spark plugs and things
Al Gilliland
Al Gilliland is offline
PostPosted: Fri May 07, 2004 11:26 am    Post subject: spark plugs and things Reply with quote
Hi everyone
Have just picked up a 1988 westy. Looking to do a tune up on it. What is everyone using for plugs. Are many of you changing the dist on these newer westy's and also better spark plug wires.
Any links on how to flush the radiator and install a new speedometer cable would be appreciated
Cheers
Laughing
AL
dieselvanagon
dieselvanagon is offline
PostPosted: Fri May 07, 2004 12:46 pm    Post subject: Reply with quote
Liar Put good quality stuff in there. Don't skimp. Bosch or othewise is good stuff. DO NOT BUY FROM A VW DEALER unless you wanna pay triple. I found Importauthority to be excellent overnites me the stuff and its good quality and prices are excellent Embarassed
Randy in Maine
Randy in Maine is offline
PostPosted: Fri May 07, 2004 1:42 pm    Post subject: Reply with quote
have you been here?
http://www.vanagon.com Good links to good info.
Deaffy
Deaffy is offline
PostPosted: Fri May 07, 2004 3:25 pm    Post subject: Re: spark plugs and things Reply with quote
Everything you'll need is right here: http://www.busdepot.com/ Dancing
Alan Brase
Alan Brase is offline
PostPosted: Fri May 07, 2004 10:30 pm    Post subject: Reply with quote
Good plan about replacing the wires. Most of mine have been shot after 15 years. do you mean the distributor or the cap? Yes for the cap and rotor. There is no other distributor that will work with this car. Nor do you need to look for one. They are completely up to the needs of this engine. Not to say it's not a good engine, I like them. (I've had 4, only broke 1, but it's run now for 50k miles and still goes over 90.)
Al
69 double cab
molson88
molson88 is offline
PostPosted: Sat May 08, 2004 7:33 am    Post subject: Reply with quote
What a coincidence - my wife and I just bought an '88 Westy (in Calgary) as well! Welcome to the club Smile
Montgomery Auto Parts over in Bowness is a good source of OEM VW parts, and are usually a bit less expensive than the local VW dealers.
http://www.4nparts.com/
