sc-surfer Samba Member
Joined: May 16, 2005 Posts: 865 Location: Santa Cruz, CA
Posted: Sat Jan 02, 2010 4:49 pm Post subject: Changing front & rear diff oil...Am I a retard? |
I just bought 2 gal. of 80w GL-4 gear oil ant the allen socket to change out both front and rear gearbox fluids. Problem is I can't seem to find any diagram in the Bently that shows where the drain and filler plugs are. I'm pretty sure I found the drains front and rear, but don't know where the fill plugs are. For some reason I have no luck actually finding what I need in the manual...seems like the organization/index is not real intuitive...or maybe I'm an idiot.
What I have figured out so far: Looks like I have to drop the rear skid plate to access the drain plug for rear diff. Front drain seems to be out in the open, on the bottom.
Where are the fill plugs? Obviously up higher... Anyone have a page reference to share, or any info on how to locate the fill plugs??
Thanks everyone! _________________ '89 Syncro Westy
Catalog of Vans at SDM 2010
Westfalia, Syncro & Tristar Reproduction decals here.
* * * Coming Soon: Washable seat covers for westy bench seat...keep the pets off the upholstery! * * * |
msinabottle Samba Member
Posted: Sat Jan 02, 2010 4:53 pm Post subject: Some Help |
The plugs are on the passenger's side, my own experiences may be useful:
http://www.thesamba.com/vw/forum/viewtopic.php?t=142068
Open the fill plug first, so that you can put more IN before you drain it all OUT. There's a horrible full-scale war over using the Red Line products. I thought my transmission shifted beautifully with Red Line MTL, but some people say it eats the transmission and my 3/4 Synchro Slider Hub went after about a year with it. Then again, it was way overdue to have GONE by then...
I don't know.
crazyvwvanman Samba Member
Joined: January 28, 2008 Posts: 10466 Location: Orbiting San Diego
Posted: Sat Jan 02, 2010 5:02 pm Post subject: Re: Changing front & rear diff oil...Am I a retard? |
The tranny fill hole is obscured by the linkage, on the pass side. The front diff fill hole is on the driver side, between fins of the case. They are both 17mm allen socket.
Mark
| sc-surfer wrote: |
I just bought 2 gal. of 80w GL-4 gear oil ant the allen socket to change out both front and rear gearbox fluids. Problem is I can't seem to find any diagram in the Bently that shows where the drain and filler plugs are. .............
Thanks everyone! |
edgood1 Samba Member
Joined: September 30, 2004 Posts: 2151 Location: Plymouth, MA
Posted: Sat Jan 02, 2010 5:43 pm Post subject: |
| sc-surfer wrote: |
Thanks ms.. that got me started. Glad to know it wasn't just me that couldn't find a diagram in the manual.  |
yeah... bentley kinda sucks on this. ... i remember them being labeled in the diagrams as "oil drain plug" which is really the fill plug... or something screwy like that.
in any event, the fill plug is on the passenger side, get a good light and you'll spot it in no time. _________________ '87 Syncro :: Subaru eng
'63 Samba Conversion ::(photo album)
'65 Westfalia
'65 Bug |
davideric9 Samba Member
Joined: January 21, 2009 Posts: 1015 Location: Oakland CA
Posted: Sat Jan 02, 2010 7:41 pm Post subject: |
Make sure you open the fill plug first because these can be very stubborn. If you cant fill it, don't drain it. I had a 17mm wrench on the 17mm allen and pushed so hard the wrench broke. Many years ago I took the van to have the diff oil changed, perhaps at the dealer and they charge me over an extra hour because they had trouble getting the fill plug open.
BTW - Some say GL-4 in the rear, GL-5 in the front.
Good luck. _________________ 1987 Syncro Westfalia, stock (bought 1994)
1986 Syncro Westfalia SVX, 3 knob (bought 2008)
1987 Westfalia (bought 2010)
1988 Wolfsburg GL (bought 2012)
Posted: Sat Jan 02, 2010 9:03 pm Post subject: |
Thanks All!!!
I'll remove the fill plug first for sure. I have an impact driver so hopefully that will work the plugs loose without too much drama. I bought a 19mm today because that was all I could think of while at the parts store. I'll be taking it back for a 17mm tomorrow and having a go at it. Hope all goes as planned!! But you know how it is when trying to get things done before a long trip... _________________ '89 Syncro Westy
kevinm Samba Member
Joined: September 08, 2008 Posts: 132 Location: Minneapolis, MN
Posted: Sat Jan 02, 2010 9:38 pm Post subject: |
A good tool to get the fill plugs out is this one:
<<http://buy1.snapon.com/catalog/item.asp?item_ID=3198&group_ID=363>>
Works on the drain plugs also, but as others have said, only after you've got the fill plugs loosened.
