ento  Samba Member
Joined: December 31, 2008 Posts: 246 Location: el paso tx
Posted: Wed Mar 19, 2025 4:11 am Post subject: |
| LHG wrote: |
62 TO 67 Hardware placement
So are these allen head bolts on mine correct? I thought they just got swapped out at some point
_________________ 62 type 2 So34
66 European bug, 66 euro sunroof
76 baja
76 sun bug sunroof
64,66,67,68 bug
69,70 bay
61 Ragtop bug, 61 sedan(looking for the vert)
61 RHD Ragtop Semaphore bug fakeAF
64,64 KG
74 thing
55 oval
70 ratrod
73 fastback pignose |
crofty Judas of the North
Joined: August 09, 2000 Posts: 19931 Location: Land of Whine and Phonies
Posted: Tue Apr 08, 2025 10:53 am Post subject: Re: Westy rack differences |
Anyone have a source for the wood screws for a Westy Rack? Preferable Stateside. _________________ Your Vanagon sucks, Stop waving at me.
| HamburgerBrad wrote: |
I slept on crofty's tent once. I passed out drunk from two bottles of Everett's brother's wine. |
EasyNow Samba Member
Posted: Thu Oct 23, 2025 3:59 pm Post subject: Re: Westy rack differences |
Better late than never? So I just pulled my westy rack down from the garage rafters after 40 years idle and hoping to confirm what 16 pages of posts might have told me... Best I can tell is a late 62?
Measurements:
~52.5 in across the wooden slats.
~10.5 in in height to the bottom support rail.
Only one tag.
Singular wood screw attachment.
Corner supports.
6 large 65-67 style clamps (although one had been chromed)
Looking for a little confirmation here... Am I close?
BarryL  Samba Member
Joined: November 01, 2004 Posts: 15510 Location: Casa de Oro, California
Posted: Thu Oct 23, 2025 6:27 pm Post subject: Re: Westy rack differences |
It looks like mine and mine is '62. Same measurements.
Posted: Fri Oct 24, 2025 7:53 am Post subject: Re: Westy rack differences |
| Thanks BarryL... |
Posted: Sun Nov 09, 2025 12:47 pm Post subject: Re: Westy rack differences |
Next question... Were the original wood screws flathead or oval head?
And were they zinc plated brass as well? |
campingbox  Samba Member
Joined: November 14, 2000 Posts: 10267 Location: Petaluma, CA
Posted: Tue Nov 11, 2025 7:58 am Post subject: Re: Westy rack differences |
| EasyNow wrote: |
It may vary by year, but I think all the early ones ('64 and back) are oval pan. They are steel. |
easy e Samba Member
Joined: May 28, 2008 Posts: 3942 Location: 1 hr north of Santa Barbara
Posted: Fri Nov 14, 2025 6:45 pm Post subject: Re: Westy rack differences |
| EasyNow wrote: |
I believe they were all chromed steel, slotted oval.
See the parts diagram at the bottom of this post. See item #12. Use the VW number or stated DIN specs. But keep in mind… it’s 1967 info. & may not be appropriate for ‘62.
https://www.thesamba.com/vw/forum/viewtopic.php?p=7962884#7962884 _________________ aka: Evan
“They are about as worthless as the tits on the boars that live in the woods behind their junk yard.” -Weatherly |
broozebrothers Samba Member
Joined: June 02, 2008 Posts: 306 Location: Los Angeles
Posted: Fri Nov 14, 2025 6:58 pm Post subject: Re: Westy rack differences |
| EasyNow wrote: |
The are flat head Domed steel screws |
Posted: Fri Nov 14, 2025 7:00 pm Post subject: Re: Westy rack differences |
| BarryL wrote: |
This is a Late 62 rack .. early model 62 racks were flat with 3 small Sloper bows and 61 style small ribbed clamps . |
Posted: Fri Nov 14, 2025 7:04 pm Post subject: Re: Westy rack differences |
| nathan3 wrote: |
| BarryL wrote: |
| nathan3 wrote: |
Hi all,
Anyone own a '61/early '62 rack? I need measurements of a bow.. I found a stash of early bows, but they are all different sizes.. |
What are you needing? |
I need measurements of a '61/early '62 rack bow. Non sloper so the bows should be the same size im assuming. |
I have one .. the early 62 rack uses 3 of the small Sloper rack bows . So just get a measurement of the small Sloper bow and you got it |
Posted: Fri Dec 12, 2025 8:24 am Post subject: Re: Westy rack differences |
| EasyNow wrote: |
Measurements:
Only one tag.
Corner supports.
So I think we determined that this rack is a late 62...
And now my next question: Anyone know what the three holes on each side of the end rail are for? And do these orient to the front or the rear of the bus?
BarryL  Samba Member
Posted: Fri Dec 12, 2025 6:48 pm Post subject: Re: Westy rack differences |
Those holes aren't Westfalia. Do they go all the way through the other side of the bend?
Maybe CB Antenna? |
Posted: Fri Dec 12, 2025 7:46 pm Post subject: Re: Westy rack differences |
They do not go all the way through and are just on the outside facing of both left and right ends on the same support rail. Have not seen this on any rack pics posted in this thread. A little confused here...
One last question - while I have milled the European Beechwood to .6" x 1.5”, I would like to understand how they are finished. Seen many with some type of polyurethane or marine varnish, and maybe some with oil (tung or linseed?).
So what treatment were the original Westy Racks finished with? |
BarryL  Samba Member
Posted: Sun Dec 14, 2025 11:47 pm Post subject: Re: Westy rack differences |
Whoa… I must admit that might just make complete sense. Wild!
Thanks BarryL!
Anyone have thoughs about the most original treatment for the wood slats? |
BIG_TEXAS_PETE Samba Member
Posted: Mon Dec 15, 2025 8:08 am Post subject: Re: Westy rack differences |
| Yes. They were stripped down to steel as quite a bit of rust had to be removed. But then I had access to zinc plating, so I went in that direction. |
Posted: Mon Dec 15, 2025 8:35 am Post subject: Re: Westy rack differences |
| EasyNow wrote: |
 _________________ https://www.instagram.com/big_texas_pete/ |
Posted: Tue Dec 16, 2025 8:40 am Post subject: Re: Westy rack differences |
| So anyone that can help here with what kind of finish was originally used for the beechwood slats? |
