SSWesty Samba Member
Joined: August 20, 2008 Posts: 735 Location: Bellevue
westylife Samba Member
Joined: October 28, 2007 Posts: 410 Location: Anchorage, Alaska
floggingmolly Samba Member
Joined: April 06, 2007 Posts: 1106 Location: San Diego, CA
Posted: Tue Aug 11, 2009 3:01 pm Post subject: |
I don't get that...if the dust seals don't fit the Girling (which I have), what's the point? What if my dust seals are bad? _________________ '85 Wolfsburg Weekender |
JunkYarDog Samba Member
Joined: March 11, 2007 Posts: 676 Location: New Mexico
Posted: Thu Oct 22, 2009 3:53 pm Post subject: |
Bumped again This is a job I'm doing now too. I have the dual piston girling calipers to work on.
As for the paste, someone correct me if this is wrong. I had a German mechanic tell me to lightly lube the pistons with copper paste before I load them back into the cylinder.
| floggingmolly wrote: |
| I don't get that...if the dust seals don't fit the Girling (which I have), what's the point? What if my dust seals are bad? |
I thought the same of mine, as it turns out I was wrong. The problem was there are four metal rings, one for each cylinder lip. They are used to secure the dust seal inplace.
I'd love to powdercoat these calipers but it's not gonna happen. So High temp paint it is. This has been a good thread for me to read prior to this job though. I'd never had thought to use both bleaders.  |
syncrodoka Samba Member
Joined: December 27, 2005 Posts: 12417 Location: Santa Cruz, CA
Posted: Thu Oct 22, 2009 6:02 pm Post subject: |
| I powdercoated and rebuilt 2 sets of audi dual piston girling calipers and stock vanagon calipers. I lightly lubed the piston and seal with brake fluid and pressed it back in place. I got the audi rebuild kits from http://www.autohausaz.com/index.html Good luck. |
Posted: Sun Oct 25, 2009 11:35 am Post subject: |
| JunkYarDog wrote: |
Can anyone advise on the use of copper paste as I was told??? |
82WestyMan Samba Member
Joined: December 28, 2006 Posts: 1098 Location: Western OR
Posted: Sun Oct 25, 2009 12:27 pm Post subject: |
I guess the thing I question is the compatibility of the copper paste with brake fluid.
Brake fluid is one of the last fluids you want compromised
I've always just used brake fluid and some care to reassemble caliper pistons without any problems _________________ "The floggings will continue until morale improves"
"I never did give anybody hell. I just told the truth and they thought it was hell" - Harry S. Truman
82 Westfalia - w/ a Raby 'Camper Special' engine |
Posted: Sun Oct 25, 2009 12:59 pm Post subject: |
| Brake fluid works fine. |
Masta Shake Samba Member
Joined: October 29, 2010 Posts: 198 Location: San Diego, CA
Posted: Sun Feb 06, 2011 5:57 pm Post subject: |
That looks good. I assume the powder coating didn't cause any fitment issues? PC can be a little thich from time to time. _________________ As a good friend told me when I got the Syncro: "Welcome to the an intense love/hate relationship". |
ragnarhairybreeks Samba Member
Joined: October 26, 2009 Posts: 1945 Location: Sidney B.C. Canada
Posted: Sun Feb 06, 2011 6:16 pm Post subject: |
I had nipple breakage this last week when trying to bleed. I couldn't salvage the caliper and I got a rebuilt unit. Putting it in I found the slider to interfere slightly with the backing plate and I trimmed the plate. I'm thinking there must be some slight differences in the sliders between Girlings. This is on '86 syncro
story here
http://shufti.wordpress.com/2011/02/05/replacing-that-buggered-caliper/
interference pics:
plate trimmed and caliper installed:
alistair _________________ '86 7 passenger syncro, converted to westy pop top, project still in progress
https://shufti.blog/
Old address still works...
http://shufti.wordpress.com |
jwallis Samba Member
Posted: Sun May 10, 2015 6:05 pm Post subject: |
I made a video of rebuilding ATE calipers last week. Trying to do this more to add to the collective knowledge base
https://www.youtube.com/watch?v=8gHecTdC35Q _________________ 50+ YouTube videos - brakes, bearings, CV joints, 1.9/2.1 cooling system, mods, Bostig and more... |
Merian Samba Member
Posted: Sun May 10, 2015 8:31 pm Post subject: |
do not use copper paste
the best thing to use is Unisilikon TK 44 N brake paste - Porsche part # 000.043.117.00 for a 50 g tube
if not, then any good quality brake paste, labelled as such
use brake fluid in an emergency |
shagginwagon83 Samba Member
Posted: Tue Mar 12, 2019 1:15 pm Post subject: |
Heck yeah man. I have to rebuild mine soon. I not only watched your video but I also glanced through your multithreading c# video multithreading gets fun when you share data structures between threads. _________________ "Jo Ann" - '83.5 Westfalia EJ22e w/Peloquin |
Merian Samba Member
Posted: Thu Mar 14, 2019 4:45 pm Post subject: Re: Brake Caliper Rebuild -Photos- |
great time to replace those 20 year old rubber hoses  _________________ .... |
Posted: Thu Mar 14, 2019 7:34 pm Post subject: Re: Brake Caliper Rebuild -Photos- |
For sure! Braided Stainless Steel, plus doing new Nickel copper hard lines.
Anybody know what to torque the 4 bolts holding the two pieces of an ATE caliper together? Will have to scan the Bentley to see if that info is there.
Rebuilding them wasn't bad. I probably spent roughly 1 hour per side. $13-17 a kit. I'll post pictures tomorrow _________________ "Jo Ann" - '83.5 Westfalia EJ22e w/Peloquin |
Posted: Wed May 01, 2019 7:44 am Post subject: Re: Brake Caliper Rebuild -Photos- |
I have one caliper leaking. I tightened it to 50 ft-lbs. I should have just bought a rebuilt set.
ATE wise. You can do this without splitting the calipers. My O-rings between the two halves of the caliper were fine. _________________ "Jo Ann" - '83.5 Westfalia EJ22e w/Peloquin |
bobhill8  Samba Member
Posted: Sat Apr 10, 2021 12:00 pm Post subject: Re: Brake Caliper Rebuild -Photos- |
Been working on this today Just reinserted the piston into my Girling calipers and this technique worked well:
For me, the key was to be patient and feed the back end of the seal in all the way around with the front outer part of the seal about halfway down the piston. I used the wood to apply even pressure, but even then, I stopped every couple of turns and took the wood out to see if things were really even. If it feels hard to turn, then something is not right. Once the piston was more than halfway in, you could feel it sliding in nicely and you could move the outer edge of the seal into its groove. _________________ 1986 Westy
1971 Squareback |
