Pat Downs Shockwave
qweedqwag
qweedqwag is offline
PostPosted: Sat Nov 01, 2025 4:04 pm    Post subject: Pat Downs Shockwave Reply with quote
Hey All,
All I can say is wow, the difference this distributor made on my car, so much adjustment with the timing plugs adding or taking away timing, springs that bring the timing in slower or faster, car is running better without the 009. The billet coil mount is awesome and plug wire included work like magic for 240.00 . Anyone on the fence do it. Thanks to everyone here for their input on this trick setup. Pat thanks for answering my question on the coil.
Texas Mike.
daveblank
daveblank is offline
PostPosted: Sun Nov 02, 2025 5:39 am    Post subject: Re: Pat Downs Shockwave Reply with quote
qweedqwag wrote:
Hey All,
Texas Mike.
Mine is just sitting on a shelf waiting for my engine to get finished.
Victor H
Victor H is online now
PostPosted: Sun Nov 02, 2025 6:21 am    Post subject: Re: Pat Downs Shockwave Reply with quote
Mine's in and running. Agree it's a good system. My car liked the lightest advance spring best (quickest advance). Only have about 600 miles on mine so far but no issues whatsoever.
thefladge
thefladge is offline
PostPosted: Sun Nov 02, 2025 8:58 pm    Post subject: Re: Pat Downs Shockwave Reply with quote
I've been considering one of these distributors on my 2110cc engine. I'm currently running one of the SVDA distributors aircooled.net used to sell about 10 or 15 years ago.
1957 Vintage Baja Bug.
2110cc engine, 40 IDF Webers on Gene Berg manifolds, Engle 110 cam, Bugpack 40×35.5 Street Pro Heads, W8CC plugs, 12.5 pound Flywheel, Kennedy 1700 pound pressure plate.
jeffrey8164
jeffrey8164 is offline
PostPosted: Mon Nov 03, 2025 10:51 am    Post subject: Re: Pat Downs Shockwave Reply with quote
For what my opinion is worth:
Pat won’t sell crap.
Volkswagen!
(Compression 8.7:1)
calvinater
calvinater is offline
PostPosted: Mon Nov 03, 2025 1:50 pm    Post subject: Re: Pat Downs Shockwave Reply with quote
How much does the Shock wave differ from the Magnaspark ?
"Albatross"!
sled
sled is offline
PostPosted: Mon Nov 03, 2025 3:17 pm    Post subject: Re: Pat Downs Shockwave Reply with quote
https://www.thesamba.com/vw/forum/viewtopic.php?t=782669&highlight=shockwave
drive your split.
Brian_e Premium Member
Brian_e is offline
PostPosted: Mon Nov 03, 2025 3:19 pm    Post subject: Re: Pat Downs Shockwave Reply with quote
They have different ignition modules.
The clamp on the shockwave is much more universal for different aluminum cases.
The boots on the plug wires are usable in the Shockwave kit. The CB boots are terrible.
The shockwave coil uses the better HEI style Male coil post.
Very similar caps. The shockwave cap looks to be a bit cheaper made.
Same rotor.
Near identical aluminum base.
Same tuning kit in the yellow bag.
Same little generic steel brackets to hold the coil.
I prefer the billet CB coil mount. Pat offers a billet mount for his also.
So more or less the lazier and stupider you want to be, the nicer quality parts you need to buy.
-Modok
Narrowed beams, Drop adjustable spring plates, Bus disk brake and IRS kits.
www.type-emotorsports.com
https://type-emotorsports.com/collections/engine-parts
chrisflstf
chrisflstf is offline
PostPosted: Tue Nov 04, 2025 8:11 am    Post subject: Re: Pat Downs Shockwave Reply with quote
I like the shockwave and Magnspark but dont own one.
The only down side I see is getting replacement modules or rotors. If they were available as a similar GM type part that you could cross reference, that would be good. Maybe they are?
I generally dont like buying from a single source manufacturer, if possible
Also, I havent found anybody that sells just the distributors, only kits
slayer61
slayer61 is offline
PostPosted: Tue Nov 04, 2025 8:50 am    Post subject: Re: Pat Downs Shockwave Reply with quote
How 'bout NAPA
Dist. Cap MSD 8434 Napa echlin fa137
Rotor MSD 8470 Napa echlin rr1670
Cusser wrote:
... Most folks are idiots when it deals with electrical !!!
67rustavenger wrote:
3/4 race cam? What's missing, one of the lobes? Shocked
Paul
'68 Manx clone... Sears??
RLR/Strange brakes
2276 built on AS21 case
W-125 w/ GB 1.25:1 rockers
Mahle forged pistons
CB 4340 crank
CB H beam rods
deep sump
45 DCOE
Garrett turbo (pending)
Tim's stage II turbo heads (pending)
MSD Box and distributor
Car Craft turbo header
View user's profile Send private message AIM Address Yahoo Messenger MSN Messenger Facebook Twitter Instagram Gallery Classifieds Feedback
