Stove Burner Disassembly / Stove Wrench
rubberdonkeyeye
rubberdonkeyeye is offline
PostPosted: Tue Sep 23, 2008 9:33 pm    Post subject: Stove Burner Disassembly / Stove Wrench Reply with quote
Well, first off... thanks to you all for the info you've contributed to this board. I purchased an '86 westy about two months ago and this board has been invaluable!
So... my stove burners don't seem to be up to snuff and I've hit the wall for ideas so I thought I'd lay down my first post. One of them increases flame to the "low" setting and then immediately starts to dim the flame until it reaches the simmer just pass the "high" setting. The other one also works ok up until the low setting but when you pass that it blows out sometimes blowing some flame out the hole above the burner knob.
I'm pretty certain the tank is full as I've had it done twice. I was suspicious the guy didnt fill it properly the first time so I went back and made sure they filled it till it came out the bleeder. I took some compressed air and blew in the lines where they exit the tank and go up to the stove, and also in the holes above the knobs.. but to no avail!
Any suggestions?
Thanks!
wayne
Alan Brase
Alan Brase is offline
PostPosted: Tue Sep 23, 2008 9:42 pm    Post subject: Reply with quote
I've actually found tiny spider webs in the air mixing area after the valves. Pretty easy to find if you are looking for it. (I've found it on furnace burners too, so it was no surprise.)
Al
Al Brase
Projects: 67 sunroof bug, 67 Porsche 912 Targa, 70 Westy
Dec 1955 Single Cab pickup WANT 15" BUS RIMS dated 8/55, thru 12/55
To New owners: 1969 doublecab, 1971 Dormobile
Vanagons:
80 P27 Westy JUL 1979, 3rd oldest known US
83 1.6TD Vanagon, 87 Wolfie Westy daily driver, swap meet home
Perales
Perales is offline
PostPosted: Wed Sep 24, 2008 4:55 am    Post subject: Reply with quote
You can look inside the burners by rotating the metal cover disk. They are keyed in, so rotate them until they lift off. Now you can look inside the burner itself. I agree with Al, spiders can be a real problem here. If you need to take it apart even further you will need the stove wrench, or something like it. Hopefully you or a PO didn't throw it out thinking it was just detritus.
Stove Wrench
-- 1987 Westfalia automatic (Captain Vino)
rubberdonkeyeye
PostPosted: Wed Sep 24, 2008 7:56 am    Post subject: Reply with quote
Stove Wrench
Thanks for the input guys! I took off the metal covers and blew that out too. Its still not working properly so I guess I'll have to dig a little deeper. Unfortunately the key is long gone... but I'm sure I can rig something.
wayne
Perales
Perales is offline
PostPosted: Wed Sep 24, 2008 8:00 am    Post subject: Reply with quote
The image file is scanned full size at 72 dpi Just print it out and you have a template to cut one out of some thick sheet metal.
markz2004
markz2004 is offline
PostPosted: Wed Sep 24, 2008 8:45 am    Post subject: Reply with quote
maybe I am confused by your description, but it sounds like your knob is set on the valve post incorrectly so when you turn to low you are actually making the valve open wider and getting a larger flame?
87 Westy, 250k GW 2.4 - 2.0 Wink, 16" wheels
ak_runner
ak_runner is offline
PostPosted: Wed Sep 24, 2008 12:53 pm    Post subject: Reply with quote
Thanks for the photo of the wrench, I was wondering what that was for.
AK_Runner
`87 Westy Syncro
MootPoint
MootPoint is offline
PostPosted: Wed Sep 24, 2008 9:44 pm    Post subject: Reply with quote
If you don't have a wrench, it looks as if you could do the same thing with a pair of needlenose pliers, no?
Haven't tried it, tho.
1984 Westy with tencentlife power!
djkeev
djkeev is offline
PostPosted: Sat Oct 07, 2023 6:56 am    Post subject: Re: stove burner funkyness Reply with quote
I recently got a Westy Stove and also picked up the GoWesty Stove Wrench.
https://gowesty.com/products/stove-wrench-for-vanagon-westfalia?_pos=2&_sid=82a202fd3&_ss=r
I am unsure of the wrenches use.
I found this old thread which mentions using the wrench but no details.
I am guessing that if I unscrew a burner it will become self evident if cleaning or repairs are called for and how to do so?
Dave
Ghia
Vanagon
Beetle
djkeev
djkeev is offline
PostPosted: Sat Oct 07, 2023 9:21 am    Post subject: Re: stove burner funkiness / Stove Wrench Reply with quote
There was a pause in the rain so I went out with the Stove Wrench.
Here is the burner inside, there are two slots, obviously the wrench fits in these slots........
But turning it?
No Go......... the wrench tabs began to bend.
I was turning counter-clockwise.......... that is normal in most mechanical construction items. But then again, propane tanks have a counter clockwise thread on them........
