Dano214 Samba Member
Joined: November 19, 2008 Posts: 35 Location: Lake Elsinore, Ca
Posted: Sat Aug 08, 2009 4:34 pm Post subject: Ball joint clearance??? |
I have 66 that i have drop spindles on a adjustable narrowed beam, the passenger lower ball joint is rubbing the rim if i lower the car to much or if i hit a good bump going down the road. The driver side has no issues with this. I don't know what would cause this or how to fix this. Any ideas?  |
Hotrodvw Samba Member
Posted: Sat Aug 08, 2009 5:16 pm Post subject: |
Do a search.............I've seen many topics like this one. _________________ '67 Sunroof
Eric
78x94 with IDA's....oober fun
Horsepower is an addiction........Addictions cost
lots of money!
Hose & Fittings |
Vee Dub Nut Samba Member
Joined: April 25, 2004 Posts: 1196 Location: Dallas, GA
Posted: Sat Aug 08, 2009 5:40 pm Post subject: |
+1
time to bust out the grinder or get you some wheel spacers _________________ Fightin' Texas Aggie Class of 2006
67 Beetle (TBD)
74 Transporter (EJ25 Swapped) - Build Thread: https://www.thesamba.com/vw/forum/viewtopic.php?t=...mp;start=0
See all my VW pics on Instagram @ vee_dub_nut |
Posted: Sat Aug 08, 2009 6:38 pm Post subject: |
| What do you grind? the ball joint? |
Posted: Sat Aug 08, 2009 6:42 pm Post subject: |
I ended up doing both on mine..
All I had to do was grind a bevel into the front side of the lower leading edge of the lower trailing arm. That and the 3/8" spacers did the trick. _________________ Fightin' Texas Aggie Class of 2006
67 Beetle (TBD)
jhicken Samba Member
Joined: October 24, 2003 Posts: 9480 Location: Fallbrook, CA
Posted: Sat Aug 08, 2009 11:06 pm Post subject: |
This my sound stupid but were does the spacer go.....  |
Jerry Hundley Samba Member
Joined: April 20, 2006 Posts: 1181 Location: Chester, Va
Posted: Sun Aug 09, 2009 5:58 am Post subject: |
| Dano214 wrote: |
between the drum and the rim _________________ Jerry Hundley (AKA Slammed 66)
Because Stock Sucks!!!!
70 baywindow deluxe
65 slammed bug
69 bug
64 drag buggy |
Airkewld Samba Member
Joined: November 14, 2003 Posts: 3200 Location: Goodyear, AZ USA
Posted: Sun Aug 09, 2009 9:25 am Post subject: |
Pete has a good idea if you have a reputable machine shop around...
This issue seems to be heavily depended on who made the wheels. Its hit or miss between brand and styles of wheels on if people have clearance problems or not.
From my experience the 3/8" spacers will just nearly take care of the entire problem. I still had a little bit of scratching when hard cornering hard on my car, and that's why I busted out the grinder on the trailing arms. Before people start freaking out about grinding on things, I only took a little bit of material out to chamfer the lower leading edge of the trailing arm. I'm only talking an 1/8 of an inch or less. _________________ Fightin' Texas Aggie Class of 2006
67 Beetle (TBD)
tacky Samba Member
Joined: April 21, 2004 Posts: 578 Location: highways of agony, va.
Posted: Mon Dec 12, 2022 3:54 pm Post subject: Re: Ball joint clearance??? |
Clearance it yourself using a dissembled ball joint shaft in an electric drill and some valve grinding compound _________________ "Everyone reading this is a PO." |
Posted: Mon Dec 12, 2022 7:07 pm Post subject: Re: Ball joint clearance??? |
| tacky wrote: |
| Clearance it yourself using a dissembled ball joint shaft in an electric drill and some valve grinding compound |
Do you know you just responded to a 13 year old post. I'm sure the original poster has figured out a solution by now. _________________ Der Kleiner Kampfwagens |
