70bus  Samba Member
Posted: Thu Jul 24, 2025 3:46 pm Post subject: Re: What did you do for your Bus today? |
Or, think of it as shin-guards for the parts under your bus! Will come in handy when you take the deluxe on the Shasta run... _________________ Craig K
70 Neunsitzer
65 Pritschenwagen
Raul the 65 singlecab
Karl the 70 nine-seater |
BarryL  Samba Member
Joined: November 01, 2004 Posts: 15253 Location: Casa de Oro, California
Posted: Thu Jul 24, 2025 6:31 pm Post subject: Re: What did you do for your Bus today? |
I have a liitle pink Teddy Bear that squeezes over it as well as a pink tennis ball. |
Who.Me? Samba Member
Joined: July 14, 2014 Posts: 2542 Location: UK (South)
Posted: Fri Jul 25, 2025 1:46 am Post subject: Re: What did you do for your Bus today? |
BarryL wrote: |
I have a liitle pink Teddy Bear that squeezes over it |
That'll traumatise some kiddies. _________________ Andy
Looking for info on my truck's history. Are you from Campbell California or nearby. Do you recognise it? ... http://www.thesamba.com/vw/forum/viewtopic.php?t=636786 |
BarryL  Samba Member
Posted: Fri Jul 25, 2025 6:07 pm Post subject: Re: What did you do for your Bus today? |
That's funny because more than once has a child been hypnotized by it. One toddler pulled it off and got grease on his hand. I had to use some Coleman Fuel to get it off for his mother.
Oldboxman Samba Member
Joined: May 16, 2018 Posts: 9 Location: Scottsdale AZ
Posted: Sat Jul 26, 2025 11:16 am Post subject: Re: What did you do for your Bus today? |
Curious…big nut, small nut transmission
My axle nut measures 38 mm.
Not 36 or 42 mm.
Is the 36 mm considered a small nut?
Cheers! |
BarryL  Samba Member
Posted: Sat Jul 26, 2025 6:06 pm Post subject: Re: What did you do for your Bus today? |
Oldboxman wrote: |
Is the 36 mm considered a small nut? |
Yes 36mm = Small Nut. |
BarryL  Samba Member
Posted: Sat Jul 26, 2025 6:09 pm Post subject: Re: What did you do for your Bus today? |
My '65 Standard got new tires. Off with the old. Got over 70,000 miles out of the old Michelin Agilis.
The tires are Yokohama Y365s 185R14.
On with the new.
Posted: Mon Jul 28, 2025 8:30 am Post subject: Re: What did you do for your Bus today? |
Broke it.
Haven't had a chance to run it for a few weeks, so took it out for a decent run. It was running great, until it wasn't.
started cutting out when I slowed to idle speeds, and then the starter took a dump. Thought it might be the battery or alternator, but my Mrs drove over with a spare battery and multimeter. Both batteries are at 13.5V. it just barely cranks a fraction then gives up.
Currently waiting for recovery.
Knew I should have stayed in bed this morning.  _________________ Andy
AC Mack Samba Member
Joined: October 11, 2007 Posts: 422 Location: Redwood Highway Caught in the Devils Bargain
Posted: Wed Jul 30, 2025 11:30 pm Post subject: Re: What did you do for your Bus today? |
Much needed complete brake system overhaul.
Trinity Co USA _________________ 1959 Model M1: 118
1964 Model 265
1965 Model 251 Deluxe walk thru
1966 Westfalia so42 Schiebedach fabrik 4864
1967 Model 231 EZ Kamper # 1940
1978 Westfalia P 31 / 1987 Westfalia Wolfram Grau
Split Bus Club / Lost Coast Bays / North Coast Vans
Long may that Split Bus Run!
Always and Everywhere Volkswagen |
thom Samba Member
Joined: October 12, 2000 Posts: 6189 Location: Sacramento
Posted: Thu Jul 31, 2025 5:50 am Post subject: Re: What did you do for your Bus today? |
Last weekend I had to do the rear brakes; one of the wheel cylinders was leaking. During the course of the cleanup, I discovered that one of the shoes was delaminating, too. Luckily I still have a small inventory of this stuff on-hand. I originally installed these in 2007.
