volkswagen_bug Samba Member
Joined: November 04, 2008 Posts: 766 Location: Gulfport, MS
Posted: Thu Nov 27, 2025 10:16 am Post subject: Rear Brake Line |
Good afternoon. I purchased a nearly all-original 1958 Bug a few days ago. My intention is to maintain it for a few years and then do a full pan-off restoration with my son. As with all vintage vehicles, a few things need attention. I noticed a pool of brake fluid under the vehicle, and the driver’s carpet is wet near the firewall. When pressing the brake pedal, I see small bubbles coming from the grommet between the firewall and the brake line. I’m assuming the line somehow has a pinhole leak.
My question is: is this common, and how difficult is it to replace the entire line? _________________ 1958 Volkswagen Bug w/ 1200 Single Port |
VW_Jimbo  Samba Member
Joined: May 22, 2016 Posts: 11487 Location: Huntington Beach, CA
Posted: Thu Nov 27, 2025 10:42 am Post subject: Re: Rear Brake Line |
Yep! That is a brake fluid leak, most likely from the master cylinder. If you remove the dust boot at the rear of the unit and push the pedal, you might be able to see it leak. If not find it quickly, as brake fluid will strip the paint off of the steel, leaving the steel exposed to moisture.
Brake fluid is hygroscopic. So, to clean it and neutralize the damages it can do, you flood it with water. Down side is flash rust will find a way in after that. After it dries up. Apply some Ospho with a squirt bottle, allow it some time to do its thing, then rinse with water. Allow that to fully dry, then hit it with an etching primer. Followed by paint.
Be sure to fix the leak during those down cycles in the brake fluid mitigation!
Also, check the wheel cylinders and the brake rubber hoses. They are probably all on the same wear point.
If it does end up being a hard line. The one running down the outside of the tunnel. The job is not difficult. You just need to know how to bend brake lines without kinking them. Watch some YouTube videos. Remove the interior on the drivers side (seat, floor mats, carpet) then get to the fun! A 11mm or 7/16” flare nut wrench is your best friend along with a 17mm open end wrench for support! _________________ Jimbo
| TDCTDI wrote: |
| Basically, a whole bunch of fuckery to achieve a look. |
| 67rustavenger wrote: |
GFY's Xevin and VW_Jimbo!  |
Posted: Thu Nov 27, 2025 10:51 am Post subject: Re: Rear Brake Line |
Thanks for the reply, VM_Jimbo. I didn’t consider the master cylinder being the culprit because I saw small air bubbles between the rear brake line and the rubber grommet at the firewall. I’ll continue to dig further before purchasing any parts. _________________ 1958 Volkswagen Bug w/ 1200 Single Port |
Cusser Samba Member
Joined: October 02, 2006 Posts: 33541 Location: Hot Arizona
Posted: Thu Nov 27, 2025 11:11 am Post subject: Re: Rear Brake Line |
The grommet around the brake line broke apart, and I cannot see anything wrong with the line. In between, though, I can see fluid and it’s wet, so I’m assuming it’s the master cylinder. Is it worth rebuilding, or should I just replace it? _________________ 1958 Volkswagen Bug w/ 1200 Single Port |
daveblank Samba Member
Joined: November 07, 2024 Posts: 285 Location: Dallas, TX
Posted: Thu Nov 27, 2025 11:22 am Post subject: Re: Rear Brake Line |
| volkswagen_bug wrote: |
| The grommet around the brake line broke apart, and I cannot see anything wrong with the line. In between, though, I can see fluid and it’s wet, so I’m assuming it’s the master cylinder. Is it worth rebuilding, or should I just replace it? |
I would replace it. Now would be the perfect time to convert it to a dual circuit master cylinder. |
Posted: Thu Nov 27, 2025 11:30 am Post subject: Re: Rear Brake Line |
I'm trying to keep it as stock as possible. Is there much benefit to converting it to a dual circuit master cylinder. _________________ 1958 Volkswagen Bug w/ 1200 Single Port |
OldSchoolVW's  Samba Member
Joined: July 03, 2020 Posts: 1610 Location: San Diego
Posted: Thu Nov 27, 2025 1:59 pm Post subject: Re: Rear Brake Line |
[quote=]"volkswagen_bug" Is there much benefit to converting it to a dual circuit master cylinder.[/quote]
Plenty. With a single circuit, a failure anywhere in the brake lines or wheel cylinders results in a failure of the brake system. With a dual circuit you would only experience a partial loss of braking ability. Do as daveblank suggests. You will be glad you did. _________________ Tom
"Following distance is proportional to IQ."
"It's okay to think."
