Upper bunk weight limit?
50 Kafer
50 Kafer is offline
PostPosted: Wed Oct 29, 2008 8:23 pm    Post subject: Upper bunk weight limit? Reply with quote
Is there a listed weight limit for the upper bunk on vanagon westy's?
John
1950 Kafer Deluxe (10/50)
1955 Beetle Deluxe (6/55)
1968 Beetle (11/67)
1982 Westy
1986 Cabriolet (6/86)
WTB Air-Camping roof top mount http://www.thesamba.com/vw/classifieds/detail.php?id=1499947
tikibus
tikibus is offline
PostPosted: Wed Oct 29, 2008 8:26 pm    Post subject: Reply with quote
This post could get wrong real fast Laughing
Depends on watcha doin'...
I see bacon frying... Embarassed
Happy Trails!
Mark
______________
Founding member of the Empire State VW Camping Club.
http://www.empirevwcamping.org/
1984 Westy - Tiki
1997 Honda Civic -The Green Hornet
1971 Volvo P-1800E- needs TLC
50 Kafer
50 Kafer is offline
PostPosted: Wed Oct 29, 2008 8:34 pm    Post subject: Reply with quote
I knew someone would twist it but lets keep it civil.
John
1968 Beetle (11/67)
1982 Westy
Zero419
Zero419 is offline
PostPosted: Thu Oct 30, 2008 4:21 am    Post subject: Reply with quote
I have slept up there with a combined weight of 360lbs.
1987 Westy Auto Bostig 2.0 Ztec
j_dirge
j_dirge is offline
PostPosted: Thu Oct 30, 2008 10:15 am    Post subject: Reply with quote
No spec I know of.
The bunk platform in my 89 flexes considerably under my 210 lbs.
My 81 would creak and groan.. My 72 felt like I could park a truck on it.
I'd not sleep two large adults up there.. but I have no qualms about two kids... two smallish adults. maybe 300lbs max.
Not worried about breakage.. worried about stress to materials and fasteners.
airkooledchris
airkooledchris is offline
PostPosted: Thu Oct 30, 2008 11:46 am    Post subject: Reply with quote
you can put 350 or so up there no problemo.
it will flex though, and will scare the hell out of someone sleeping below when you change positions.
It seems to be to be mostly that extension part, not so much the larger main section at the rear of the poptop - that makes the most noise when you have some weight up there. it seems like it could use one more brace to just keep it from flexing... or maybe cut a thicker chunk of wood to use as that section?
djbside
djbside is offline
PostPosted: Thu Oct 30, 2008 12:10 pm    Post subject: Reply with quote
On the under side of the fold out section, you could mount you a Pipe Flange... Then just fold out the top bunk, and screw in a section of steel pipe as a leg. I'm sure one would do the trick, but if you did 2, out on the edge you could figure out a way to make it double as not only a support but also a ladder for kids and drunk adults to get in and out of the top bunk easier.
I have a rough image of what it could look like on the cocktail napkin I call my brain.
Brandon...'83 Westy "Rose"
aswah
aswah is offline
PostPosted: Thu Oct 30, 2008 12:31 pm    Post subject: hmm Reply with quote
what about putting a metal bar across the fold out section of the top bunk to support excessive weight?
WIT WA DA DA (Peace and Unity)
Aswah, Lisa, Beaumont and Loose Lucy Too!
1989 Westy
2013 Jetta Sportswagon TDI
dart330
dart330 is offline
PostPosted: Thu Oct 30, 2008 2:59 pm    Post subject: Reply with quote
I have had over 500 pounds of people sleep up there no problem. It does bow a bit, but wasn't anything to worry about.
View user's profile Send private message Send e-mail Twitter Gallery Classifieds Feedback
noganav
noganav is offline
PostPosted: Thu Oct 30, 2008 3:19 pm    Post subject: Reply with quote
I swapped mine out for 5/8" thick pieces of Baltic Birch. Looks great and is solid as a rock now. The only creaks and groans are from me hauling my 230 pound butt up there. Wink
floggingmolly
floggingmolly is offline
PostPosted: Thu Oct 30, 2008 3:56 pm    Post subject: Reply with quote
And I thought my wife and I at a TOTAL of 360 was high! That 500 must have been a comfy sleeping arrangement...
