EDragnDean Samba Member
Joined: July 13, 2005 Posts: 1151 Location: Vancouver, WA
Posted: Sat Jul 18, 2009 10:30 pm Post subject: Rekey Ignition switch |
| Short version. Send an ignition to Gabe for a rekey. Rekey works great, ignition switch does not. I have another switch... question is how do you remove the cylinder on the ignition switch? I would assume I could then just swap the guts, problem solved. |
Bruce Samba Member
Joined: May 16, 2003 Posts: 17699 Location: Left coast, Canada
Posted: Sat Jul 18, 2009 11:25 pm Post subject: Re: Rekey Ignition switch |
| EDragnDean wrote: |
| ....Send an ignition to Gabe for a rekey. Rekey works great, ignition switch does not. ...... |
Didn't he test it? _________________
| overheard at the portland Swap Meet... wrote: |
| ..... a steering wheel made from a mastadon tusk..... |
glutamodo  The Android
Joined: July 13, 2004 Posts: 26640 Location: Douglas, WY
Posted: Sat Jul 18, 2009 11:33 pm Post subject: |
I switched my cylinder from one switch to another on my 62 once. But it's been so long now that I can't remember what I did to get that small retaining clip off the end of it. Maybe just tapped on it with a punch/hammer. I just searched the Gallery and found Bruce's photo of an older switch!
Posted: Sun Jul 19, 2009 6:49 am Post subject: Re: Rekey Ignition switch |
| Bruce wrote: |
| EDragnDean wrote: |
Didn't he test it? |
Have never had an issue with Gabe. Tumblers turn (his task) but ignition switch won't engage the starter, acc works. Put the original (after market ignition switch) back in and it works fine. Therefore, bad switch. |
Posted: Sun Jul 19, 2009 6:51 am Post subject: |
| glutamodo wrote: |
Thanks Glutamodo, that makes sense. Looking at the ignition, it has got to be damn near impossible to get the clip off that cylinder. |
Bruce Samba Member
Posted: Sun Jul 19, 2009 2:29 pm Post subject: |
I use an old dental pick. _________________
Posted: Sun Jul 19, 2009 2:42 pm Post subject: |
| I can't remember how I got mine off now, but to put it back on, I recall that I used a hollow drift or made something similar out a piece of metal pipe, to pop it back on. |
