Looking For Oil Filler Neck Grommet.....
BUGSTUFF
BUGSTUFF is offline
PostPosted: Fri May 22, 2009 9:56 am    Post subject: Looking For Oil Filler Neck Grommet..... Reply with quote
Hey All,
I'm looking for the oil filler neck grommet that goes around the neck where it goes thru the tin.
'79 Westy
OEM part # is 021 119 953
-or-
021 119 958
I cleaned up the old one as best as possible but it is still kind of hard to read the number.
Tried Bus Depot and Bus-Boys to no avail.
Anyone???
Thanks in advance!!! Very Happy
Kirk
Northeast IL VW Association - www.nivaclub.org
www.facebook.com/nivaclub
Volkswagen Club of America - www.vwclub.org
RZAR
RZAR is offline
PostPosted: Fri May 22, 2009 10:31 am    Post subject: Reply with quote
I've been looking for this part also. On Ratwells site its says its NLA.
Randy in Maine
Randy in Maine is offline
PostPosted: Fri May 22, 2009 1:45 pm    Post subject: Reply with quote
A piece of vacuum line sliced down the middle and secured with an adhesive will get you through until you find one.
Mike C
Mike C is offline
PostPosted: Fri May 22, 2009 2:54 pm    Post subject: Reply with quote
I've been looking for one as well for my '70. Randy--thanks for the tip.
Bone stock 1970 non-walkthrough "Station Wagon" bus
[quote="1977_L63H_P27"]As mentioned before, it's a 9-passenger Deluxe. The true "station wagon" of buses.
VDubTech
VDubTech is offline
PostPosted: Fri May 22, 2009 4:13 pm    Post subject: Reply with quote
Unless you're running a TYpe 4 motor, your '70 doesn't have one.
First Trip in the RustyBus:
http://www.thesamba.com/vw/forum/viewtopic.php?t=279077&highlight=
borninabus wrote:
a measurement of your rod would be extremely useful.
notchboy wrote:
my dad wasnt a belittling cock when he tought me how to wrench on cars.
One photo = good for reference.
10 photos = douchebaggery
rcnotes
rcnotes is offline
PostPosted: Fri May 22, 2009 7:53 pm    Post subject: Reply with quote
I knew I should have taken some pics before I reinstalled it.
I found a rubber boot that looks like it's for a shifter tube (underneath) or some kind of shaft or tube. It had three distinct bulbous sections from about 2" diameter at the bottom and 1/2" exit hole at the top. I cut the top 1/3rd wide enough to slip over the fill tube and fit through the hole through the tin.
It takes a lot of "shopping" the online VW vendors to find reasonable facsimiles of the odd rubber bits. Some are for other VW's and others from (gasp) non-German vehicles.
Mike C
Mike C is offline
PostPosted: Fri May 22, 2009 9:19 pm    Post subject: Reply with quote
Thanks for clearing that up for me VDub Tech. I feel kind of silly Embarassed I noticed this little hole and thought that a grommet is needed in there. Does the hole need to be sealed? If so, what is missing?
RZAR
RZAR is offline
PostPosted: Fri May 22, 2009 9:20 pm    Post subject: Reply with quote
Exactly what I did.
VDubTech
VDubTech is offline
PostPosted: Fri May 22, 2009 9:37 pm    Post subject: Reply with quote
Good idea, those are shift rod bellows, one on each end of the rear shift rod. Here's a brand new one in my box o' parts for the '79 Westy.
1975 Kombi
1975 Kombi is offline
PostPosted: Sat May 23, 2009 6:27 pm    Post subject: Reply with quote
Here's a MK2 wiring harness grommet through the firewall.
Brett
“He’s decieving you boy! Reach into his pocket and take what he’s got.” Mr. Crabbs.
75 Westy auto
03 Jetta TDI
71 SB
74 Westy
2011 Touareg TDI
2001 NB TDI
Licensed pilot (single engine land VFR)
Rust In Pieces: 72 Bug, 73 Bug, 81 Rabbit LS D 2D, 83 Rabbit D 2D, 84 Jetta TD GL, 85 Jetta D, 68 Z28 RS 302, 91 Passat 16v
