micromotor Samba Member
Posted: Sun Apr 25, 2010 7:50 pm Post subject: 3M panel adhesive vs old fashion welding |
I'm ready to install my new Gerson bed panels on my '62 Single Cab. A friend was telling me about a 3M ahesive product that is used instead of welding the panels on. Is anyone familiar with this product? |
cdennisg Samba Member
Joined: November 02, 2004 Posts: 20897 Location: Sandpoint, ID
Posted: Sun Apr 25, 2010 8:30 pm Post subject: |
There has been discussion in the body/paint forum on here, I would suggest you look there for an answer.
I have heard good things about that adhesive, in certain situations. I would think it would work just fine for what you are doing. _________________ Confusious say it takes it takes two wipes to know you need three, but it takes three wipes to know it only needed two. |
LittleThunder Samba Member
&Dan Samba Member
Posted: Mon Apr 26, 2010 1:14 am Post subject: |
I'm seriously considering going this route for our farkled wheelwells.
I've been looking mightily hard for a downside, and frankly cannot find a compelling reason not to use it.
Despite the knee-jerk reaction I have to gluing something together that heretofore has been joined with a weld, the data doesn't lie and its use in aerospace applications is awfully convincing. |
williamblanda Don't Disgrace The Eddy!
Joined: September 09, 2008 Posts: 1379 Location: Buffalo, NY
Posted: Mon Apr 26, 2010 4:21 am Post subject: |
Dan, I would still weld your farkled wheel wells shut. I would use the adhesive in place of a spot weld, not a butt weld.
My 2 cents. |
thom Samba Member
Joined: October 12, 2000 Posts: 6227 Location: Sacramento
Posted: Mon Apr 26, 2010 6:29 am Post subject: |
You're not looking hard enough; laziness will do that to you.
Panel adhesive is for panels that overlap; it requires a certain amount of surface area of the mated panels to work properly. Cars that are assembled using this stuff were designed from the group up to use it. Your bus was not. If you're dying to use adhesive to slap a car together, go buy a Saturn. _________________ -Thom
1956 Single Cab
1957 Porsche 356A Sunroof
1957 23-Window Deluxe
1963 Unimog 404
1965 E-Type |
joescoolcustoms Samba Member
Posted: Mon Apr 26, 2010 7:00 am Post subject: |
One version of the Kenworth Road Tractor cabs are built with the adhesive and no welding. It preforms very well. But as stated, it does require a overlapping of surfaces to acheive the strength needed for automotive use. I got to tour the plant in Ohio looking at recycling their waste. The adhesive is impressively strong.
I have used the adhesive to attach a rocker panel on a mid 80's chevy pickup and worked very well. I have a panel replacement crimping tool that allows for 1/2 inch panel overlap while giving the exterior surface a flush alignment. Did it about 7 years ago and it still looks good.
Unless a crimping tool is used to allow overlap, I would not reccomend the usage on a VW. Not very many places can a replacement panel be crimped and overlapped on all edges. _________________ Bad News Racing 2018 NORRA 1000 3rd in Class
Posted: Mon Apr 26, 2010 2:29 pm Post subject: 3M panel adhesive vs old fashion welding |
Everything I'm seeing tells me to try the 3M stuff. My question now is the applicator. There are two different guns. One goes for about $300, the other for about $75 but I can not tell what the difference is between the two. |
partonkevin Samba Member
Joined: June 10, 2003 Posts: 478 Location: McMinnville, TN
Posted: Mon Apr 26, 2010 3:11 pm Post subject: |
joescoolcustoms wrote: |
Unless a crimping tool is used to allow overlap, I would not reccomend the usage on a VW. Not very many places can a replacement panel be crimped and overlapped on all edges. |
I bought a replacement lower doorskin panel for a 56 Ford a while back and the manufacturer actually recommended crimping and using the adhesive. They had been doing that for several years at their restoration shop with very good results. Specifically, no heat warpage and no rust at the lap seam. |
MODIFIER Samba Member
Joined: December 09, 2006 Posts: 1560 Location: Summerville SC
Posted: Mon Apr 26, 2010 5:08 pm Post subject: |
thom wrote: |
Panel adhesive is for panels that overlap; it requires a certain amount of surface area of the mated panels to work properly. Cars that are assembled using this stuff were designed from the group up to use it. Your bus was not. If you're dying to use adhesive to slap a car together, go buy a Saturn. |
And you are ill informed.
Adhesives will require a face to face mating surface, and that is easily done on bus wheelwells by flanging an overlap area, or making a sleeve style backing strip to mate to the two panels.
It has been proven time and time again that these adhesives are as strong or stronger that welding.
I do prefer 3M to lord fusor for work time and brute strength.
http://multimedia.3m.com/mws/mediawebserver?mwsId=66666UuZjcFSLXTtl8Tc48TcEVuQEcuZgVs6EVs6E666666--
http://www.youtube.com/watch?v=g-bgruJgHew _________________ Happyasshell
USC USMC DAD OORAH!
