0.028" deck height too small with H-beam rods?
Dingleweed
Dingleweed is offline
PostPosted: Fri Jan 19, 2007 8:43 pm    Post subject: 0.028" deck height too small with H-beam rods? Reply with quote
Here's the info:
CB aluminum case with +3.5mm deck
84 mm crank with Chevy journals
CB Super Race forged H-beam rods (5.5")
Clevite rod bearings
94 mm stroker pistons
CB wedge-port heads with 66 cc chambers
without any barrel shims, I measured the deck height to be 0.028" which would yield all by itself my desired compression ratio of 9.2:1
So, here's the question:
is a deck height of 0.028" enough? Does anyone know the stretch figures for forged H-beam rods?
1962 Dune Buggy, 2332cc, W125, 44x37 wedgeports, 48 IDFs, Rancho Pro Street transaxle
vwracerdave
vwracerdave is offline
PostPosted: Fri Jan 19, 2007 9:01 pm    Post subject: Reply with quote
I personally do not run less then .045" deck height no matter what parts are used.
Type 5 Joe
Banned
Type 5 Joe is offline
PostPosted: Fri Jan 19, 2007 9:05 pm    Post subject: Reply with quote
I agree.... If a rod bearing goes out, you don't take out the piston, head,rod crank, ect......
If you would like to contact me, just email through one of my ads on here...
I don't use the P.M. service on here.
Type 5 Joe
Banned
PostPosted: Fri Jan 19, 2007 9:11 pm    Post subject: Reply with quote
Set the deck to .045 (at least).... Cut the head to the calculated CC's needed.. Wink
vwdragracer
vwdragracer is offline
PostPosted: Fri Jan 19, 2007 9:34 pm    Post subject: Reply with quote
the "RODS" are not your problem. The problem will be crank flex. Even some of the high dollar forged full circle cranks will flex a bit. .045" deck minimum. Like stated set deck at .045 and adjust head cc for the desired compression ratio
Going fast in a VW because to do so in anyything else is boring
View user's profile Send private message AIM Address Yahoo Messenger MSN Messenger Gallery Classifieds Feedback
A.J.Sims
Banned
Location: LowBugget.com 982 N Batavia A4 Orange Ca 92867
A.J.Sims is offline
PostPosted: Sat Jan 20, 2007 12:47 am    Post subject: Reply with quote
sand drag 1600 with .012"
pro stock 9000rpm combos .025"
my 2387 at 13.2:1 .032"
all the motors that come out of my shop .04"
If you have a crank that will flex over .005" you need a new crank, as that one you have is rubber!
I would not run .028". its not how close of a deck that's the problem its how your checking it and with what! add .02" shim and fly cut the heads the same .02" to get the same number!
Or cut .028" off the barrel and make it 0.0" then add a .04" copper head gasket and still cut the heads.
Have tech questions? Need real help? Give us a call.
www.Lowbugget.com
982 North Batavia A4, Orange Ca 92867.
68 drag bug 1915cc 10.50's @130mph
66 fastback 2387cc turbo street car
67 baja 2054cc turbo.
camch
camch is offline
PostPosted: Sat Jan 20, 2007 6:33 am    Post subject: Reply with quote
are you saying run a 0 deck height and a .040 head gasket
Dingleweed
PostPosted: Sat Jan 20, 2007 11:49 am    Post subject: Reply with quote
Thanks for the replies guys. The intentions for this motor are far from a daily driver and/or high-milage or long-term reliability motor. It's going into my weekend "toy" so it would more accurately fall into a racing motor category than a daily driver motor. I was curious what deck heights some of you racers and high horsepower engine builders have used.
Thank you very much for the reply AJ and the deck heights you have setup in the past. I first used a dial indicator to find absolute TDC (my degreed crank pulley was 2* advanced). Then I used a depth gauge to measure the deck height. I then also (for the fun of it) used a flat edge and feeler gauges just to see if the #s matched. Both times I came up with 0.028".
I'll be going with some barrel shims. Whether I go with 0.010" or 0.020" inches I haven't decided yet. I think I am going to deck height measure cylinders 2, 3, and 4 to see what all of the #s are before I decide.
Thanks again guys.
Glenn Premium Member
Mr. 010
Glenn is offline
PostPosted: Sat Jan 20, 2007 11:57 am    Post subject: Reply with quote
Thanks again guys.
Rimco will make custom shims, so if you want .018" they will make them and you can set whatever CR you want.
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
Dingleweed
PostPosted: Sat Jan 20, 2007 12:15 pm    Post subject: Reply with quote
Glenn wrote:
Thanks again guys.
Cool, thanks for the info Glenn. Oh and by the way, I like your name.
Glen
gerg
a.k.a. 6volt65
gerg is offline
PostPosted: Sat Jan 20, 2007 1:00 pm    Post subject: Reply with quote
Call over and speak to Greg - very personable and willing to help.
Gerg
. . . I got 99 problems and my bus ain't one . . .
'65 Sunroof Beetle
'65 Vert
'60 Singlecab
View user's profile Send private message Send e-mail Visit poster's website Yahoo Messenger Gallery Classifieds Feedback
Bruce
Bruce is offline
PostPosted: Sat Jan 20, 2007 3:42 pm    Post subject: Reply with quote
How are you measuring that?
If that were true why use any DH greater than .006"?
miniman82
Samba Swamp Donkey
miniman82 is offline
PostPosted: Sat Jan 20, 2007 6:19 pm    Post subject: Reply with quote
Rods also stretch a measureable amount...
