Everpress Samba Member
Joined: February 14, 2006 Posts: 415 Location: Augusta GA
Posted: Fri Jul 18, 2025 1:18 pm Post subject: Re: The Stupid Question Thread |
KentABQ wrote: |
The Samba also has all the wiring diagrams in the "Technical" section above. |
Thanks; I always forget that. My son tore apart my Bentley manual with the intention of laminating and hole punching the whole thing... That was a year or so ago... Not pointing fingers but a lot of pages disappeared during this "project". I have a new one on order.
Would the turn signal housing be a point of failure for the entire passenger side having no lights (passenger side headlight works on normal - turn the brights on, and it fails though)? _________________ ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
1969 Bay Camper - "Lost 'Cause Mk.I"
1904 DP
EMPI 34 PICT 3
2000 MAGNASPARK II Ignition/Distributor
Refurb, not resto (I’m not made of restoration money!)
It's not a perfect loaf, but it's my loaf. |
Posted: Fri Jul 18, 2025 8:23 pm Post subject: Re: The Stupid Question Thread |
Everpress wrote: |
Wildthings wrote: |
The grounds near the battery can be a mess, not sure what your vintage bus has exactly though. |
I get that. I removed the screw holding multiple grounds on the passenger side engine compartment and wire-brushed the point of contact on the bus as well as the ends of the ground wires. I forgot to mention that.
I need to find my wiring diagram, honestly, and put it to work.
It seems the positive wires on the rear pass. side share power with the license plate light (which does work?) which is why I started focusing on the ground wires. |
Scraping the corrosion off the inside of the sockets for the bulbs may help as may cleaning the bases of the bulbs themselves. I have been applying a thin layer of dielectric grease to such sockets and bulb bases for 20+ years at point and have greatly reduced the maintenance require to keep the lights functioning. |
Posted: Sun Jul 20, 2025 10:39 am Post subject: Re: The Stupid Question Thread |
Wildthings wrote: |
No real corrosion to speak of. Probably because this was suggested a year or so ago to get the tail lights/brake lights working. And yep, it worked then, but the magic of it working twice isn't there.
If my turn signal assembly is messed up, would this affect the entire passenger side? I ask because:
1) Everything on the driver's side works now (except backup lights - which I can fool with later).
2) Sometimes when I try to use my turn signal, the horn honks
3) There are clicks (light a blinker relay) when using the left signal, but not the right.
I think I explored the easier stuff to diagnose thanks to you fine folks. If it is the turn signal assembly, I'll be ripping that off (gently, of course) and working for a bit at the kitchen table to clean and reassemble instead of the 100 degree Georgia heat. _________________ ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
1904 DP
EMPI 34 PICT 3
Posted: Sun Jul 20, 2025 1:55 pm Post subject: Re: The Stupid Question Thread |
Everpress wrote: |
Wildthings wrote: |
No real corrosion to speak of. Probably because this was suggested a year or so ago to get the tail lights/brake lights working. And yep, it worked then, but the magic of it working twice isn't there. |
If you are sure you have a good ground you need to work either forward or backwards on the 12+ side to see where in the circuit the power disappears. Fuses, switches, and connectors are the most likely spots to have problems. |
70bus  Samba Member
Posted: Wed Jul 23, 2025 12:40 am Post subject: Re: The Stupid Question Thread |
I am making interior panels for my 70, and haven’t found some info in the forums yet: I don’t have some of the original panels, but I traced the locations of the mounting holes in the frame. What I need to know is how much to offset the holes in the panel, and whether they are all offset the same direction (I.e., “panel holes are all drilled 1/4” below the holes in the frame.” _________________ Craig K
70 Neunsitzer
65 Pritschenwagen
Raul the 65 singlecab
Karl the 70 nine-seater |
W1K1 Samba Member
Joined: March 04, 2004 Posts: 5303 Location: Southern AB
Posted: Wed Jul 23, 2025 5:56 am Post subject: Re: The Stupid Question Thread |
70bus wrote: |
I am making interior panels for my 70, and haven’t found some info in the forums yet: I don’t have some of the original panels, but I traced the locations of the mounting holes in the frame. What I need to know is how much to offset the holes in the panel, and whether they are all offset the same direction (I.e., “panel holes are all drilled 1/4” below the holes in the frame.” |
as an alternative: i tried the WW reproduction clips on mine and gave up, they never seemed to stay stuck. I ordered the modern push pin type for my new panels off amazon
_________________ 1973 super 2110cc
1965 squareback 1500E-sold
1971 bay window westy- EJ2.5 subi swap |
70bus  Samba Member
Posted: Wed Jul 23, 2025 8:46 am Post subject: Re: The Stupid Question Thread |
Thanks; while those look great in later buses, I have a Deluxe with light/dark grey panels. I'll look for some that are a close color match, though. _________________ Craig K
70 Neunsitzer
65 Pritschenwagen
70bus  Samba Member
Posted: Wed Jul 23, 2025 7:33 pm Post subject: Re: The Stupid Question Thread |
Bumping this a bit - still didn't find any real advice on hole offsets for the clips. And I measured both the space in the bus and the (slightly shrunken) vinyl cover to the big panel on driver's side... double-checking that it is roughly 48" x 30" or did my vinyl REALLY shrink? _________________ Craig K
70 Neunsitzer
65 Pritschenwagen
busdaddy Samba Member
Joined: February 12, 2004 Posts: 52847 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Wed Jul 23, 2025 8:19 pm Post subject: Re: The Stupid Question Thread |
You really need an old panel from that year to trace, many of the panels changed around 70 and the offset and spacing for the clip holes changed with them. The vinyl sometimes shrinks if it's gotten loose, or the panel could be a different size if it's for the sliding door. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
70bus  Samba Member
Posted: Wed Jul 23, 2025 8:36 pm Post subject: Re: The Stupid Question Thread |
That’s my problem - the original panel fell apart, and I haven’t found another to trace. I’ll try local VW shop tomorrow and see if they’ll let me trace one … if they have one! They had some nice panels last time I looked, but wrong colors and unknown years. Don’t really want to buy nice one to strip and glue my old vinyl to. Same for the sliding door panel.