When replacing, make sure not to over tighten.
- Kevin |
Posted: Sat Jan 02, 2010 9:42 pm Post subject: |
Kevin,
Ya, that's basically what I got, just in the wrong size. And not Snap On. Will exchange for proper size tomorrow and apply force with my impact driver. _________________ '89 Syncro Westy
Posted: Sun Jan 03, 2010 7:52 am Post subject: |
Van-Cafe sells this tool for $5.00. Let us know how this turns out for you. _________________ 1987 Syncro Westfalia, stock (bought 1994)
1988 Wolfsburg GL (bought 2012) |
insyncro Banned
Posted: Sun Jan 03, 2010 10:39 am Post subject: |
Really good deal IMHO.
I have the Snap On version of that socket $50+ and the NLA transmission wrench.
Both have allowed me to free all stubborn plugs with gentle heat first.
dylan |
Posted: Sun Jan 03, 2010 10:58 am Post subject: |
Bummer Peter is closed today. Maybe I can hold off 'till tomorrow and get the tool from him. The one I bought (that was the wrong size!!!) was still $30 even though it wasn't MAC or Snap On. I guess for $25 I can wait. Gotta get a couple of other things at Van-Cafe before we leave anyway. Thanks for the tip!!
I will follow up with the results. This should be a simple no-brainer. Drain fluid, add fluid...but it is a Vanagon  _________________ '89 Syncro Westy
Posted: Sun Jan 03, 2010 11:03 am Post subject: |
insyncro Banned
Posted: Sun Jan 03, 2010 11:13 am Post subject: |
With the right tools and a little patience anything is possible, reguardless of the vehicle.
prelube the area in advance, use gentle heat to loosen it up, consistant pressure when removing.
It will work out for you.
dylan |
syncrodoka Samba Member
Joined: December 27, 2005 Posts: 12408 Location: Santa Cruz, CA
Posted: Sun Jan 03, 2010 11:33 am Post subject: |
| I have a snap-on and VC version if you want to borrow it. |
Posted: Sun Jan 03, 2010 1:49 pm Post subject: |
| Put the tools on your porch in the box with the tranny fluid. |
Posted: Sun Jan 03, 2010 10:12 pm Post subject: |
Thanks to Syncrodoka I managed to finish the project. No real drama other than having to drop the syncro rear skid plate to access the drain plug for the transaxle. I swear some day I'll own a lift. I HATE crawling arround on the ground. At least I have concrete in our new place. Beats the gravel drive of out last place.
Plugs came out with a firm tug on my breaker bar. I was able to access the fill plug on the transaxle with an extension without removing the shift linkage. By putting the front wheels up on ramps I got quite a bit of fluid out.
Front diff was a piece of cake.
Observations: only a little 'fur' on the magnetic drain plugs, no big chunks. Seems to go into first gear from a stop much smother. Maybe the fluid level was low, or the new oil has a different viscosity??
On the other hand, there seems to be a little more noise transmitted through the shift lever. Any idea why? The sound is a light whirring sound that almost goes away entirely when I just touch the shift knob. Why do I have this sound and is there a way to quiet it? It has always bothered me and now it is slightly louder.
Glad to have it done for another 30k or so!! _________________ '89 Syncro Westy
Posted: Mon Jan 04, 2010 12:37 am Post subject: |
BTW, it was Van Cafe that told me to use gl-4 in the rear and gl-5 in the front. I guess you used gl-4 all the way around. I have not done the front diffs yet, I trust Van-Cafe and so i may use the GL-5. _________________ 1987 Syncro Westfalia, stock (bought 1994)
meanvicky Samba Member
Joined: September 03, 2012 Posts: 1 Location: Monterey, CA
Posted: Tue Sep 11, 2012 8:18 pm Post subject: Tightening Gear Oil Fill & Drain Plug |
| kevinm wrote: |
- Kevin |
I was able to follow the Vanganauts advice on pulling plugs and draining, filling and replacing plugs just fine. But I can't seem to get the plugs back in so they are flush with the tranny casing as I found them. They are tight but I didn't want to crank on them aggressively. Is it ok if the drain plugs are not flush, but rather three or four threads off the tranny case?  |