_________________ -Thom
1956 Single Cab
1957 Porsche 356A Sunroof
1957 23-Window Deluxe
1963 Unimog 404
1965 E-Type |
thom Samba Member
Posted: Thu Jul 31, 2025 5:54 am Post subject: Re: What did you do for your Bus today? |
Sometimes it's not what you do for your bus, but what you have to pay someone else to do for it. I dropped in to check on the interior work, and they're almost done with the headliner. There's a couple of small issues that will need to be rectified (like the B pillar dent), but at this point I just want to get this thing done. 99% of the general populace wouldn't know better, and 80% of the bus people probably wouldn't either. There's probably mistakes in it that I don't know about.
1956 Single Cab
1963 Unimog 404
1965 E-Type |
EasyNow Samba Member
Posted: Thu Jul 31, 2025 6:24 am Post subject: Re: What did you do for your Bus today? |
Still gorgeous Thom! What is the fabric used for the interior headliner? |
thom Samba Member
Posted: Thu Jul 31, 2025 8:35 am Post subject: Re: What did you do for your Bus today? |
EasyNow wrote: |
It's been called several things, like "mohair" or "nap cloth"
https://www.thesamba.com/vw/classifieds/detail.php?id=2733689 _________________ -Thom
1956 Single Cab
1963 Unimog 404
1965 E-Type |
thom Samba Member
Posted: Thu Jul 31, 2025 5:19 pm Post subject: Re: What did you do for your Bus today? |
I recently bought a Sunbrella tilt cover, because the canvas ones are unavailable, at least here in the States. One of the issues with the lighter material is that it wants to flap when you drive with the rear section rolled up. My hackaround was to install some Pinzgauer tie-downs, which are the exact same dimensions as the OG VW tie downs, onto the rear hoop, so I can strap down the sides. I've pop-riveted them for now, since this is a proof-of-concept; if it works out I'll braze them on.
1956 Single Cab
1963 Unimog 404
1965 E-Type |
von_hansel  Samba Member
Joined: June 12, 2006 Posts: 815 Location: Inland Empire
Posted: Thu Jul 31, 2025 9:31 pm Post subject: Re: What did you do for your Bus today? |
AC Mack wrote: |
Trinity Co USA |
The Shoe! _________________
Mugatu wrote: |
von_hansel is still so hot right now |
thom Samba Member
Posted: Fri Aug 01, 2025 2:00 pm Post subject: Re: What did you do for your Bus today? |
I got a call from the interior shop "Hey, the vinyl piece for that gray metal section isn't long enough. Also, where does the black stuff go?"
1956 Single Cab
1963 Unimog 404
1965 E-Type |
cdennisg Samba Member
Joined: November 02, 2004 Posts: 20842 Location: Sandpoint, ID
Posted: Fri Aug 01, 2025 2:12 pm Post subject: Re: What did you do for your Bus today? |
oops. _________________ Confusious say it takes it takes two wipes to know you need three, but it takes three wipes to know it only needed two. |
thom Samba Member
Posted: Fri Aug 01, 2025 2:42 pm Post subject: Re: What did you do for your Bus today? |
To someone who doesn't know buses, this looks nice. But I'd given them tons of reference pix and called every other day or dropped in to see if they had questions... _________________ -Thom
1956 Single Cab
1963 Unimog 404
1965 E-Type |
DanM Samba Member
Joined: June 07, 2002 Posts: 1376 Location: Falls Church, VA
Posted: Fri Aug 01, 2025 3:13 pm Post subject: Re: What did you do for your Bus today? |
thom wrote: |
I got a call from the interior shop ...
Check the long panel screws  |
BarryL  Samba Member
Posted: Fri Aug 01, 2025 6:15 pm Post subject: Re: What did you do for your Bus today? |
thom wrote: |
Mine doesn't have those indents but how is yours supposed to be? What is the fix? |
