Match porting the intake gasket
Glenn Premium Member
Mr. 010
Glenn is offline
PostPosted: Thu Feb 15, 2007 4:46 pm    Post subject: Match porting the intake gasket Reply with quote
What's the best way to match port the intake manifold gasket?
I bolted the gasket to the manifold and used a sanding drum on a dremel until I hit metal.
Is there a better way?
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
cal63look
cal63look is offline
PostPosted: Thu Feb 15, 2007 4:54 pm    Post subject: Reply with quote
Damn i never even thought of doing it like that Shocked The only thing i could think of would be an exacto knife. But i think your way sounds pretty darn good to me. Im sure that would produce a nice consistent cut on the gasket and not look too butchered up.
Ace
Ace is offline
PostPosted: Thu Feb 15, 2007 4:56 pm    Post subject: Reply with quote
are you using metal gaskets? I used to use the old thick paper ones and an exacto using nuts and washers to keep it from moving while cutting. I would keep that one as the original for a template to cut the others when needed.
[email protected]
masoliven@yahoo.com is offline
PostPosted: Thu Feb 15, 2007 4:57 pm    Post subject: Reply with quote
Glenn,
Thats pretty much the way I did mine, After your done with the first one...Take it and put up to another one and draw a bunch of them out. That way theres xtras for later. Wink
Mike Soliven
2006 PRA Super Mod Champion
S/G 333
64 Sunroof 2276cc IDA's
Joval
Joval is offline
PostPosted: Thu Feb 15, 2007 4:59 pm    Post subject: Reply with quote
There was an article in Volksworld a while back that suggested fitting the gasket and tapping it with, IIRC Confused the handle of a screwdriver to make an impression
then cut the gasket with a craft knife.
Mr. 010
Glenn is offline
PostPosted: Thu Feb 15, 2007 5:17 pm    Post subject: Reply with quote
I'm using the Berg extra wide paper gaskets.
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
RIS
RIS is offline
PostPosted: Thu Feb 15, 2007 5:22 pm    Post subject: Re: Match porting the intake gasket Reply with quote
That's how I do mine, unless the engine is assembled - then I use an exacto knife...
Richard Sedoris - VW Performance & Machine - Youngstown, OH
http://rismachine.tumblr.com/
YouTube: https://m.youtube.com/channel/UCfTBCG4I61iVm_ROc8OAuOQ
Instagram: @rismachine
jamestwo
jamestwo is offline
PostPosted: Thu Feb 15, 2007 5:22 pm    Post subject: Reply with quote
Gaskets are old school, the new hottness is to run the intakes naked Baby!!!
o gaskets here, just a THIN layer of gaskets sealer.
hEY, lOOK, i'M WRONG HALF THE TIME, AND THE OTHER HALF i'M NOT SURE WHAT THE HECK i'M TALKING ABOUT. MY POST ARE FOR MY OWN ENTERTAINMENT VALUE ONLY.
Mr. 010
Glenn is offline
PostPosted: Thu Feb 15, 2007 5:36 pm    Post subject: Reply with quote
What sealer?
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
RIS
RIS is offline
PostPosted: Thu Feb 15, 2007 5:38 pm    Post subject: Reply with quote
I'd make sure the intake manifolds are perfedctly flat before using only sealant...
cal63look
PostPosted: Thu Feb 15, 2007 6:50 pm    Post subject: Reply with quote
What type of sealer? anearobic(spellin?)?
Mad Manx
Mad Manx is offline
PostPosted: Thu Feb 15, 2007 7:44 pm    Post subject: Reply with quote
I have used Loctite 518 flange sealant on my manifolds for a couple
of years now, just a thin layer and manifolds straight onto the heads.
I have never had a leak or had a nut come loose from vibration even
in off road cars. I read about this over on the Cal-Look and it worked
great, I use it on my oil pumps to case also with no gasket . It fools
you by looking like it never dries around the edges but it is good and
sealed between the metal Wink
Mr. 010
Glenn is offline
PostPosted: Thu Feb 15, 2007 7:57 pm    Post subject: Reply with quote
what about when you remove the manifolds and reinstall? Do you have to clean it off before reapplying and reinstalling?
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
Mad Manx
Mad Manx is offline
PostPosted: Thu Feb 15, 2007 8:17 pm    Post subject: Reply with quote
Yea, it comes off pretty easy with a blade and Berrymans B12 will get
it off when applies directly onto it, I have never had the B12 affect it
when sprayed on it in the assembled condition.
HBRag
HBRag is offline
PostPosted: Thu Feb 15, 2007 8:34 pm    Post subject: Reply with quote
'Old School', ha. 1940's era aircraft engines didn't use a gasket on the carburetor to manifold connection. The two surfaces are machined and assembled using a none hardening, fuel resistant sealer and a piece of sewing thread. The manifolds are laid out so that the thread can be run from stud to stud, and be centered on the mating portion of the flange.
The thread trick would be tuff with the VW manifold design.
nsracing
nsracing is offline
PostPosted: Thu Feb 15, 2007 9:01 pm    Post subject: Reply with quote
Sanding drums will clog up quickly w/ aluminum. Use a HSS or carbide burr to port all the way to the outline if that is all you need. WD-40 for lube is okay. I use tallow sticks (used in bandsawing).
Didn't the heads get ported with the manifolds?
If the surfaces are machined perfectly flat and no burs, sure you can install naked. Or you can use a skinny paper like an oilpump cover gasket to seal the manifolds.
Hell..tranny intermediate carriers only has the skinny paper gasket. That thing is so flimsy, it will rip if you looked at it long enough. Very Happy
Mr. 010
Glenn is offline
PostPosted: Thu Feb 15, 2007 9:08 pm    Post subject: Reply with quote
Nick,
I used a sanding drum since it will easily cut the gasket but not chew up the aluminum when it hits the manifold.
The manifolds were match ported to the heads.
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
nsracing
nsracing is offline
PostPosted: Thu Feb 15, 2007 10:12 pm    Post subject: Reply with quote
Somebody already mentioned Exacto knife. Them Berg gaskets are huge ain't they?
How far is the engine? I am getting excited too. Razz
Mr. 010
Glenn is offline
PostPosted: Thu Feb 15, 2007 10:14 pm    Post subject: Reply with quote
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
nsracing
nsracing is offline
PostPosted: Thu Feb 15, 2007 10:28 pm    Post subject: Reply with quote
That thing looks beasty hung up like that. Nice job, Glenn.
