BerT3's dropped spindles
BerT3
BerT3 is offline
PostPosted: Fri May 26, 2006 11:43 am    Post subject: BerT3's dropped spindles Reply with quote
Hello,
Finally after 4 years I have a suitable test car for my own fabricated dropped spindles.
Bought a '66 T34 some time ago and decided to test run a pair of my spindles on the car.
Took me some hours to put them on.
Took advantage of the car being on axle stands to renew the entire front brake system and upgrading to a dual circuit master cylinder with new calipers, hoses etc...
Removed the bottom bumpstop in case I want to go lower.
For the moment it's just sock height with the spindles on.
I like the stance with the stock size rims and new oem spec. tires.
Next week I gonna have the front train aligned.
I have enough cores to make some other sets. I will have 2 sets available to overseas customers.
For details check www.BerT3.be - accept downloading the .doc to read the pages.
https://www.thesamba.com/vw/gallery/pix/156982.jpg
https://www.thesamba.com/vw/gallery/pix/156983.jpg
https://www.thesamba.com/vw/gallery/pix/278328.jpg
BerT3
localboy
Samba Longboarder
localboy is offline
PostPosted: Fri May 26, 2006 1:21 pm    Post subject: Re: BerT3's dropped spindles Reply with quote
Pix of the car with them installed? Would like to see the "stance".
One man's "patina" is another man's cancer...
Black '65 Resto-Custom S Notch 2110 cc powered
original paint Pearl White '66 Westy SO-42
Allstate single-wheel trailer project
Notched
Notched is offline
PostPosted: Fri May 26, 2006 1:30 pm    Post subject: Reply with quote
Uhhhhhh, d'oh!
Is this a problem??
Phillip Bradfield
Current stock: '57 Panel Bus, '63 Rat Notch, '64 Baja, '66 Variant, '67 Convertible Ghia, '68 Squareback, '69 Squareback, '69 Fastback
Southern Oregon VW Club -- http://www.sovw.org
Oregon VW Forum -- http://www.oregonvw.org
Bobnotch
Bobnotch is offline
PostPosted: Sat May 27, 2006 7:23 pm    Post subject: Reply with quote
Notched wrote:
Uhhhhhh, d'oh!
Is this a problem??
UHH, I think it's missing a tire. The rim only really lowers the front end. Very Happy I'd still like a set of those. I know they work. Shocked If I sent you a set of core spindles, would it save me a core charge? Wink
Bob 65 Notch S with Sunroof
Tram wrote:
Tram wrote:
BerT3
BerT3 is offline
PostPosted: Sun May 28, 2006 1:32 am    Post subject: Reply with quote
That's the main idea yes.
I have 4 pair of cores myself. which I am planning to have made in the next month.
Photos next week. Otherwise check old threads and photos under my nickname at this very forum !
BerT3
Air_Cooled_Nut
Air_Cooled_Nut is offline
PostPosted: Sun May 28, 2006 8:43 am    Post subject: Reply with quote
Bobnotch wrote:
Notched wrote:
Uhhhhhh, d'oh!
Is this a problem??
Bob, it looks like it's scraping the inside of the rim...thus the problem Wink
Toby http://www.aircoolednut.com/
Did I mention that I'm an original Darksider?
'72 VW Squareback, 2007cc, GB 5-speed, rag top; '76 VW Riviera Penthouse Sundowner 2.0L; 2015 Audi S5 Cabby w/Stage II APR; '06 Ducati Sport Classic 1000; '14 Ducati Diavel Strada
The First Invasion
BerT3
BerT3 is offline
PostPosted: Sun May 28, 2006 12:41 pm    Post subject: Reply with quote
It isn't though.
At least 1 inch space.
It's because of the top vieuw photo !
I can take some photos of it installed next week.
BerT3
canabus
canabus is offline
PostPosted: Sun May 28, 2006 6:59 pm    Post subject: parts Reply with quote
did you have a certified welder weld that,looks like a fair bit of undercut and lack of weld material,by the cad plated piece
I know in canada that if there is not a red seal interprovincial ticket you can't use any modified parts,or you are personally liable as a driver
I personally would hate to loose everything ,I worked hard for ,for lack of a certified tradesman
my 2c
BerT3
BerT3 is offline
PostPosted: Mon May 29, 2006 10:00 am    Post subject: Reply with quote
It indeed looks like it; It's because there is a kind of a logoon in the bottom piece. Hence why it looks underwelded.
Both halves where heated in a smiss oven before welding though.
They are bolted through with one M10 and one M12 bolt for safety
Same over here as with any non stock parts !
We just have new laws regarding tuning over here.
We even have to have a certificate for a non stock steering wheel !
BerT3
BerT3
BerT3 is offline
PostPosted: Tue Jun 20, 2006 11:09 am    Post subject: Reply with quote
https://www.thesamba.com/vw/gallery/pix/284032.jpg
Finally a photo
Front:
145/65 tires on a 4.5" lemmertz rim with ET 25 and an extra 10mm added wide of the 42mm dropped spindles.
Added an extra 1 outer spline drop at the front trailing arms.
Makes it possible to use new standard height shocks due to almost it's entire stock travel.
Rear:
165/65 tires on a 4.5" lemmertz rim with ET 25
I found this the perfect stance with lots of room and comfort
Note these are both expensive tires !
BerT3
Mr. Bubblehead
El Chupa Nibre
Mr. Bubblehead is offline
PostPosted: Tue Jun 20, 2006 11:40 am    Post subject: Reply with quote
Finally a photo
Front:
Rear:
BerT3
Got any more of those 4.5" Sprints you care to part with?
OGST
Samba Member #4862
BerT3
BerT3 is offline
PostPosted: Tue Jun 20, 2006 1:06 pm    Post subject: Reply with quote
Aren't those common in the USA ?
Not much choice for 4 lug cars in a decent offset.
Tried rivieras etc ... All a bad offset.
Stock ET value of 46 is the best. Not much space underneath a lowered T34.
BerT3
blankmange
Type 3 Darksider
blankmange is offline
PostPosted: Tue Jun 20, 2006 1:22 pm    Post subject: Reply with quote
BerT3
nope -- the 5.5" are more common, but the 4.5"s are not...
póg mo thóin
Certified DHS Technician
Samba Member # 24517
notchback
Insensitive Jerk
notchback is offline
PostPosted: Tue Jun 20, 2006 3:14 pm    Post subject: Reply with quote
BerT3
I've got 4 4.5" and 9 5.5" sitting in my barn Shocked
zeen wrote:
Arguing with johnnypan is like mud-wrestling a pig. After a while you realize he just enjoys playing in the mud, winning the contest is not the point.
FU#3
blankmange
Type 3 Darksider
PostPosted: Tue Jun 20, 2006 3:44 pm    Post subject: Reply with quote
BerT3
and you are doing what with them -- hoarding them? I'll take 2 and 2, thank you...
póg mo thóin
notchback
Insensitive Jerk
PostPosted: Tue Jun 20, 2006 3:58 pm    Post subject: Reply with quote
BerT3
Three sets. One set of 5 painted 5.5"s with OG center caps. One set of nice original chrome 2 - 4.5" and 2 - 5.5" with OG center caps. One set of ratty/rusty chrome 2 -4.5" and 2 - 5.5" with no caps. Just trying to decided what to do with them all. Also have two sets of polished 8 spokes and a set of 5 Baja Marathon rims all with center caps. I've got more money tied up in accessories than I have in any car.
FU#3