I’ll happily pay for a good, correct one, of course. Just have some Masonite laying around and the old coverings. Bought new kick pieces and hatch panels from Clara, but she hasn’t branched into the multitude of bay side panels yet. _________________ Craig K
70 Neunsitzer
65 Pritschenwagen
70bus  Samba Member
Posted: Wed Jul 30, 2025 11:04 pm Post subject: Re: The Stupid Question Thread |
Ok, theoffset for most panel clips is 15 to 17mm from the center of the hole; the bulk seem to be offset 45 degrees and the rest straight up/down or horizontal. My long cargo panel had 4 tha were horizontally offset, and 2 vertical upwards… but I was using a 75 panel for a template and I have a 70. There were holes in body not drilled in later-bay panel. . It may vary by year cluster.
I’m continuing the rest of this repair over in Karl’s thread but wanted to post an answer to my original Q for the next person attempting this. _________________ Craig K
70 Neunsitzer
65 Pritschenwagen
70bus  Samba Member
Posted: Wed Jul 30, 2025 11:06 pm Post subject: Re: The Stupid Question Thread |
Next stupid question: why are some fog light knobs GREEN and some ORANGE. Country rules, year, or plain old whim? _________________ Craig K
70 Neunsitzer
65 Pritschenwagen
KTPhil  Samba Member
Joined: April 06, 2006 Posts: 35947 Location: Conejo Valley, CA
Posted: Thu Jul 31, 2025 8:27 am Post subject: Re: The Stupid Question Thread |
70bus wrote: |
Next stupid question: why are some fog light knobs GREEN and some ORANGE. Country rules, year, or plain old whim? |
Most I have seen are orange, at least on German cars.
I had a green one, but I had cheated and used a green defroster switch, and buffed off the defrost symbol. For the single position (on/off) switch, it is identical to the defogger switch; only the screwed-in lamp lens is different. The 2 position (front/front+rear/off) switches are not the same, obviously. _________________ Current Fleet:
- '71 Fastback
- '69 Westfalia
Retired:
- '67 Beetle
- '65 Beetle (x2)
- '65 Bus
- '71 Squareback |
jasoncvw Samba Member
Joined: August 27, 2024 Posts: 7 Location: central Ohio
Posted: Tue Aug 05, 2025 5:25 am Post subject: Re: The Stupid Question Thread |
We recently brought home a 76 Westy. I was digging in yesterday and noticed a reservoir on top of the engine. The engine in the pic is not ours, it's still in the Bus and running well. What is the reservoir?
Thanks!
Posted: Tue Aug 05, 2025 7:49 am Post subject: Re: The Stupid Question Thread |
It's an oil separator, it strains the juicy stuff out of the crankcase fumes, the fumes go to the intake manifold to be reburnt, the oily moisture falls back into the engine. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Tue Aug 05, 2025 5:14 pm Post subject: Re: The Stupid Question Thread |
busdaddy wrote: |
It's an oil separator, it strains the juicy stuff out of the crankcase fumes, the fumes go to the intake manifold to be reburnt, the oily moisture falls back into the engine. |
Right on, thank you. Is there any maintenance to be done for this? |
Posted: Tue Aug 05, 2025 5:50 pm Post subject: Re: The Stupid Question Thread |
jasoncvw wrote: |
busdaddy wrote: |
Maybe clean it out with carb cleaner, and test it to confirm the diaphragm in the valve isn't broken: https://www.thesamba.com/vw/forum/search.php?searc..._chars=200 _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Tue Aug 05, 2025 6:20 pm Post subject: Re: The Stupid Question Thread |
busdaddy wrote: |
jasoncvw wrote: |
busdaddy wrote: |
Maybe clean it out with carb cleaner, and test it to confirm the diaphragm in the valve isn't broken: https://www.thesamba.com/vw/forum/search.php?searc..._chars=200 |
Thank you! |
dodger tom  Samba Member
Joined: March 25, 2013 Posts: 1923 Location: Central Coast, CA, but we're all still Ukrainian and Californian
Kwoggy Samba Member
Joined: October 11, 2012 Posts: 44 Location: Ventura County
Posted: Thu Aug 07, 2025 9:26 am Post subject: Re: The Stupid Question Thread |
1970 walk through Bus. Under the walk thru mat, did the factory install this small board?
Under the board there appears to be four holes. Two have screws coming up through the floor, two appear to be empty. Looking for the factory set up under this mat.
_________________ 1970 Bus |
