Perales Samba Member
Joined: May 07, 2007 Posts: 2046 Location: Nova Scotia
Posted: Sat Sep 22, 2007 12:29 pm Post subject: Fuel Hose Clamps |
How tight should the fuel hose clamps be tightened? The hoses are under considerable pressure so you don't want them blowing off but you don't want to crush the fittings either. Anybody have any advice as to how to know if they are on tight enough?
I ordered the fuel hose replacement kit. Don't want to be the next photo of a burning van on the Samba. (man are my old hose clamps ever rusty!!) _________________ -- 1987 Westfalia automatic (Captain Vino) |
Glenn  Mr. 010
Joined: December 25, 2001 Posts: 79602 Location: Sneaking up behind you
Posted: Sat Sep 22, 2007 12:35 pm Post subject: |
First you need the right clamp. Here are two "better" clamps, the left is German stainless with rolled edges. The right is Swedish and provides the most uniform pressure on the hose. Then you need the right size, too large a clamp is no good.
I'm using the Swedish ones. _________________ Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי |
Randy in Maine Samba Member
r39o Samba Polizei
Posted: Sat Sep 22, 2007 1:39 pm Post subject: |
The "Mercedes" fuel line clamps that the bus despot sells work fine too.
I like the smooth clamps with the rounded edges best too. The Mercedes clamps from bus despot are like that.
I would, however, NOT use them as replacements for the crimped on hose ends of the fuel injectors. Just get your injectors professionally serviced and have new hoses with new crimps installed. I did and am happy that I can sleep at night. _________________ "Use the SEARCH, Luke" But first visit the Vanagon FAQ!
Glenn  Mr. 010
Posted: Sat Sep 22, 2007 1:41 pm Post subject: |
Randy,
I went to his house/shop to get mine. /all I can say is INC READABLE. _________________ Glenn
Member #1009
#BlueSquare
msinabottle Samba Member
Posted: Mon Sep 24, 2007 12:02 am Post subject: NAPA! |
You can get those swedish clamps (or clamps using that design) from NAPA. I use them by preference, they are JUST big enough for the injector lines, if you get the largest size.
Those are the ones on the right in the useful picture above.
germansupplyscott Samba Member
wavanagon Samba Member
Joined: September 17, 2007 Posts: 400 Location: Everett, WA
Posted: Mon Sep 24, 2007 8:34 am Post subject: |
Having just done this, I would say either 14 or 13 for the smooth 7mm fuel line. Unless busdepot sent me smaller diameter line, there's no way I could have gotten a 15 to stay on. I bought size 14 for my job and they are pretty close to maxed out as far as remaining thread goes. And, no, I did not over tighten. FWIW....
And yes, go w/ ultimategarage.com, they are 100% SS. I believe his name is Steve and he runs a first class business in my opinion. _________________ 1988 Vanagon GL - For Sale
1987 Westfalia
2008 Audi A4 2.0T
http://wavanagon.googlepages.com
Dirty from working on your Vanagon? Buy soap from my wife!
http://www.teatreesoap.com |
dr. no Samba Member
Joined: August 06, 2004 Posts: 579 Location: Santa Fe
Posted: Mon Sep 24, 2007 9:57 am Post subject: |
| Quote: |
| I would, however, NOT use them as replacements for the crimped on hose ends of the fuel injectors. Just get your injectors professionally serviced and have new hoses with new crimps installed. I did and am happy that I can sleep at night. |
That's assuming that you are entirely confident that the "professionally serviced" means that they used (or were able to get) hose that will not rot by next summer...While I don't exactly enjoy it, I don't mind changing the little short lines as much when I don't have to cut off the crimps. _________________ Scott
http://lungehphoto.com
'83.5 Westy s/p 1.6td JX and 4sp DK transplant
'09 Jetta SportWagen TDI
'06 MB Sprinter
'86 Iltis
'89 Isuzu Trooper
PAST VWs:
'82 NA diesel Vanagon
'86 7-passenger Vanagon
'77 Bay
'71 Bay
'74 Things (2)
'69 Karmann Ghia (the only one I miss--in nice weather, anyway...)
'91 Fox |
Posted: Mon Sep 24, 2007 11:43 am Post subject: |
| wavanagon wrote: |
Which brings me back to my original question in this thread...
How tight is tight enough, but not too tight and how can you tell when you are tightening them? _________________ -- 1987 Westfalia automatic (Captain Vino) |
Posted: Mon Sep 24, 2007 3:10 pm Post subject: |
| Tight enough means they will not leak and too tight means that they will cut into and damage the hose. Just right is subjective and has to be learned by experience. Typically you can still rotate the hose on the fitting without too much effort when they are just right, (this doesn't work for larger hoses) |
tencentlife Samba Member
Joined: May 02, 2006 Posts: 10147 Location: Abiquiu, NM, USA
Posted: Thu Jul 10, 2008 9:31 am Post subject: |
Hey, Perales, if you followed the link above to Ultimate Garage you would have found the answer to your question. _________________ Shop for unique and useful Vanagon accessories at the Vanistan shop:
Experience is death to doctrine. |
Posted: Thu Jul 10, 2008 9:44 am Post subject: |
| tencentlife wrote: |
| Hey, Perales, if you followed the link above to Ultimate Garage you would have found the answer to your question. |
Gee how did I miss that..
I guess I didn't read it carefully.. I feel silly, Oh well.
I will post a quote for local reference:
Clamps should be torqued properly to assure proper seal - for all ABA Mini clamps & Original Clamps through size #6, use 25-30 inch pounds; for Original Clamps sizes #8 through #16, use 30-40 inch pounds and for sizes #20 and higher, tighten to 40-45 inch pounds. _________________ -- 1987 Westfalia automatic (Captain Vino) |
randywebb Samba Member
Posted: Mon Apr 05, 2010 9:36 pm Post subject: |
so, is #14 the size to get for most of the line? _________________ 1986 2.1L Westy 2wd Auto Trans. |
RCB Samba Member
Joined: September 05, 2005 Posts: 4143 Location: San Francisco-Bay Area
Posted: Tue Apr 06, 2010 6:08 am Post subject: |
| #13 is what I have for the 7mm fuel injection hose. At least thats what the ABA clamps have stamped on them. Ultimate Garage has a real fine selection of these clamps and they also have a chart that shows the inside/outside diameter of each clamp. I found the chart to be helpful in deciding what size clamp to get for each application. |
Alaric.H Samba Member
Joined: March 28, 2009 Posts: 2529 Location: Sandy Springs GA
Posted: Tue Apr 06, 2010 6:32 am Post subject: |
| randywebb wrote: |
| so, is #14 the size to get for most of the line? |
4 14.5 and the rest 13 for the injectors . The 4 barbs are larger so they need a bigger size. These sizes are for step less ear clamps. |
Busdepot Samba Member
RCB Samba Member
Posted: Tue Apr 06, 2010 7:27 pm Post subject: |
| Ron, do you carry different sizes of this style of clamp?? Putting a want list together. |
Posted: Tue Apr 06, 2010 9:03 pm Post subject: |
also do you have whatever size is required for the larger hose runs?
IIRC, it is the hose from tank to the big metal filter & maybe from there thru the firewall
there are 2 listings for the 2.1L motors but they both seem to point to the same item _________________ 1986 2.1L Westy 2wd Auto Trans. |
r39o Samba Polizei
Posted: Tue Apr 06, 2010 10:22 pm Post subject: |
These are the ones Bus Depot sells:
