My 67 - 1500 (Help!)
ocdbeetle
Samba Optimist
ocdbeetle is offline
PostPosted: Fri May 02, 2008 11:35 am    Post subject: My 67 - 1500 (help!) Reply with quote
I've never pulled off the door panels but I'd like to work on my vent rubber...Will I need any new clips to replace the panel or are the clips reusable? Just want to make sure I order what I need beforehand...
1967 Lotus White Beetle
67 Shane
67 Shane is offline
PostPosted: Fri May 02, 2008 11:47 am    Post subject: Reply with quote
Clips are reusable. There are a couple different kinds but reusable all the same. Its an easy task.
-OstKüste-
67 Euro Type 1.
67 SO-42 Westfalia
67 Florida Deluxe
Samba Purist
67 Florida Deluxe is offline
PostPosted: Sat May 03, 2008 9:58 am    Post subject: Reply with quote
Door panel clips are available from vendors (here's the ones at Wolfsburg West). Occasionally, the original ones break during removal, so it's nice to have a few extras.
You might also get new grommets/seals for the holes where the door panel clips attach. They get brittle and tear easily.
When you remove the panel, be careful to not tear the panel. I use a putty knife wrapped with electrical tape so as not to scratch the paint. Push the putty knife between the panel and door were a clip is and gently pry the panel off (do not use a twisting motion). The putty knife distributes the force against the panel, thus reducing the possiblity of tearing the panel board. Once you get all the panel clips removed, you'll need to hold the upper part of the panel away from the door and pull up slightly. The armrest has a clip that slips over a bracket on the door to give the armrest strength. You need to slip the panel upward to get it off the bracket. Holding the top part of the panel away from the door will prevent the panel clips from scratching the door paint.
-Kent (BaT "daleallen")
OG member of the '67 Posse
A few of my toys, past and present
'56 Oval, '66 KG Conv't, '67 21-Window, '67 Bug, '79 SuperVert, '55 Pre-A Continental
ocdbeetle
Samba Optimist
PostPosted: Sat May 03, 2008 10:44 am    Post subject: Reply with quote
Very cool info - Thanks guys...My bug is grateful... Very Happy
ocdbeetle
Samba Optimist
PostPosted: Sun May 04, 2008 10:29 am    Post subject: Reply with quote
I want to put these trim rings on but am wondering if the wheel weights get in the way of the rings?
Russ Wolfe
Russ Wolfe is offline
PostPosted: Sun May 04, 2008 10:34 am    Post subject: Reply with quote
Wheel weights should not get in the way of trim rings. Not factory, or repops anyway.
Gary: OK. Ima poop.
ocdbeetle
Samba Optimist
PostPosted: Sun May 04, 2008 10:39 am    Post subject: Reply with quote
Thanks Russ - I forgot to put the picture in...arthritis meds kicking in again... Embarassed
Russ Wolfe
PostPosted: Sun May 04, 2008 10:41 am    Post subject: Reply with quote
Those shouldnt mess with the wheel weights.
Gary: OK. Ima poop.
ocdbeetle
Samba Optimist
PostPosted: Mon May 05, 2008 7:06 am    Post subject: Reply with quote
I just realized those trim rings are 8 slot and my rims are 10 slot so thats probably not going to work...I'll keep looking i guess... Smile
67 Florida Deluxe
Samba Purist
PostPosted: Mon May 05, 2008 7:33 am    Post subject: Reply with quote
Trim rings should be anodized aluminum finish (like trim moulding) not shiny chrome
ocdbeetle
Samba Optimist
PostPosted: Mon May 05, 2008 7:39 am    Post subject: Reply with quote
I was wondering what took you so long kent... Very Happy
67 Florida Deluxe
Samba Purist
PostPosted: Mon May 05, 2008 7:47 am    Post subject: Reply with quote
They should be 10 slot trim rings to align with the holes in the wheel. There are 11-slot and 8-slot trim rings, but they are for Ghias and Type 3s
ocdbeetle
Samba Optimist
PostPosted: Mon May 05, 2008 8:49 am    Post subject: Reply with quote
That was my "afterthought" and after browsing the other areas of Samba I found a good link on Beauty rings in the Type 3 section...Didnt know about the anodized versus chrome though...thanks...
ocdbeetle
Samba Optimist
PostPosted: Mon Jun 02, 2008 6:33 pm    Post subject: Reply with quote
Does this crack in the back of the manifold look like a problem? It didnt appear to be affecting anything...
In the next pic is the heat riser "normal" or more clogged than it should be? I hope i get a good camera for fathers day... Very Happy
67type0ne
67type0ne is offline
PostPosted: Mon Jun 02, 2008 6:37 pm    Post subject: Reply with quote
not real sure how a manifold is put together but the aluminum i thought was to hold all the steel tubing together....If so that crack could be a big problem....i have a 1500 that I have tried giving away here on the classifieds but still here Crying or Very sad if you end up needing a manifold let me you can have it next to nothing
mailman
mailman is offline
PostPosted: Mon Jun 02, 2008 6:38 pm    Post subject: Reply with quote
As long as it's already apart, I guess if it was mine I'd be looking for a better manifold. I don't like the looks of the crack, and I'd want the heat riser tubes clearer....
'64 Bahama Blue Beetle / steel sunroof
'64 Bahama Blue Beetle Sedan (future ragtop)
ocdbeetle
Samba Optimist
PostPosted: Tue Jun 03, 2008 6:06 am    Post subject: Reply with quote
thanks - I'll check it out a little more today...
ocdbeetle
Samba Optimist
PostPosted: Tue Jun 03, 2008 1:23 pm    Post subject: Reply with quote
Help! the road draft tube is hitting the lower tin and wont go where it belongs...I put the 2 screws in just to hold the lower tin while I put the gen stand back on...Also is the gen stand gasket oriented correctly?
PostPosted: Tue Jun 03, 2008 10:32 pm    Post subject: Reply with quote
This means you have the wrong oil breather/filler setup to use with those small lower tin pieces.
Generator stand gasket info
http://www.thesamba.com/vw/forum/viewtopic.php?t=240438
From that thread
Glenn wrote:
Robert Bentley says:
ocdbeetle
Samba Optimist
PostPosted: Wed Jun 04, 2008 6:10 am    Post subject: Reply with quote
And the hits just keep on coming...Need to update my entry in the "Previous Owner" thread Crying or Very sad ...Thanks for the info...
Page 3 of 4
