1974 westy water tank
mighty-manx
mighty-manx is offline
PostPosted: Wed May 17, 2006 10:21 pm    Post subject: 1974 westy water tank Reply with quote
Help folks I am looking for a picture of a 1974 westy water tank mine is missing and It dosen't show it in my westy owners manual (yes I have it with the origonal VW owners manual)
I am trying to restore the system and undo all the P/O hack jobs like the entire icebox set up missing ( a picture of the stove and ice box would rock also).
thanks in advance I am replacing the canvas next weekend and want to take this thing out soon and test the 2110 torque monster engine on a real trip.
Mighty-Manx (Dan)
Birdibus
Birdibus is offline
PostPosted: Thu May 18, 2006 6:53 am    Post subject: Reply with quote
Dan~ Here are a couple of photos I have collected of the fridge/stove cabinet, which I am missing also. I will try to get you a photo of the water tank later today. What color is your bus and your upholstery?
'74 Westfalia Yosemite Yellow
'71 Bus Niagra blue and white
Karl
Karl is offline
PostPosted: Thu May 18, 2006 7:07 am    Post subject: Reply with quote
The 74/75 deluxe Westy tank looks identical to the 76-79 Westy tank EXCEPT for the location of the pump and drain holes.
On 76-79, they are on the same end as the fill pipe hole. The large end.
On 74/75, they are on the opposite end, the small end.
I just sold both of them. Should have taken pics..... pictures explain it easier.
mighty-manx
PostPosted: Thu May 18, 2006 8:22 am    Post subject: Reply with quote
Thanks guys try and keep the Pictures coming.
Birdibus my 74 is yosemity yellow with the blue/green plad looks like your avatar.
Karl do you think you could put a 76/79 in and re do the plumbing I know I can find a 76-79 the 1973 I have isn't even close
I am not shooting for a 100% period correct resto but it needs to look fairly period and any mods need to be hidden.
Thanks again
Dan
Birdibus
Birdibus is offline
PostPosted: Thu May 18, 2006 8:34 am    Post subject: Reply with quote
I thought I remembered seeing a vendor who sells water tanks for some Westfalia years, but couldn't find it. Try reading this topic and the link included in it. If you can't find a new tank, try placing a want-to-buy ad in the Samba classifieds to locate a used tank.
http://www.thesamba.com/vw/forum/viewtopic.php?t=171876&highlight=water+tank
mighty-manx
PostPosted: Thu May 18, 2006 9:25 am    Post subject: Reply with quote
Thanks Birdibus I will call Inca if all else fails but my problem is I have no clue what a 74 tank even looks like I have never seen one I think it goes in the first cabinet inboard under the sink above where the spare tire goes? the pump is missing and there is another hack job faucet installed.
If you or any one can take a picture of what it is supose to be i can go from there .
Thanks
Dan
Ps if any one needs a 73 console with good ice box let me know.
Birdibus
Birdibus is offline
PostPosted: Thu May 18, 2006 2:22 pm    Post subject: Reply with quote
Here ya go. Hope these help. There may be some small details that aren't completely original, but it's very close, eg. collapsable tire is gone, support strap is replaced, the PO did something funny with the siding. Embarassed The camera has a way of finding dirt and stains I haven't noticed before. Gotta reach in a little further with the furniture oil-on-a-rag.
1974 Westfalia sink watertank faucet upper cabinet
1974 Westfalia pump, sink drain, tank drain with brass valve (dirty clear plastic hose), lower cabinet
1974 Westfalia drain and vent pipes, fresh water hose (black), wiring from faucet to pump
1974 Westfalia underside of sink and faucet, water hose, wiring, top of tank visible lower left
1974 Westfalia underside of watertank, pump with black freshwater hose, brass valve with tank drain (clear plastic hose), wiring
steponmebbbboom
steponmebbbboom is offline
PostPosted: Thu May 18, 2006 3:12 pm    Post subject: Reply with quote
hrm
http://www.incaplastics.com/w20/48.htm
Someone wanna go compare measurements, we may have a winner here.
mighty-manx
PostPosted: Thu May 18, 2006 4:44 pm    Post subject: Reply with quote
THANK YOU!!!!! you have been upgraded to hero status Wink THat was exactly what I needed. now I know what I am up against. not too bad some of the stuff is still there like the terminal block. and I have the spare but I have a nose mount also need the storage space.
Dan
steponmebbbboom
PostPosted: Thu May 18, 2006 5:09 pm    Post subject: Reply with quote
she's pretty good aint she
Karl
Karl is offline
PostPosted: Thu May 18, 2006 7:05 pm    Post subject: Reply with quote
Not sure if this person still has it 4sale, but here is the tank:
http://www.thesamba.com/vw/classifieds/detail.php?id=261562
If not, and you do find a tank, MAKE sure the two outlets on the bottom are on the small and away from the filler hole.
If the two outlets are on the big end, same as the filler hole, THAT is a 76-79 tank.
renobdarb
renobdarb is offline
PostPosted: Thu May 18, 2006 8:13 pm    Post subject: Reply with quote
I know for a fact that the guy at BustedBus has one of those tanks for that year, because he sent me one instead of the one I needed for my '78. It was an honest mistake and he sent me the correct one right away. Give him a try, because if I remember right he said he had a few of them. -b
1978 Campmobile, 2000cc w/hydro lifters, dual Weber 44 IDF carbs (50 idle jets, 115 main jets), SVDA distributor w/Compufire.
mighty-manx
PostPosted: Thu May 18, 2006 8:16 pm    Post subject: Reply with quote
You guys rock I e-mailed the Samba seller and I will contact Busted Bus thanks again i found the pump and faucet @ boaters world for 42 bucks. I will post info if any one is interested.
Hoping to do the 2007 Artic circle gig and need all the westy stuff good to go.
Dan
Birdibus
Birdibus is offline
PostPosted: Fri May 19, 2006 12:53 am    Post subject: Reply with quote
Check out The Bus Depot for faucets and pumps.
Karl
Karl is offline
PostPosted: Sat May 20, 2006 9:08 pm    Post subject: Reply with quote
Dan
I found your water tank today..... email me at [email protected]
mighty-manx
PostPosted: Sat May 20, 2006 9:14 pm    Post subject: Reply with quote
E-mail sent
Thanks
Dan
hambone
hambone is offline
PostPosted: Mon May 22, 2006 1:35 pm    Post subject: Reply with quote
My friend's bus has a heater under the tank, is that rare?
Midreal
Midreal is offline
PostPosted: Thu Mar 12, 2020 10:17 am    Post subject: Re: 1974 westy water tank Reply with quote
I have a water tank I pulled out of a older van quite awhile back. I am cleaning my shed out and listing parts I don’t need. But I noticed that the tank I have has the water pump and drain located under the tall part of the tank instead of under the narrow part like seen in this post. So now I am wondering why and how to list it. Is this not a standard 70’s westfalia tank? Why would it be reversed? I can’t find many photos online or much info on these. Any help would be appreciated.
Mispeld
Mispeld is offline
PostPosted: Thu Mar 12, 2020 1:50 pm    Post subject: Re: 1974 westy water tank Reply with quote
My 77 westy has the fittings like yours in the back under the long side. It slides into the cabinet with the long part in the rear, and the shorter part facing you.
Tom
1977 Westy. 2.0 Fuel Injected.
Midreal
Midreal is offline
PostPosted: Thu Mar 12, 2020 11:56 pm    Post subject: Re: 1974 westy water tank Reply with quote
Awesome thanks so much for the explanation. Really appreciate the post 👍