ASE MASTER TECH BODY/PAINT and MECHANICAL
62 Beetle
63 Vert
64 Beetle
https://www.facebook.com/SmartFarmServices |
gfw1985 Samba Member
Joined: December 24, 2003 Posts: 948 Location: Raphine, VA
Posted: Tue Apr 27, 2010 6:09 am Post subject: Re: 3M panel adhesive vs old fashion welding |
micromotor wrote: |
I won't dispute the fact that 3M is probably a higher quality adhesive, but I have used Eastwood's adhesive with no complaints. The tubes are smaller and come with an adapter to use a regular caulking gun. |
thom Samba Member
Posted: Tue Apr 27, 2010 9:38 am Post subject: |
MODIFIER wrote: |
thom wrote: |
On which count? That the glued panels need to be overlapped, or that buses were not designed to be glued together? _________________ -Thom
1956 Single Cab
1963 Unimog 404
1965 E-Type |
thom Samba Member
Posted: Tue Apr 27, 2010 9:39 am Post subject: Re: 3M panel adhesive vs old fashion welding |
gfw1985 wrote: |
micromotor wrote: |
I wouldn't be surprised if Eastwood is just re-packaging the 3M adhesive and marking up the price. _________________ -Thom
1956 Single Cab
1963 Unimog 404
1965 E-Type |
Posted: Tue Apr 27, 2010 5:46 pm Post subject: |
thom wrote: |
MODIFIER wrote: |
thom wrote: |
On which count? That the glued panels need to be overlapped, or that buses were not designed to be glued together? |
Calling the OP lazy for looking at adhesives instead of welding on a nonstructural panel is something an illinformed person would say.
most cars were NOT designed from the ground up for adhesive repairs,not even todays latest cars. but ALL manufacturers have adhesive repair guidelines in place to facilitate replacing previously welded panels.
more bad info.
It is an industrywide accepted fact that todays adhesives will bond stronger or as strong as a weld seam.
follow instructions closely,pay attention to the details, and work cleanly and you can use the proper adhesive to facilitate a great repair that is stronger than any weld seam.
every time, no problems. _________________ Happyasshell
USC USMC DAD OORAH!
62 Beetle
63 Vert
64 Beetle
66buggie Samba Member
Posted: Tue Apr 27, 2010 6:35 pm Post subject: |
MODIFIER wrote: |
thom wrote: |
MODIFIER wrote: |
thom wrote: |
X20
more bad info.
every time, no problems. |
zeroman Samba Member
Joined: February 05, 2010 Posts: 891 Location: Cane field
Posted: Wed Apr 28, 2010 12:27 am Post subject: |
other than eastwood..are all the rest in a special applicator type packaging only? I was thinking of picking up some, like i said before.. paint shop guy said applicator was pushin a bill and another 30+ for the glue.
got to do some door patch panels.. Those vice grip style crimpers and some fuser seems to be the trick for it.. so many up-sides from welding.. so few downs. _________________ 77 super convertible |
Posted: Wed Apr 28, 2010 1:57 am Post subject: |
Here is the crimper I have, works very well.
In thinking about this glueing thing, I think it would be better to not have a welded panel that has the heated metal with burnt off weldable primer exposed to the elements to rust from the inside out. I have done panel replacement where I cannot get to the back side of the welded panel to clean and paint the welded surface, like a double lip fender well in the overlap area. The adhesive would seal that exposed metal and may make the repair last longer.
http://www.autobodytoolmart.com/panel-crimper-478-p-12676.aspx _________________ Bad News Racing 2018 NORRA 1000 3rd in Class
Posted: Wed Apr 28, 2010 3:26 am Post subject: |
http://www.autobodytoolmart.com/panel-crimper-478-p-12676.aspx |
Be careful with that tool.
It works with a air chisel and can get away from you quickly.
the hand held squeeze type works well for the money and the air powered type has the most control.
practice on a lot of scrap before attempting to use that tool on your vehicle. _________________ Happyasshell
USC USMC DAD OORAH!
62 Beetle
63 Vert
64 Beetle
Posted: Wed Apr 28, 2010 3:32 am Post subject: |
MODIFIER wrote: |
practice on a lot of scrap before attempting to use that tool on your vehicle. |
For anyone buying the tool I indicated, MODIFIER is correct. The air hammer can cause more dammage than you are trying to correct. I bought that tool back in the early 80's and it did take some practice to learn how to hold it and use it, but once familiar with it, 30 seconds and you are done.
I will be using it to replace my rear lips on my '59 SC, and maybe the adhesive too. _________________ Bad News Racing 2018 NORRA 1000 3rd in Class
John Kelly Samba Member
Joined: March 17, 2002 Posts: 477 Location: Moclips WA
Posted: Wed Apr 28, 2010 6:24 am Post subject: |
I have never used adhesives. I can see where they would work just fine but I would not buy an old car that had been repaired that way if there were another just as decent vehicle that had been properly welded available for the same general cost.
Strength is not an issue. Both methods are strong. There are two issues that would be of concern to me....overlapping or using flanged panels creates a thicker generally lower area than a butt weld and will always require filler if done in the middle of a panel, and the flanging process changes the contours of a panel unless the line is straight, and not on a curved surface.
I think adhesives are an advancement for body shops but not necessarily great to stumble across on a classic car you just bought and are trying to restore. Still, I would use adhesives in some areas for everyday commuter cars (most of which won't be around in ten years) if I were doing collision repair for a living.
I'm also a fan of people doing whatever they want with their own car once they know the benefits and detriments of both choices.
John www.ghiaspecialties.com _________________ Metal Shaping and Dent Repair videos:
http://www.youtube.com/profile?user=GullWingInn&view=videos |
