Re: Tesla Tech? In a VW Bus?? Oh yea! Reply with quote
SGKent wrote:
busdaddy wrote:
Balidas wrote:
...........In the meantime, I have have to eat, I am starving.
Posting while experiencing low blood sugar often results in regrettable statements, careful. Wink
funny. Quite funny.
Saw our first Buzz on the way home yesterday from the hospital. Very nice looking car. Will probably get one when we sell the 1977, if we sell. The oil leak appears gone - and other than needing new tires due to their age of being over 10 years old, and a brake fluid change the 1977 appears as good as life gets. The Buzz for us would be better than any resto tesla bus, but go for it and enjoy it. There were a couple bays around on the forum that are used to drive to the store, or go to the beach. Unless someone has free charging, and too much time on their hands, long distance EV bus trips are not likely to be in a bay owner's future. Sounds more like a science experiment, or maybe what BusDaddy mentioned.
I've read a review and seen a bunch of pictures of the Buzz. Nice but, until they build an electric vehicle that can self charge and not need to be plugged in, I'm not interested.
tommu Premium Member
tommu is offline
PostPosted: Thu Jul 17, 2025 11:42 am    Post subject: Re: Tesla Tech? In a VW Bus?? Oh yea! Reply with quote
I'm waiting for my bus to fill itself with gas.
Green Bay Bus Yellow Ghia
SGKent is offline
PostPosted: Thu Jul 17, 2025 1:14 pm    Post subject: Re: Tesla Tech? In a VW Bus?? Oh yea! Reply with quote
let me know when that happens Smile I'd love the feature too. Smile
Balidas
Balidas is offline
PostPosted: Thu Jul 17, 2025 5:26 pm    Post subject: Re: Tesla Tech? In a VW Bus?? Oh yea! Reply with quote
Aren't we all. In the meantime we could have one of those refueling planes come down and fill our tanks as we roll down the road.
Balidas
Balidas is offline
PostPosted: Thu Jul 17, 2025 5:27 pm    Post subject: Re: Tesla Tech? In a VW Bus?? Oh yea! Reply with quote
It will be a stampede.
Balidas
Balidas is offline
PostPosted: Thu Jul 17, 2025 6:11 pm    Post subject: Re: Tesla Tech? In a VW Bus?? Oh yea! Reply with quote
This end piece here, whatever it's called needs to go,
I don't see any way to mate this to the brake pedal pushrod. Upon close inspection this piece looks like it can be screwed off so I put a couple wrenches on it and spun it around, having to force it a bit.
Afterwards I watched a video and the guy did the same thing I did on his iboost except, his piece didn't screw off either but it snapped off. So, that is how that is done.
At this point the only idea I have to connect the iboost rod to the brake pedal pushrod is to machine a coupling, one end is threaded to the pushrod and the other slips onto the iboost rod.
Balidas
Balidas is offline
PostPosted: Fri Jul 18, 2025 7:19 pm    Post subject: Re: Tesla Tech? In a VW Bus?? Oh yea! Reply with quote
Now for the electrics. The gen 2 iboost is only a three wire hookup. A 12 gauge constant hot hooked directly to the battery on a 40 amp fuse, a 12 gauge ground and a switched hot on a 5 amp fuse.
All this connected to the ecm through the big connector.
Also connected to the ecm through the big connector are 4 small gauge wires, 22-20 from the pedal travel sensor...
with this connector...
If someone decides to do this and you source your iboost from a parts car, grab that harness. More then likely the constant power wire will be yellow and you will have to splice in enough length to reach the battery and maybe splice enough for the 5 amp switched.
If like me you get the connectors with pigtails or no connectors at all, you can buy a ready made harness like this...
From these guys... https://www.retrofitinnovations.com/category/parts
The power wire on this harness is 18 feet long. That should reach the battery but don't forget you'll need a fuse. So if necessary, that can be your splice point.
Instead of a fuse, I'm thinking to use this...
from here...
https://www.amazon.com/RED-WOLF-Inverter-Trolling-...iewsAnchor
Balidas
Balidas is offline
PostPosted: Fri Jul 18, 2025 7:46 pm    Post subject: Re: Tesla Tech? In a VW Bus?? Oh yea! Reply with quote
If you get a stock harness or connectors with pigtails, there are 5 small wires out of the big connector you can eliminate, we don't use them.
If you have no connectors and don't mind building a harness, you can get this kit...
https://tulayswirewerks.com/product/bosch-ibooster-gen-2-connector-kit/
Altho I am not too happy with this kit. If this picture is correct then I see some parts missing that I have with my originals.
If like me, you're not a big fan of splicing, especially in this situation, then depin and start new. In either case, here is a pinout...