I'll need to revisit this with a brass drift and a hammer, see if I can knock it loose.
Meanwhile...... what is this screw for?
Ghia
Vanagon
Beetle
kamzcab86
kamzcab86 is offline
PostPosted: Sat Oct 07, 2023 11:17 am    Post subject: Re: stove burner funkiness / Stove Wrench Reply with quote
But turning it?
IIRC from when I removed the pots to polish them, the lock pin at 6:00 needs to be removed first. Or, does it move with the assembly up to the 3:00 position, then gets pulled out? Think Can't remember.
Mounts pot to stove base.
2016 Golf GTI S
MsTaboo Premium Member
MsTaboo is offline
PostPosted: Sat Oct 07, 2023 11:20 am    Post subject: Re: stove burner funkiness / Stove Wrench Reply with quote
It's been a few years since I rebuilt the stove on mine, but here are a couple pics I have on hand.
IIRC you have to press down a bit while turning the collar. Of course it's old, so give a couple squirts of PB Blaster.
The screws just hold the burner to the main bits.
EDIT.
Ah, yes, forgot about that!
Currently:
djkeev
djkeev is offline
PostPosted: Sat Oct 07, 2023 11:21 am    Post subject: Re: stove burner funkiness / Stove Wrench Reply with quote
kamzcab86 wrote:
But turning it?
That was a question I forgot to ask!
What is the steel pin for?
Thanks for the response Kam!
I'll pull that pin and see if the nut turns.
Ghia
Vanagon
Beetle
djkeev
djkeev is offline
PostPosted: Sat Oct 07, 2023 11:24 am    Post subject: Re: stove burner funkiness / Stove Wrench Reply with quote
Great photo!
That really helps a lot!
I don't see that steel pin in your photo but I do see a notch for it in the collar.
Ghia
Vanagon
Beetle
MsTaboo is offline
PostPosted: Sat Oct 07, 2023 11:34 am    Post subject: Re: stove burner funkiness / Stove Wrench Reply with quote
djkeev wrote:
Great photo!
Yep, strange, I usually make sure all the relevant screws, etc. are with the parts.
Went back to my photo collection and found the missing lock pins in this picture.
Not sure why I had them grouped like this, but it was a quickie shot.
Currently:
djkeev
djkeev is offline
PostPosted: Sat Oct 07, 2023 11:36 am    Post subject: Re: stove burner funkiness / Stove Wrench Reply with quote
Not the greatest photo but your photo shows a pressure regulator under the cook top, mine ..... a beige and brown unit ....... just has the pipe from the gas tank, a straight feed in.
Must be a modification to the newer stoves.
I'm guessing that mine is what 1985/84 to 1987?
The label.......
Ghia
Vanagon
Beetle
djkeev
djkeev is offline
PostPosted: Sat Oct 07, 2023 11:39 am    Post subject: Re: stove burner funkiness / Stove Wrench Reply with quote
The photos are priceless!
Thanks!
I wasn't going to take a drift to the collar until I heard back from someone...... I really hate forcing stuff and thought that there just might be a "trick" to removing this puppy.
Ghia
Vanagon
Beetle
MsTaboo is offline
PostPosted: Sat Oct 07, 2023 12:18 pm    Post subject: Re: stove burner funkiness / Stove Wrench Reply with quote
Thanks!
You're welcome.
I always try to take a bunch of pictures when I take stuff apart. Not always the ones I later need Confused Laughing .
In the post above I said maybe you need to press down while turning the collar, I think I was mixing that up with the spring lock pins Kamz mentions. Once the pins are out I think it just turns freely.
I looked at the date on those pictures, they're from 2013. My memory is starting to fail Crying or Very sad .
Interesting about the extra pressure regulator on the newer model stoves.
I'm guessing the regulators on the tanks must have been different?
Currently:
djkeev
djkeev is offline
PostPosted: Sat Oct 07, 2023 1:24 pm    Post subject: Re: Stove Burner Disassembly / Stove Wrench Reply with quote
Well, I went out and pulled the locking tab.......(you can see it sitting on the burner)
But....... no joy in mudville.
The wrench began to bend again so I flooded the recess with PB Blaster.
I'll let it soak in over night and see if anything loosens up.
Ghia
Vanagon
Beetle
djkeev
djkeev is offline
PostPosted: Sat Oct 07, 2023 2:16 pm    Post subject: Re: Stove Burner Disassembly / Stove Wrench Reply with quote
Looking at the photos more closely.......
There are no threads.
The locking collar has two slots at 180° That need to align with the lower burners tabs?
Am I correct to guess that I need to pull that screw holding the upper burner half in position and the entire upper burner rotates with the collar?
Or
Does the collar rotate within the upper burner? Leave the two halves screwed together?
What exactly does that locking pin engage with?
Ghia
Vanagon
Beetle
