Zenith Carb
Page: 1, 2, 3 ... 18, 19, 20  Next
nukeworker
nukeworker is offline
PostPosted: Sun Apr 12, 2009 7:47 pm    Post subject: Zenith Carb Reply with quote
Hi. Just bought a Zenith 32 NDIX. I don't know squat about Zeniths except Jeff Hibbard says they're great. I'm looking for information/help. Anyone know web sites, books, anything where I can learn from. I've done some internet searching and all I can find is a couple of places that refurbish them. I want to know how to install, adjust, etc. Thanks.
QRP
QRP is offline
PostPosted: Sun Apr 12, 2009 7:53 pm    Post subject: Reply with quote
Hey nuke just give me a call I will PM you my #
baja1967
baja1967 is offline
PostPosted: Sun Apr 12, 2009 8:52 pm    Post subject: Reply with quote
Ditto. I'll help any way I can. Wouldn't run anything else!!!!
thefladge
thefladge is offline
PostPosted: Sun Apr 12, 2009 9:50 pm    Post subject: Reply with quote
Who still sells parts for the Zenith?
1957 Vintage Baja Bug.
2110cc engine, 40 IDF Webers on Gene Berg manifolds, Engle 110 cam, Bugpack 40×35.5 Street Pro Heads, W8CC plugs, 12.5 pound Flywheel, Kennedy 1700 pound pressure plate.
baja1967
baja1967 is offline
PostPosted: Sun Apr 12, 2009 9:55 pm    Post subject: Reply with quote
I just about always stumble on them. I have a bin of jets, linkages, and spare parts. I also have a complete carb for a spare. I get my rebuild kit from my local vw shop, Relic VW Parts.
JonF
JonF is offline
PostPosted: Sun Apr 12, 2009 10:16 pm    Post subject: Reply with quote
i also have a zenith 32 ndix. i havent got around to putting it on the baja yet because i am unsure of how to tune it. so please tell guys any tips you might have on tuning them.
68 bug 1600sp 30/31
68 baja 1600sp 010 32ndix
nukeworker
PostPosted: Mon Apr 13, 2009 5:12 am    Post subject: Reply with quote
Thanks Guys. I will take you up on those pms after I install it. My was missing a return spring. Ordered a couple last night from some Porsche parts place.
zancat
zancat is offline
PostPosted: Mon Apr 13, 2009 6:35 am    Post subject: Reply with quote
I have a set of duals I am thinking about fixing up but had the same questions. How big of a motor would these work well with?
Zancat
Desert-Craft inc.
www.desert-craft.com
Pro-Tools Dealer
XxonValdez
XxonValdez is offline
PostPosted: Mon Apr 13, 2009 8:45 am    Post subject: Reply with quote
I was curious too, I have three sets of venturis, 32-24's, 32-28's, and a set of 32-25's?? never heard of these anyone have any input?
nukeworker
PostPosted: Mon Apr 13, 2009 8:08 pm    Post subject: Reply with quote
If you google Zeniths you don't find a lot, but if you google it, then click on images up top, it links to some good sites. Here's one with some tuning tips.
http://images.google.com/imgres?imgurl=http://www....N%26um%3D1
QRP
QRP is offline
PostPosted: Mon Apr 13, 2009 8:26 pm    Post subject: Reply with quote
Hey nuke I posted some pics of the brackets in the off road gallery.
nukeworker
PostPosted: Mon Apr 13, 2009 8:36 pm    Post subject: Reply with quote
Nice. Thanks. Cool
1970DARKNESS
1970DARKNESS is offline
PostPosted: Mon Apr 13, 2009 9:32 pm    Post subject: Reply with quote
i run a zenith too i could not find anyone who had smaller jets for it so my friend and i soldered them shut and redrilled them a bit smaller. worked good for me but it is still a little rich but not bad. It had jets on it to feed a 2332cc and i have a 1600dp. A little overkill on fuel.
Green bug Guy
Green bug Guy is offline
PostPosted: Tue Apr 14, 2009 11:05 am    Post subject: Reply with quote
ayy diet danny P, alisa got one of them bad boys in compleat! manifold and all. thought id let you know so you can go swoop that thing up like all the other ones you find!
baja1967
baja1967 is offline
PostPosted: Tue Apr 14, 2009 6:38 pm    Post subject: Reply with quote
I'll call her tomorrow......
perrib
perrib is offline
PostPosted: Tue Apr 14, 2009 7:31 pm    Post subject: Reply with quote
Make sure you have functional preheat for the manifold. Use an aluminium one if you can. They can be jetted for almost any size engine. Bigger engines give up top end. Mine is on a 2180 with a WEB VZ 30 style cam. The 356 registry has detailed rebuild instructions.
nukeworker
PostPosted: Tue Apr 14, 2009 7:39 pm    Post subject: Reply with quote
Aluminum manifold? Do you know if the stock solex heater tubes would fit the zenith manifold?
perrib
perrib is offline
PostPosted: Tue Apr 14, 2009 8:30 pm    Post subject: Reply with quote
They don't.
perrib
perrib is offline
PostPosted: Tue Apr 14, 2009 8:52 pm    Post subject: Reply with quote
Aluminium intake
You might be able to adapt progressive weber preheat tubes.
Preheat I added to a Tri Mil. Made from 1/2 tube and pre heat block offs.
QRP
QRP is offline
PostPosted: Tue Apr 14, 2009 9:34 pm    Post subject: Reply with quote
the only aluminum manifolds I have seen are the plenum type.
stick with the divided intake for a small motor like you'rs
Page 1 of 20