I pulled this from another forum because somebody added those lines showing the corresponding pin locations for each connector. Also you can see which wires can be eliminated from the big connector.
Balidas
Balidas is offline
PostPosted: Fri Jul 18, 2025 8:22 pm    Post subject: Re: Tesla Tech? In a VW Bus?? Oh yea! Reply with quote
Now, if like me, you get frikken frustrated because you can't figure out how to disconnect the big connector from the ecu and you're about to pull out the BFH, step back, take a few deep breathes, relax and watch this video...
https://www.youtube.com/watch?v=pakPMejDRzY&t=51s
This will help tremendously.
In building a wire harness, I've read 14 gauge wire could be used for the power and ground but personally I wouldn't do that and as a rule Tesla uses 12 gauge.
Recently I watched a video where the guy was building a harness for his gen1 iboost. For that he had to add an extra 14 gauge that went somewhere or other, but what caught my attention, he used 10 gauge for the power and ground so I decided I will do that as well.
For the four wires to the pedal sensor and I think the 5 amp switched, 22-20 gauge is recommended but I'm using 18 gauge.
Matter of fact I ordered GXL wire from Wirebarn. I just learned about GXL wire and I'm curious about it.
Balidas
Balidas is offline
PostPosted: Tue Jul 22, 2025 6:28 pm    Post subject: Re: Tesla Tech? In a VW Bus?? Oh yea! Reply with quote
So...I done did it. I went from this...
to this...
to this...
Balidas
Balidas is offline
PostPosted: Tue Jul 22, 2025 6:38 pm    Post subject: Re: Tesla Tech? In a VW Bus?? Oh yea! Reply with quote
Initially I put a couple of wrenches to spin the bracket to snap it off. It didn't snap. Then I got my angle grinder, put the disc between the forks and used the edge of the disc to grind the head flush with the bracket. Then used a screwdriver to pry the bracket off leaving me with a small umm..."protuberance".
The grinder quickly took care of that to give me a smooth, flat surface, which is what is needed. Then used a file to clean up any rough edges.
Balidas
Balidas is offline
PostPosted: Tue Jul 22, 2025 6:51 pm    Post subject: Re: Tesla Tech? In a VW Bus?? Oh yea! Reply with quote
Oh yea, got my wire in from Wirebarn...
Shipping was very fast, 2-3 days. Since the original power wire was yellow, I stayed with that colour. The white is for the pedal sensor. I'll cut the wire to length and use different colour shrink wrap to identify each one.
The 16 ga green is for the 5 amp switched.
Also got some Tesla tape for the harness...
This is a 5 roll pack I got from Amazon.
Now I'm just waiting for other items to arrive.
Balidas
Balidas is offline
PostPosted: Wed Jul 23, 2025 2:42 pm    Post subject: Re: Tesla Tech? In a VW Bus?? Oh yea! Reply with quote
Because of this post;
I went in search of a weather resistant/ water proof brake light switch. And because of this post;
lil-jinx wrote:
a L bracket and a hose clamp instead of welding, would be adjustable
This had eventually caught my eye;
It's a rear brake light switch for a motorcycle and it had just come in today. The switch feels very well made, quite solid and I believe could fit the bill.
Balidas
Balidas is offline
PostPosted: Thu Jul 24, 2025 6:36 pm    Post subject: Re: Tesla Tech? In a VW Bus?? Oh yea! Reply with quote
I need to make a correction, the mounting bolt pattern on the iboost is actually 60mm x 80mm.
I also forgot to mention the bore size for the iboost mc is 26mm, whereas the bore on the stock Bus mc is 23.81mm {15/16ths}.
And, wherever someone gets their iboost from, make sure you get the nuts for the mounting studs. I never got them for mine and now I have to go searching.
Balidas
Balidas is offline
PostPosted: Sat Aug 02, 2025 10:01 am    Post subject: Re: Tesla Tech? In a VW Bus?? Oh yea! Reply with quote
I found these easy enough. Easier then I thought at my local O'Reillys.
I carried my iboost cradled in my arm like a baby I didn't want to drop on its head to make sure I got the right size nuts.
Balidas
Balidas is offline
PostPosted: Sat Aug 02, 2025 10:09 am    Post subject: Re: Tesla Tech? In a VW Bus?? Oh yea! Reply with quote
I also got the circuit breaker in;
This is a nice little unit. Feels nice and sturdy. I like it. It came with these copper lugs;
The barrels tho are too big for 10-12 gauge wire. These are for 6 gauge so I put them aside for later and got a bunch of these coming in;
I like this open barrel style because for one, they are all brass and 2, the top part of the barrel crimps on the bare wire while the bottom part crimps onto the insulation. Which gives it a stronger hold. It's like having that Kung Fu grip.
Page 2 of 3
