pan drawing required
hoghead
hoghead is offline
PostPosted: Tue Jun 03, 2008 9:19 pm    Post subject: pan drawing required Reply with quote
Does anyone have a dimensioned drawing of a stock Beetle pan.
CAD is best, but I can live with what is available.
L572
L572 is offline
PostPosted: Wed Jun 04, 2008 9:55 am    Post subject: Reply with quote
The Bentley manuals have a line drawing of a pan showing the locations and routings for the clutch cable, the fuel line, the accelerator and heater cables, and the brake lines.....Would that work for you or are you looking for a precisely scaled drawing?
L572
hoghead
hoghead is offline
PostPosted: Wed Jun 04, 2008 6:48 pm    Post subject: Reply with quote
I am looking for a scaled and detailed engineering drawing with dimensions.
hoghead
hoghead is offline
PostPosted: Sun Jun 08, 2008 10:21 pm    Post subject: Reply with quote
No drawings out there?
djkeev
djkeev is offline
PostPosted: Mon Jun 09, 2008 3:57 am    Post subject: Reply with quote
hi,
I can tell you through much diligent searching that any blue print type drawings with accurate dimensions UNLESS they are for occupant and luggage capacity or the distance the bumper is off the ground type information, this Has not yet been found, at least not by me.
Why do you need these with so much detail? As mentioned the Bentley manual has a fair number of dimensions but nothing like a blueprint.
Good Luck, let us know if you unearth drawings.
Take your body off and make your own if you need them so badly.
Dave
Ghia
Vanagon
Beetle
sammyphsyco
sammyphsyco is offline
PostPosted: Mon Jun 09, 2008 6:54 pm    Post subject: Reply with quote
This is what I have, hope it helps. I can't vouch for the accuracy, I down loaded it along time ago. It's in my gallery as well.
sammyphsyco wrote:
Your just jealous the voices are talking to me
eurodub
eurodub is offline
PostPosted: Mon Jun 09, 2008 7:01 pm    Post subject: Reply with quote
sorry if being off topic, does anyone have a drawing with dimensions for a cart to use to carry the beetle shell around? i am thinking of bolting it by the front two bolts near the panhead, and in the back, near the shock absorbers. the car is still on the pan and it's kinda tricky to do the measurements
thank you Smile
1960 1200 model 117 deluxe ragtop
1976 MK1 Golf
sammyphsyco
PostPosted: Mon Jun 09, 2008 7:15 pm    Post subject: Reply with quote
thank you Smile
PM me if these don't work, everything you want & way way way way way more.
http://rapidshare.com/files/96374779/vwtools1.pdf.html
http://rapidshare.com/files/96374780/vwtools2.pdf.html
http://rapidshare.com/files/96374781/vwtools3.pdf.html
http://rapidshare.com/files/96374782/vwtools4.pdf.html
http://rapidshare.com/files/96374783/vwtools5.pdf.html
HIjack over.
hemifalcon
hemifalcon is offline
PostPosted: Mon Jun 09, 2008 8:43 pm    Post subject: Reply with quote
Sammyphsycho, that rapidshare thing is anything but 'rapid'..
'62 VW Bug Sedan (Ruby Red)
Resto pics> http://smg.photobucket.com/albums/v697/hemifalcon/Bug%20resto/?start=all&paginator=top
memento
memento is offline
PostPosted: Tue Jun 10, 2008 7:55 am    Post subject: Reply with quote
interesting scans on the tooling! thanks a bunch, even if I don't use it - it's still cool.
tcarlos10
tcarlos10 is offline
PostPosted: Mon Apr 18, 2011 8:44 am    Post subject: Reply with quote
Hi, are there more pics of dimensions/measurements of floor pans? like the square bars in it in the front and rear etc.??? it would be a great help.
Aynthm
Aynthm is offline
PostPosted: Tue Apr 19, 2011 3:28 am    Post subject: Reply with quote
Sounds like you want to set up some metal dies to make molds to manufacture pans. It would probably be cheaper to buy a set of pans and go from there. Many of the pans sold are not as original as the real ones. Seat tracks are sometimes off, pedal stop plate holes sometimes missing. Seat belt bottom plate holes missing. Anyway, good luck.
Chris Paterson
Chris Paterson is offline
PostPosted: Tue Apr 19, 2011 7:49 am    Post subject: Reply with quote
like this one?
- Chris
58' PGSG
tcarlos10
PostPosted: Wed Apr 20, 2011 1:38 am    Post subject: Reply with quote
I am trying to rebuild a 65 vw beetle but the dimensions of the gold bars and clearance gives us a headache coz we want it to be that accurate as much as possible. I have that copy already. There are no available floor pans here in the province of the Philippines and it is much cheaper to have it done here than buying in the U.S., hope someone out there has one and willing to help
Aynthm
Aynthm is offline
PostPosted: Wed Apr 20, 2011 3:08 am    Post subject: Reply with quote
What do you mean by "gold bars"?
tcarlos10
PostPosted: Thu Apr 21, 2011 7:15 am    Post subject: Reply with quote
the rectangular shapes in the floor pan that is a size of a gold bar. I just need measurements if you have those
Aynthm
Aynthm is offline
PostPosted: Thu Apr 21, 2011 12:31 pm    Post subject: Reply with quote
8.5"X1.25 at the front or small end (2 gold bars)
10.5X1.25 at the rear or larger end (2 gold bars)
The individual sizes vary because it's tapered to the curve of the sides
of the pan.
Not sure this is what you wanted though?
Mine are all covered with sound deadener, but those are rough sizes.
Maybe you could find an old bug around, a friend, a stranger etc, and measure them first hand.
Look, I just DL the drawing posted above, I will take it to the garage and fill in all the numbers I can in CM. I will scan it and post it again. My wife is from Pampanga and I've been there, I know what you're trying to do and it's a big undertaking. I will get all the numbers I can.
Okey?
Aynthm
Aynthm is offline
PostPosted: Thu Apr 21, 2011 2:13 pm    Post subject: Reply with quote
Scan didn't do well with uploading.
I will post better resolution on link below.
tcarlos10
PostPosted: Mon Apr 25, 2011 3:38 am    Post subject: Reply with quote
Maraming Salamat for your help. I will post the floor pans here soon. I can't thank you enough. It's a big help.
Torq
Torq is offline
PostPosted: Mon Apr 25, 2011 6:54 am    Post subject: Reply with quote
Your dilligence paid off Thomas, then show them how we do it the econo way in the Philippines. It's so expensive if we get the floor pans outside PH, but pinoy ingenuity and craftmanship will always be there . . . for the love of Volkswagen . . Cool Kudos to your '65 bug restoration . .
