Ragtop question..
57 Rag
57 Rag is offline
PostPosted: Tue Feb 13, 2007 7:00 pm    Post subject: Ragtop question.. Reply with quote
Where do I get a new rag from???
thanks
57 Ragtop
84x94 86C
IDAs
volkswagenut
Samba's Big Jerk
volkswagenut is offline
PostPosted: Tue Feb 13, 2007 7:04 pm    Post subject: Reply with quote
new as in aftermarket?
We are a Republic, NOT a Democracy
RareAir
RareAir is offline
PostPosted: Tue Feb 13, 2007 8:56 pm    Post subject: Reply with quote
Are you looking for just the top material?
www.wolfsburgwest.com www.vintagepartsinc.com & www.bfyobsoleteparts.com
1947 Typ 11a
1954 Typ 117
1956 Typ 151
1959 Typ 117
1959 Typ 265
1961 356B
1966 Typ 151
1966 Typ 241
67 Florida Deluxe
Samba Purist
67 Florida Deluxe is offline
PostPosted: Tue Feb 13, 2007 9:14 pm    Post subject: Reply with quote
On the same topic, I have a new top for my '63 but the seam at the front is creeping up and away from the front edge. Any reason? Cheap top or improper install? It was installed just before I got it and the more I use it the further away from the front edge the seam gets! So who makes the best top?
-Kent (BaT "daleallen")
OG member of the '67 Posse
A few of my toys, past and present
'56 Oval, '66 KG Conv't, '67 21-Window, '67 Bug, '79 SuperVert, '55 Pre-A Continental
57 Rag
57 Rag is offline
PostPosted: Wed Feb 14, 2007 2:54 am    Post subject: Reply with quote
Yeah, just to replace the material. Nothin else. Are those the best 3 distributors for rags??
thanks
57 Ragtop
84x94 86C
IDAs
volkswagenut
Samba's Big Jerk
PostPosted: Wed Feb 14, 2007 3:52 am    Post subject: Reply with quote
IMO , I would get a canvas top . had a vinyl top and didn't like it a bit . the canvas i have now is alot better. Wink got it from WW
KPottorff
KPottorff is offline
PostPosted: Wed Feb 14, 2007 7:47 am    Post subject: Reply with quote
Got a canvas top from WCM about 8 years ago when I lived in Phoenix. I live in OK now and even after years of exposure to the sun it still is in good condition.
I just vacuum it once in a while to get the dust out before I wash the car.
RareAir
RareAir is offline
PostPosted: Wed Feb 14, 2007 8:25 am    Post subject: Reply with quote
Originally, VW used rivets to secure the cover material to the front header bow. These days, most people use a poor contact cement to glue it down. Probably a comination of incorrect glue and the cover is too tight.
1947 Typ 11a
1954 Typ 117
1956 Typ 151
1959 Typ 117
1959 Typ 265
1961 356B
1966 Typ 151
1966 Typ 241
57 Rag
57 Rag is offline
PostPosted: Wed Feb 14, 2007 6:30 pm    Post subject: Reply with quote
Whats the proper way to put it on nowadays then?
57 Ragtop
84x94 86C
IDAs
67 Florida Deluxe
Samba Purist
PostPosted: Wed Feb 14, 2007 6:38 pm    Post subject: Reply with quote
Which material is proper for which years? Pinpoint vinyl vs. Stayfast canvas.
67 Florida Deluxe
Samba Purist
PostPosted: Wed Feb 14, 2007 6:40 pm    Post subject: Reply with quote
X2 Smile
RareAir
RareAir is offline
PostPosted: Wed Feb 14, 2007 10:19 pm    Post subject: Reply with quote
1950-55 Beetles came with canvas
1956-later Beetles came with Vinyl
1947 Typ 11a
1954 Typ 117
1956 Typ 151
1959 Typ 117
1959 Typ 265
1961 356B
1966 Typ 151
1966 Typ 241
57 Rag
57 Rag is offline
PostPosted: Wed Feb 14, 2007 10:20 pm    Post subject: Reply with quote
What's that?? Yeah ....okay you got me I'm an ID!
57 Ragtop
84x94 86C
IDAs
RareAir
RareAir is offline
PostPosted: Wed Feb 14, 2007 10:22 pm    Post subject: Reply with quote
X2 Smile
3M adhesive came as a suggestion when I inquired a few months ago. After you spray it on both surfaces, let it sit for a few minutes before attaching the parts together. Many times during assembly, most people spray the adhesive then attach the material & header bow together instantaneously without allowing the glue to tack up. This doesn't allow the adhesive to bond as well as it should
1947 Typ 11a
1954 Typ 117
1956 Typ 151
1959 Typ 117
1959 Typ 265
1961 356B
1966 Typ 151
1966 Typ 241
my59
my59 is offline
PostPosted: Wed Feb 14, 2007 10:23 pm    Post subject: Reply with quote
In my gallery I've posted the manual for a 59. I used rivets to secure the replacment one I got from BFY. The manual has info re adjusting the tension so the front dosent lift.
my59: Well son, my grandfather died before I got to drive it, so does that answer your question?
Other:'12 Jetta, '77 Benz 300D, and a 74 MG Midget.
glutamodo Premium Member
The Android
glutamodo is offline
PostPosted: Thu Feb 15, 2007 11:11 am    Post subject: Reply with quote
The adhesive I used when I put my last (canvas) top on was that Automotive Goop stuff. It really held that top on strong. Actually, since the top turned out to fit so poorly at first, I had to un-glue it and re-do it after a while, and that Goop held it on so well that it was very hard to get off. I've had much worse results with general contact cements over the years.
67 Florida Deluxe
Samba Purist
PostPosted: Thu Feb 15, 2007 12:04 pm    Post subject: Reply with quote
I looked at your gallery and those pages from the manual look great! I assume they are applicable to '63. As you can see, I have two issues; the first bow doesnt look to be installed properly and the front edge is creeping back. (I may have a third issue - I dont know if this is a quality top Confused ) I'm going to print the pages from the manual and go see if I can improve this situation.
scott s
scott s is offline
PostPosted: Thu Feb 15, 2007 12:23 pm    Post subject: Reply with quote
I got a vinyl top from WCCR and it fit MUCH better than the TMI top I had on before. It's also a very close match for the Ruby Red paint. They offer several colors that are matches for the factory stuff.
WCCR = West Coast Classics and Restorations.
Bruce
Bruce is offline
PostPosted: Thu Feb 15, 2007 4:19 pm    Post subject: Reply with quote
Sometime after 56, when you went into the VW dealer to buy a cover for a 50-55 Beetle, you got a vinyl cover. Vinyl was the upgrade.