"If you don't do it this year, you'll be one year older when you do." Warren Miller
'63 Beetle Sedan
'69 Beetle Sunroof
'70 Beetle Sedan
'73 Type 3 Fastback |
Posted: Thu Nov 27, 2025 2:26 pm Post subject: Re: Rear Brake Line |
Is there a common part number used for the dual circuit master cylinder that you can share? _________________ 1958 Volkswagen Bug w/ 1200 Single Port |
Posted: Thu Nov 27, 2025 2:49 pm Post subject: Re: Rear Brake Line |
| Is there a common part number used for the dual circuit master cylinder that you can share? |
A master cylinder for a later Karmann Ghia or Beetle would work well as an upgrade for an earlier Beetle. This one from NAPA has a lifetime warranty and would be compatible with front disc brakes if you decided to do that worthwhile upgrade during a brake overhaul. I have it in my '63 bug.
https://www.napaonline.com/en/p/NMCM2110
You said you believe your bug to be all original. If you believe that to be the case for the brake hard lines, you may want to plan on replacing them ... sooner rather than later. As they say, it really doesn't matter how well it goes if it doesn't stop when you need it to.  _________________ Tom
'63 Beetle Sedan
'69 Beetle Sunroof
'70 Beetle Sedan
viiking Samba Member
Joined: May 10, 2013 Posts: 3469 Location: Sydney Australia
Posted: Thu Nov 27, 2025 2:54 pm Post subject: Re: Rear Brake Line |
It's not just the MC you need but you will also have to get/make brake lines to go from single circuit to dual circuit. _________________ 1968 1500 RHD Lotus White Beetle since birth. In the hospital for major surgery
Discharged: 1983 Vanagon, 1974 1800 Microbus,1968 Low Light,1968 Type 3 |
Posted: Thu Nov 27, 2025 3:11 pm Post subject: Re: Rear Brake Line |
Kind of why I'm nudging our OP to consider doing the brake overhaul now. I totally get the desire to drive and enjoy a recently purchased bug (the fun part of ownership) and get around to stuff like brake overhauls later on. Unless certain of what recent work was done to the bug (and that it was done properly), taking the time to tend to the mechanicals early on goes a long way toward preventing costly, unfortunate failures (brake failure, fuel line leak in engine compartment, fuel pump diaphragm leak, etc.) that can take the bloom off the rose. _________________ Tom
'63 Beetle Sedan
'69 Beetle Sunroof
'70 Beetle Sedan
Posted: Thu Nov 27, 2025 3:29 pm Post subject: Re: Rear Brake Line |
| OldSchoolVW's wrote: |
| Kind of why I'm nudging our OP to consider doing the brake overhaul now. I totally get the desire to drive and enjoy a recently purchased bug (the fun part of ownership) and get around to stuff like brake overhauls later on. Unless certain of what recent work was done to the bug (and that it was done properly), taking the time to tend to the mechanicals early on goes a long way toward preventing costly, unfortunate failures (brake failure, fuel line leak in engine compartment, fuel pump diaphragm leak, etc.) that can take the bloom off the rose. |
Agree 100%.
Not many of us would agree to an aeroplane taking off and waiting for a failure to happen before doing preventative maintenance. _________________ 1968 1500 RHD Lotus White Beetle since birth. In the hospital for major surgery
Schnitzelfuss Samba Member
Joined: September 18, 2024 Posts: 208 Location: North Alabama
Posted: Thu Nov 27, 2025 5:54 pm Post subject: Re: Rear Brake Line |
| I’m of the belief that it’s OK to keep the single circuit brake system provided you’ve ensured all system components are inspected regularly and maintained in good working order. As others have stated, for your safety and peace of mind, replace the components with moving parts, all rubber seals and lines, inspect the rest of the system using the workshop manual information, and put fresh fluid in the system. |
Posted: Fri Nov 28, 2025 5:33 am Post subject: Re: Rear Brake Line |
Thanks for all of the replies. At this time I will be keeping the single circuit brake system and saving any future upgrades for when we do the full restoration. All moving parts, rubber and seals have been ordered. _________________ 1958 Volkswagen Bug w/ 1200 Single Port |
Posted: Fri Nov 28, 2025 8:43 am Post subject: Re: Rear Brake Line |
That"s the one that I'm installing.
| viiking wrote: |
| It's not just the MC you need but you will also have to get/make brake lines to go from single circuit to dual circuit. |
I was able to reuse the rear & right front. The one for the left front was too short, NAPA has a 12in hose that I was able to bend & make work. A 10in or possibly 8in would have worked too, the original was 6. |
Posted: Fri Nov 28, 2025 8:57 am Post subject: Re: Rear Brake Line |
I've seen a master cylinder much like that one but with the reservoir mounted on top. Not sure where those are from though. _________________ 1958 Volkswagen Bug w/ 1200 Single Port |
Posted: Fri Nov 28, 2025 10:05 am Post subject: Re: Rear Brake Line |
| I've seen a master cylinder much like that one but with the reservoir mounted on top. Not sure where those are from though. |
There is a reservoir that mounts directly to the master cylinder. I don't like those because I'm old & don't want to crawl around on the ground just to check the fluid level. I'm mounting a 67 dual circuit reservoir to mine. |
Bobs67vwagen Samba Member
Joined: March 27, 2005 Posts: 1007 Location: Eastern north carolina
Posted: Fri Nov 28, 2025 12:44 pm Post subject: Re: Rear Brake Line |
I put one on my IRS pan that I am going to use on my 67. I got it form rock auto, here is a picture.