'85 Wolfsburg Weekender
Westy Steve
Westy Steve is offline
PostPosted: Fri Oct 31, 2008 11:24 am    Post subject: Re: Upper bunk weight limit? Reply with quote
I remember the first time I was inside a Westy, I asked a guy if the upper bunk would hold my weight.
His response: "I had two girls up there with no problems"
My response: "You are a GOD to me!"
aswah
aswah is offline
PostPosted: Sat Nov 01, 2008 5:21 am    Post subject: reason alone Reply with quote
wow, look where this post went...
two girls up top... reason enough to buy one...
ASWAH
1989 Westy
Perales
Perales is offline
PostPosted: Sat Nov 01, 2008 10:15 am    Post subject: Reply with quote
This is starting to sound a bit like the old "How many people can you cram into a VW" kind of thing. Time for an updated challenge, perhaps...
-- 1987 Westfalia automatic (Captain Vino)
shagginwagon83
shagginwagon83 is online now
PostPosted: Thu Apr 28, 2022 8:12 pm    Post subject: Re: Upper bunk weight limit? Reply with quote
I do need to upgrade my wood Rolling Eyes
Talking about the 5/8” birch
Howesight
Howesight is offline
PostPosted: Thu Apr 28, 2022 9:42 pm    Post subject: Re: Upper bunk weight limit? Reply with quote
I doubled up the steel U-channel attached to the edge of the fold-out panel, leaving the the stock plywood. This made a HUGE improvement.
Hint: The tracks sold at Home Depot for garage shelving are the perfect fit for this mod. They now sell a few different brands which might have a different size or profile, so bring your measurements with you or better yet, the U-channel from your Westy to slip the Home Depot U-channel over the Westy U-channel.
See here:
https://www.homedepot.com/p/ClosetMaid-Maximum-Load-48-in-Silver-Shelving-Standard-3585/100182923
I dabbed spots of MIG-weld on mine and it's very strong. Then painted the correct Westy grey.
'86 Syncro Westy SVX
djkeev
djkeev is offline
PostPosted: Fri Apr 29, 2022 3:58 am    Post subject: Re: Upper bunk weight limit? Reply with quote
It is my observation that those among us who carry a few more pounds than is "average" will probably not be able to hoist themselves into the upper bunk to test its load capacity.
Dave
Ghia
Vanagon
Beetle
dobryan
dobryan is offline
PostPosted: Fri Apr 29, 2022 5:53 am    Post subject: Re: Upper bunk weight limit? Reply with quote
Dave
My son has grown up camping in our '87 westy. From a toddler to a 19 year old very large man.
He still uses the top bunk when we camp.
He is about 6'7" 340 lbs.
He can sit on the edge of the top bunk platform and it bends maybe an inch but goes right back to level after he lays down. I can attest that the stock platform is way stronger than you imagine. Shocked
Dave O
The Western Syncro build
dabaron
dabaron is offline
PostPosted: Fri Apr 29, 2022 12:29 pm    Post subject: Re: Upper bunk weight limit? Reply with quote
i have spent a not insignificant amount of time in the top bunk. i weigh more than a duck, less than a gorilla. no issues.
1991 Vanagon GL Camper
Red Ryder
Red Ryder is offline
PostPosted: Fri Apr 29, 2022 2:22 pm    Post subject: Reply with quote
????? Rolling Eyes
“Most everyone’s mad here. You may have noticed I am not quite all there myself.” — Cheshire Cat, Adventures of Alice in Wonderland
“Scarlett” — 1990 Vanagon Carat Wolfsburg Edition (Tornado Red)
“Nigel” — 1999 Jaguar XK8 convertible (Alpine Green Metallic)
