bill may Samba Member
Joined: August 27, 2003 Posts: 14160 Location: san diego,ca
Posted: Wed Jun 04, 2008 6:43 am Post subject: |
| mailman wrote: |
| As long as it's already apart, I guess if it was mine I'd be looking for a better manifold. I don't like the looks of the crack, and I'd want the heat riser tubes clearer.... |
did the welds break joining the metal tubes? the aluminum is to hold heat in heat risers journey of heated air. you can heat and re-fuse the crack if careful. but sometimes the welds crack. _________________ Admin note: Bill Passed away - July, 2017
1965 panel bus-Kermit
"Camping is cheaper than therapy"
www.sv2s.com
www.steeringboxscrapers.net
SBS #100
http://www.thesamba.com/vw/forum/viewtopic.php?t=453617 |
ocdbeetle Samba Optimist
Joined: March 18, 2008 Posts: 1176 Location: South Carolina
Posted: Wed Jun 04, 2008 6:46 am Post subject: |
Seems like the only problem (Other than it being clogged) is the crack along the back...Nothing else seems seperated - no welds broken that i can see... _________________ 1967 Lotus White Beetle |
aircooled Samba Member
Joined: December 02, 2003 Posts: 1316 Location: Heartland, Neb
Posted: Wed Jun 04, 2008 7:34 am Post subject: |
These pictures will give you and idea of the breather pipe arrangement to the tin. The correct pipe will go straight down and not have the bend on the lower portion of the pipe.
Posted: Wed Jun 04, 2008 7:41 am Post subject: |
thank you...it seems the PO was "stuck" in 68...the engine is a 67 for sure though...I've got all the correct tins now so I guess I'll find a correct oil filler...
I was pulling my hair out trying to find an oil leak and the "elbowed" road draft tube was dripping oil on the bottom head tin and dripping it out toward the front (front is front) of the engine...
Is that a rubber seal where the tube goes through the tin? _________________ 1967 Lotus White Beetle |
Posted: Wed Jun 04, 2008 8:15 am Post subject: |
| Yes, there is a rubber seal where the tube goes through the tin. |
Posted: Wed Jun 04, 2008 8:24 am Post subject: |
thank you thank you - thank you _________________ 1967 Lotus White Beetle |
Posted: Mon Jun 09, 2008 10:58 am Post subject: |
I just received the "correct" oil filler tube from a Samba member - We agreed it was a 67 bug 1500 oil filler...The problem is it looks just like the one i need to replace (elbow at bottom)...(not like the one in the ad that I thought i was buying - straight tube)
So - before i pull my hair out - Should my road draft tube have an elbow at the bottom or be straight? I have the elbow tube(hitting the tin) and thought I was buying the straight tube type.. _________________ 1967 Lotus White Beetle |
Posted: Mon Jun 09, 2008 11:33 am Post subject: |
The tube is straight like in the picture I sent, no elbow. The picture I sent is what you need in order for the tin fit right. It is hard to find the right stuff sometimes but it will pay off with you having the peace of mind that is correct. When you start looking for the 67 only stuff you will have even more fun. Hang in there.  |
Posted: Mon Jun 09, 2008 11:55 am Post subject: |
Thanks - Just wanted to make sure before I contacted the seller...I thought your picture was Straight but wanted to double check before I contacted the seller and get my duckies back (or the correct filler)... _________________ 1967 Lotus White Beetle |
Rhunes29 Samba Member
Posted: Mon Jun 09, 2008 3:02 pm Post subject: |
OCD is right
That is a clean engine compartment!!! I should have the pieces you sent tomorrow, I can't wait to install them and update pics. I really owe you!!!!!!!!!!!! I really miss my '67, it was by far my favorite VW. I'll have to wait to see if my new one can take that title some day. |
Posted: Mon Jun 09, 2008 5:56 pm Post subject: |
| Rhunes29 wrote: |
| I should have the pieces you sent tomorrow, I can't wait to install them and update pics. |
Scrounge up some screws for the tin if you havent already...let me know when you get the package... _________________ 1967 Lotus White Beetle |
67 Florida Deluxe Samba Purist
Joined: June 21, 2005 Posts: 7990 Location: Gainesville and Tampa, Florida
Posted: Tue Jun 10, 2008 7:51 am Post subject: |
Oh for God's sake...  _________________ 1967 Lotus White Beetle |
