180mm flywheel replacement
mlapp007
mlapp007 is offline
PostPosted: Sat Oct 25, 2025 7:17 pm    Post subject: 180mm flywheel replacement Reply with quote
I have a '65 with the 1200 motor.
Previous owners had converted, at least some parts to 12v. When the starter went out, I replaced with a 12v starter, but (as some of you will point out) did not realize that the 109-tooth/180mm flywheel is not made for the 12v starter.
Long-short is that my 180mm flywheel has been worn by the 12v starter. Pictures below.
I now need a new flywheel. I would like to stick with the 180mm and get a new 6v starter.
Does this all make sense? Can someone point me to where I might get a new 180mm/109 tooth flywheel?
klroger
klroger is offline
PostPosted: Sun Oct 26, 2025 7:36 am    Post subject: Re: 180mm flywheel replacement Reply with quote
A quick search in the classified turned up this https://www.thesamba.com/vw/classifieds/detail.php?id=2601634
It's just 1 example. If you search, you may find 1 closer to your location or it looks like MOFOCO has some https://www.mofoco.com/category/Flywheels/c131
I Didn't know what to do, So I Didn't do anything!!!!
McFunzeepants
McFunzeepants is offline
PostPosted: Sun Oct 26, 2025 8:14 am    Post subject: Re: 180mm flywheel replacement Reply with quote
The ring gear on your flywheel has already been replaced.
You can get a replacement from Gene Berg in either 6 or 12v.
Heat up the flywheel in the oven and you can knock out the old ring and install a new one of your choice.
https://www.geneberg.com/
MrGoodtunes
MrGoodtunes is offline
PostPosted: Sun Oct 26, 2025 10:25 am    Post subject: Re: 180mm flywheel replacement Reply with quote
@mlapp007 - Depending on your transmission, choose the correct starter shaft end support bushing. Look here:
https://www.thesamba.com/vw/forum/album_page.php?pic_id=323827
If your electrical system is 12v, consider using a 12v solenoid on 6v starter. Look here:
https://www.thesamba.com/vw/forum/viewtopic.php?p=9190175&highlight=#9190175
Eric&Barb
Eric&Barb is offline
PostPosted: Sun Oct 26, 2025 10:35 am    Post subject: Re: 180mm flywheel replacement Reply with quote
Suggest upgrading to 200mm 6 volt flywheel. Clutch disc will last longer, for less maintenance time spent.
Then 6 volt starter with 12 volt solenoid if you are running 12 volt battery.
Research is a must before just stuffing parts into the car.
In Stereo, Where Available!
daveblank
daveblank is offline
PostPosted: Sun Oct 26, 2025 11:26 am    Post subject: Re: 180mm flywheel replacement Reply with quote
Get another 6v flywheel. Then you can get a 12v starter designed for a 6v flywheel
@ CB Performance https://www.cbperformance.com/product-p/2145.htm?s...9JI2uxqTxF
IMI is a little less expensive https://www.kustom1warehouse.net/Imi_high_torque_starter_for_VW_Volkswagen_p/hitorquestarter.htm
Since you're in the DFW metroplex, call Will @ Cal-Look Performance in Sanger. He can definitely fix you up.
Wayne S. Johnson
Wayne S. Johnson is offline
PostPosted: Sun Nov 02, 2025 2:40 pm    Post subject: Re: 180mm flywheel replacement Reply with quote
Hybrid 12V Starter on 6V Flywheel. In stock.
HYBRID STARTER 6/12 https://www.thesamba.com/vw/classifieds/search.php?username=Wayne+S.+Johnson
Additional products with Bluetooth http://www.thesamba.com/vw/classifieds/detail.php?id=2097231