Build thread: http://www.thesamba.com/vw/forum/viewtopic.php?t=212747
Glenn wrote:
satterley_sr wrote:
I just wanted to bitch but I'm getting no sympathy.
Welcome to the Samba.
stealth67vw
stealth67vw is offline
PostPosted: Sat Jan 20, 2007 6:48 pm    Post subject: Reply with quote
Piston expansion and and carbon build up.
John Bates
JB Machining Services
1967 street Bug 2276 w/ 48 IDAs, 2050lbs with driver
7.76 @ 89.55mph 1/8 mile
12.27 @ 109.56 mph 1/4 mile
https://youtube.com/shorts/GmifEu5QvnA?si=OIw8eM7QU3LMhtiz
https://www.tiktok.com/t/ZT68foYFS/
Dingleweed
PostPosted: Sat Jan 20, 2007 7:45 pm    Post subject: Reply with quote
*Update*
I went to measure the deck height for all of the other pistons and cylinders and noticed that the cylinders weren't sitting flush with the case deck. They were binding a little between the head studs and the outsides of the cylinders. So I measured the overlap area from the outside of the cylinders (where the stud goes) to the sleeve which slips into the case. The measurements were all over the place for the cylinders... anywhere from 0.07-ish" to 0.13-ish". The clearance between the case cylinder bores and the head studs (8-mm ones) measured in the 0.11-ish" range.
Is this variation in the cylinder sleeve to head stud measurements normal for a set of cylinders?
So I used my die grinder to grind down the outsides of the cylinders in the area where the head studs are supposed to go on the case side of the cylinders. I ground them all down to be in the 0.07" to 0.08-ish" range. Now all of the cylinders slip nicely down on the heads studs and sit flush with the case.
Re-doing deck heigh measurements for all of the pistons and cylinders yielded deck heights of 0.024" to 0.025".
I think I'll be ordering a set of standard 0.020" barrel shims. This should give me a deck height of 0.044" to 0.045" and a compression ratio of 8.89:1 using the heads the way they are now (66 cc combustion chambers).
Thanks for the help guys. Oh, and this discussion of why you need deck heigh at all is very interesting Very Happy (whether it is due to crank flex, rod stretch, thermal exansion of the piston, etc.)
My vote is that rod stretch accounts for the majority of deck height needed because I calculated that an 84 mm crank spinning at 8,000 rpm yields an acceleration of about 3,008 g's at the small end of the rod (assuming the piston is a simple harmonic oscillator...i.e., very long rods)
Type 5 Joe
Banned
PostPosted: Sat Jan 20, 2007 8:22 pm    Post subject: Reply with quote
Rod stretch isn't that much.... Grab an H-Beam rod and pull on the ends, you aint gonna stretch it that much Laughing
Imagine how many times the piston would contact the head @ 8000 RPM if you ran really tight deck height, and the rod bearing shell fails.... 133 times a second.
You had better be able to shut her down quick if you hear a problem.Shocked
Mostly crank flex, thermal expasion (piston) and carbon "use up" some of the deck clearance. I put about .045"-.050" in there, so if there ever was a problem, I might not explode my piston, rod, head, crank, case, then cam, ect, ect, .... Hopefully the piston won't contact the head a Thousand times or so before the engine gets shut down.
- Joe
Dingleweed
PostPosted: Sat Jan 20, 2007 8:35 pm    Post subject: Reply with quote
True, but I can't pull with around 3,000 lbs of force either Wink (that's the ball-park number for ~3,000 g's on a ~1 lb piston at the end of a rod on an 84 mm crank spinning ~8,000 rpm)
Type 5 Joe
Banned
PostPosted: Sat Jan 20, 2007 8:56 pm    Post subject: Reply with quote
O-K imagine you're piston travelling with a force of three thousand G's or so... hitting you're head 133 times a second.... Laughing
nsracing
nsracing is offline
PostPosted: Tue Feb 13, 2007 8:22 pm    Post subject: Reply with quote
I am trying to understand how anyone can measure crank flex at all? Must be a new distortion meter somehow. Razz
A crank will flex a lot if it has a lot of unbalance. Ultra balance work is key in building good running engines.
I like 0.040 - 0.050 myself for deck height. I mean 0.040 " is not large at all.
I am not a believer of zero deck. If you think about all the total stack of clearances from rod bushings to rod bearings and main bearings and the tolerances on the rod lenghts..end to end, I am sure it will be quite a bit of clearance.
gerg
a.k.a. 6volt65
gerg is offline
PostPosted: Tue Feb 13, 2007 9:00 pm    Post subject: Reply with quote
My deck measured at .030" (on the thin side I know). I had some new 044 CB heads that Darren over at DRD did some mild work on for me. He told me that there was not enough material in the head to remove to get a 8.0:1 CR without major distortion to the squish area. Instead of putting a spacer under the barrel he suggested a step in the head.
So he recommended 'some' chamber work, then when cutting the head for 94mm he left a step to add to my .030" deck. The step was the same width as the 94mm cylinder wall thickness.
Overall I wound up with .030" in the cylinder, and .080 step in the head. That is a total of .110" deck - HUGE I know. Darren said large decks are not that bad and that sometimes your only option is to 'deck it' to get your CR where you want it.
I know Berg's litterature is old and fuel has changed, but he documented larger decks than that.
My engine runs fine.
Now - tear it up . . . . Twisted Evil
Gerg
'65 Sunroof Beetle
'65 Vert
'60 Singlecab
