Accelerator cable rubbing against transmission
quartermilecamel
quartermilecamel is offline
PostPosted: Fri Jun 13, 2008 11:35 am    Post subject: Accelerator cable rubbing against transmission Reply with quote
Hello, 1964 bus. I was following the accelerator thread and thought I would check my transmission for rubbing marks. Sure enough the accelerator cable is rubbing against it. Whats the fix? file down tranny. Bend cable. bend guide tube?
WM971252
WM971252 is offline
PostPosted: Fri Jun 13, 2008 11:54 am    Post subject: Reply with quote
The original guide tube is flexible type the will not "bend" and hold the same position. As I can not find may original tubes I use old fuel hose myself. With the "sleeve" it will not "cut" into the tranny.
quartermilecamel
PostPosted: Fri Jun 13, 2008 12:17 pm    Post subject: Reply with quote
Um well if there is supposed to be a rubber guide tube then I dont have that. Ive always had issues with the throttle not returning enough. I put a spring up front the keep the pedal at maximum.
j.pickens
j.pickens is offline
PostPosted: Fri Jun 13, 2008 1:16 pm    Post subject: Reply with quote
Yeah there should be a tube, I missed getting an accelerator cable bowden tube at the OCTO by seconds. That would solve the problem.
Here's one from CIP1 for $19
http://www2.cip1.com/ProductDetails.asp?ProductCode=VWC-131-721-551
BeaterBarndoor wrote:
Red Fau Veh wrote:
Stocknazi
Stocknazi is offline
PostPosted: Fri Jun 13, 2008 6:01 pm    Post subject: Reply with quote
i'll second using the fuel line. until you get a bowden tube push a piece of 1/4 inch line onto the cable tube, works fine. good use for older fuel line you have replaced on your bus.
WANTED:
Thomas Jefferson
Eric&Barb
Eric&Barb is offline
PostPosted: Fri Jun 13, 2008 6:41 pm    Post subject: Reply with quote
http://www.type2.com/archive/vintagebus/064591.html
In Stereo, Where Available!
quartermilecamel
PostPosted: Sat Jun 14, 2008 12:23 pm    Post subject: Reply with quote
Well I looked at the cip1 tube...19.95. 25 bucks minimum order. If there is a place that sells one that I can order with out having to order extra shit that would be great
j.pickens
PostPosted: Sat Jun 14, 2008 5:01 pm    Post subject: Reply with quote
I think that's a standard West Coast Metric part, if you have an import shop in the area, they could order it for you and save on the shipping.
Red Fau Veh wrote:
quartermilecamel
PostPosted: Sun Jun 15, 2008 2:25 pm    Post subject: Reply with quote
why yes I do have a local import store. And if your lucky, they might actually be able to get a vw part for you. You would think they would be able to get you a long block....nope. I will have to go to the next town over to get the tube ..if they have it.
ToolBox
ToolBox is offline
PostPosted: Sun Jun 15, 2008 5:49 pm    Post subject: Reply with quote
Call Euclid for the parts you need.
6D2
SBS Hit Squad
6D2 is offline
PostPosted: Sun Jun 15, 2008 6:34 pm    Post subject: Reply with quote
I used an old e-brake bowden tube for mine..
Chris
The SBS #62
Red Hot Ad Specialties & Stuff...
Shirts and hoodies for shows or clubs.. we ship world wide...
www.pottymouthpromos.com
View user's profile Send private message Send e-mail Visit poster's website MSN Messenger Gallery Classifieds Feedback
quartermilecamel
PostPosted: Mon Jun 16, 2008 12:20 am    Post subject: Reply with quote
Well wow I didnt know there was a foreign place in cleveland. I wonder what all they sell. Will have to call them.
Andrew
Andrew is offline
PostPosted: Mon Jun 16, 2008 11:55 am    Post subject: Reply with quote
I just went to Lowe's and got some tubing that was just barely big enough for the end of the throttle cable to pass through. It was 1/4" nylon if I remember correctly. Don't really remember. I bought it like 5 years ago. The shortest length they sold was like 25 feet, but I've been slowly using it up on random stuff for the past 5 years. And I think it was only like 5 or 10 bucks, too. It's not the correct part, but it essentially does the same thing and has worked fine for me so far.
-Andrew
Culito
11010101
Culito is offline
PostPosted: Mon Jun 16, 2008 3:01 pm    Post subject: Reply with quote
That's basically what I did - I found some black somewhat-flexible PVC tubing just a bit bigger than the end of the acc. cable end. stuck one end of the tube in the metal outlet where the cable comes out of the body. Works just fine...
© CJ Industries, Inc.
'64 standard w/2.0L type 4
'62 bug
johnnypan wrote:
runderwood
runderwood is offline
PostPosted: Tue Jun 17, 2008 8:01 am    Post subject: Reply with quote
I used a bit of metal brake line... can pick it up anywhere... and if you are missing the piece that goes thru the fan shroud as well, pick up a piece of the next size down as well, and when you cut off the end to make it the right length, it will slip right inside the other for a nice snug fit... of also, the larger size i used to route it around the trans fit perfectly over the tube coming out of the frame as well.... on the downside... it is not flexible... i don't know how important it is that this is a flexible tube... i like the metal line since it can be slightly bent to ensure it doesn't rub on anything...
61 DD Panel
nicko
nicko is offline
PostPosted: Tue Oct 21, 2008 12:38 am    Post subject: early tranny guide Reply with quote
Is the early style wire bracket mentioned in the above link used on a split case tranny- Nov 58 bus??
cdennisg
cdennisg is offline
PostPosted: Tue Oct 21, 2008 8:36 am    Post subject: Re: accelerator cable rubbing against transmission Reply with quote
Which thread were you watching about accelerator cables? I want to read it.
...And does anyone have a pic of what the wire mount looked like on the earlier trannies? I did a search, but I am mostly computer dysfunctional.
BarryL Premium Member
BarryL is offline
PostPosted: Wed Oct 22, 2008 1:03 pm    Post subject: Re: accelerator cable rubbing against transmission Reply with quote
It was rubbing so I put on the wire clip. Then I added the tube and just left the clip there with tye-wraps which kept the tube from sagging. Normal would be the accelerator wire going through the clip by itself.
cdennisg
cdennisg is offline
PostPosted: Wed Oct 22, 2008 1:14 pm    Post subject: Reply with quote
Thanks for that. Another thing on the to-do list for the winter.
KevinAlbrecht
Location: Ocean City > Boca > Pompano > Kirkland > Eugene > Sarasota
KevinAlbrecht is offline
PostPosted: Sun Jun 02, 2013 3:09 pm    Post subject: Reply with quote
Gave a first try at installing my Bowden tube today. it's incredibly tight (and dirty).
Kevin Albrecht
1963 Panel
Don't forget those seat-belts!
Click to view image
