Putty on rear of overhead vent cover plate
Page: Previous  1, 2, 3
Kelly
Kelly is offline
PostPosted: Mon May 08, 2006 1:00 pm    Post subject: Reply with quote
DaveM wrote:
The top most screw is correct/.. those screws should NOT be sheet metal screws. Some PO did a bad thing!
So if I get the correct screws, will my existing holes be salvagable, can I tap them out?
It's not how wide your hatch is, it's what you do with it.
Eriba Puck Sticky
DaveM
Mad Samba Scientist
DaveM is offline
PostPosted: Mon May 08, 2006 1:06 pm    Post subject: Reply with quote
you may be able to tap them... the best you can do is try.
Sounding like a broken record as to why You should be measuring protein during harvest in order to better your agronomic practices.
Jerry J
Jerry J is offline
PostPosted: Sun Aug 20, 2006 4:55 pm    Post subject: Reply with quote
Yes, that stuff is seam sealer. I did that already, it worked very well.
Messy stuff
Everett, would you happen to recall the brand name of this seam sealer? Would you think that something like POR15 in there would be of value?
Also, does the rubber portion of the flap rest against something when it's in the closed position?
Jerry
'58 Bug
'63 KGhia
'67 Squareback
'67 Standard Bus
'60 Single cab
PostPosted: Mon Aug 21, 2006 8:45 am    Post subject: Reply with quote
3M All Around Autobody Sealant
Part # 08500
Yes, there is a seal there:
I used a front door seal as mine was totally missing but it is really a slightly different shaped seal. Note that my rivets are backwards in that photo and I corrected them later so the flap sits flush on the seal.
Major Woody
Samba Enigma
Major Woody is offline
PostPosted: Mon Oct 01, 2007 3:58 pm    Post subject: Reply with quote
This is a very satisfying small repair to do. Replacing all the seals in the flap area, sealing it up tight and also replacing the rubber on the directional flap is a pleasant project and there is nothing like the soft "whump" of the flap snapping into place or the flaps moving smoothly from side to side.
I got NO air leaks now, and all the metal up there is rustfree and smooth gray! Very Happy
Jerry J
Jerry J is offline
PostPosted: Mon Oct 01, 2007 4:05 pm    Post subject: Reply with quote
Did you use the seam sealer like Everett said? I had that shit all over me trying to get it pressed into all of the seams.
Jerry
'58 Bug
'63 KGhia
'67 Squareback
'67 Standard Bus
'60 Single cab
vdubinit
vdubinit is offline
PostPosted: Mon Oct 01, 2007 4:31 pm    Post subject: Reply with quote
that black putty stuff is dumm dumm as per an old german audi vw tech that turned me on to it I use it everyday for bolts
I stab a little piece of dumm dumm on the outer corners of the head of the bolt and stick the bolt onto my socket and that bolt will stay in the socket at any possible angle without falling out Wink
**WANTED** ONE 4 1/2 EARLY FUCH
Major Woody
Samba Enigma
Yah sure, you betcha.
I actually used Vulkem polyurethane caulk, which I believe is the most tenacious gooey substance on earth. I put about an inch of it on the tip of my finger and applied it that way, little by little, after priming and painting. There was a little bit of a mess on me but everywhere else was fine.
When I pulled mine apart, the flap was stuck open because of a big ol wasp's nest and there was another one in the vent, preventing the directional flaps from moving much. The rubber on the flaps was all crusty and folded over and hard. Now everything just glides like butter.
mightymouse
mightymouse is offline
PostPosted: Sun Dec 21, 2008 12:13 pm    Post subject: Reply with quote
Thread from days gone by. Smile dan sent this to me, and i read it and went.... one more bump for 08!
I have to do this repair soon, so i quit freezing. Very Happy
Nothing can stop the man with the right mental attitude from achieving his goal; nothing on earth can help the man with the wrong mental attitude.
Thomas Jefferson
Note to EVERYONE.
Know your ZDDP levels or you WILL lose a cam and lifters.
oring71
oring71 is offline
PostPosted: Sun Dec 21, 2008 2:24 pm    Post subject: Reply with quote
Is there a way to remove the mesh screens? as mine have 2 smallish holes in them and are all cacked with paint and shit, tryed cleaning them but to no real satisfaction.
Has anyone ever done this?
Thanks.
Eric.
Das Maltese Kruizers
BulliBill
BulliBill is offline
PostPosted: Sun Apr 13, 2014 8:20 am    Post subject: Reply with quote
On my thread about the restoration of my 1959 Double Cab ( http://www.thesamba.com/vw/forum/viewtopic.php?t=545000 ) there is a pretty good how-to with lots of photos of how I did the resto of my DC overhead fresh air system using paint, fresh seam-sealer and new seal kits. Look around the middle of page 15 and page 18 for the latest sealing work on my overhead vent system.
Bill
Mission VW - San Fernando
Thornton VW - Stockton
Thanks for any help!
OB Bus
OB Bus is offline
PostPosted: Mon May 25, 2015 8:45 am    Post subject: Reply with quote
Old thread but it is a new day.
Since there are now seal kits for the fresh air flap we no longer have to use electrical tape. My old seal on the '67 single cab was completely gone. The new seal has a longer flap that goes on the "top" (near the roof) OR the bottom. Any ideas which side get the longer flap?
Bill I looked at your pictures but could not see this part.
Thanks!
Larry in OB
69 Westfalia and 2002 Eurovan Camper.
People deserve the Government they voted for.
BarryL Premium Member
BarryL is offline
PostPosted: Mon May 25, 2015 6:48 pm    Post subject: Reply with quote
Can you post a picture of the seals or link to the kit?
OB Bus
OB Bus is offline
PostPosted: Mon May 25, 2015 8:21 pm    Post subject: Reply with quote
OK will do. I bought the seal from Airhead. I looked at their add as well as everyone else selling the same part. No one had a decent and descriptive picture.
These pix are a bit hard to see. In both pictures the holes on the seal are lined up with the rivet holes on the metal flap.
In the first one there is an extra part of the seal showing at the top.
And if I rotate the seal 180 degrees the rubber seal is square on the plate.
Would having things all equal insure success? I just do not want to do the riveting twice.
Thanks!
Larry in OB
BarryL is offline
PostPosted: Tue May 26, 2015 8:59 am    Post subject: Reply with quote
I can't imagine this isn't the correct way: equal. Can you use masking tape and tape it then try dry fitting it? The other way it would whistle when closed at the bottom: yuck.
OB Bus
OB Bus is offline
PostPosted: Tue May 26, 2015 8:59 pm    Post subject: Reply with quote
Equality it will be. It is logical in every way.
Thanks Barry!
Larry in OB
Page 3 of 3
