hazetguy Samba Member
Joined: April 06, 2001 Posts: 10800 Location: the past
j.pickens Samba Member
Joined: December 03, 2002 Posts: 9831 Location: Exit 7, New Jersey
Posted: Fri Aug 12, 2005 10:17 pm Post subject: |
As always, this is greatly appreciated. _________________ Founder and Chairman Emeritus, ECMSAS
BeaterBarndoor wrote: |
i wish more people would actually drive their vws rather than just talking about what they have in the garage. |
Red Fau Veh wrote: |
If you've seen one sunroof swivel seat kombi, you've seen them all!  |
splitpile Samba's Worst Speller
Joined: May 03, 2000 Posts: 5928 Location: back to living where hell meets the suface
Posted: Fri Aug 12, 2005 10:44 pm Post subject: |
Jon, you need to publish a book, all your pics and how to are a great help to many people.
and I know we won't have to worry about a how to lower your bus tech artical from you _________________ Stocking distributor of "The Funky Green Panels"
"no more hacking my sig line" |
EverettB  Administrator
Joined: April 11, 2000 Posts: 71588 Location: Phoenix 602
Clara  Samba Member
Posted: Sat Aug 13, 2005 7:25 am Post subject: |
EverettB wrote: |
I thought 59s had a crank apron too? Thus the one year-only longer crank handle... |
I have a wierd apron that came with a 60 SC I had a few years ago. It is crank start, but has one tailpipe cut out. _________________ The Obsolete Air-Cooled Documentation Project http://oacdp.org/ |
i dunno. the dates are a guess, and luckily, the really cool guy who runs this site added an "edit" feature for the text of the pics so i can change the info if needed. and by no means am i trying to be the "end all debate" guy on these, because i am sure there are some weird variations, but the ones i took pics of seem to be the most common examples for the vast majority of busses i've seen.
have you ever seen (in person) a 59 with a crankstart and the supposed "longer" handle? i have not.  |
rene p. l. Samba Member
Joined: September 27, 2002 Posts: 280 Location: YQB, Québec, Canada
Posted: Sat Aug 13, 2005 7:31 am Post subject: |
2 years ago, i bought a '59 double door panel who had a crank start apron and a crank start nut. Never found the handle but i'm sure at 99.9% it was original to this panel. P.O. never found handle in his garage. |
Posted: Sat Aug 13, 2005 7:41 am Post subject: |
maybe the "early" 59's still had cranks, and the "later" 59's did not? all i can say is that the one that is pictured (the blue one) is definitely the original to my 6/30/59 built Westfalia which i believe would have had the bastard motor, but maybe not since it was a UT delivery bus (maybe i'll look at the "birth certificate, even though i think it's wrong). and maybe busses in other countries (remember, these are USA busses i'm talking about) had 36hp later into production? they had semaphores and 40hp's later, why not 36hp? |
campingbox  Samba Member
Joined: November 14, 2000 Posts: 10252 Location: Petaluma, CA
Posted: Sat Aug 13, 2005 9:32 am Post subject: |
I've got a longer crank handle.....exactly the same as the early ones, but about three inches longer. |
Posted: Sat Aug 13, 2005 10:39 am Post subject: |
My early 60 DC and my 60 SC (27,000 original miles) both had/have crankstart aprons, both were original owner (per say) when I bought them and both in what was left of the og paint. I thought that was odd when I got them but never paid attention to it. Noe of my other 1960 buses have crank start aprons, only the trucks, early 60 truck only thing maybe, or changed and painted original color way back when? _________________ Stocking distributor of "The Funky Green Panels"
Posted: Mon Jul 07, 2008 11:09 am Post subject: |
splitpile wrote: |
My early 60 DC and my 60 SC (27,000 original miles) both had/have crankstart aprons, both were original owner (per say) when I bought them and both in what was left of the og paint. I thought that was odd when I got them but never paid attention to it. Noe of my other 1960 buses have crank start aprons, only the trucks, early 60 truck only thing maybe, or changed and painted original color way back when? |
My 60 SS DD panel also has the original crank start apron. So far 3 of my 8 1960 buses have crank start aprons. I'll have to see what my new to me 60 SO 23 has when I pic it up. _________________ Stocking distributor of "The Funky Green Panels"
i_am_cool_fred Samba Member
Joined: June 26, 2004 Posts: 1743 Location: Benton, AR
Posted: Sun May 02, 2010 10:03 am Post subject: |
in looking at this thread, i see that 55-58 had an apron
besides the slightly obvious, what about mounting location??? my march 58 bus' apron seems to mount about a quarter of an inch to high, the decklid, which i don't thin is right for the bus either fits so tight you can't get a peice of paper around the top or the bottom, and that's with the apron being bowed out. i think it's all in the apron just wondering about mounting location differences.
it does appear as though my apron sits a good quarter of an inch higher at the bottom than the two corners of the bus.
here is a not so good pic of it in place but not mounted
and this one you can kinda see how it does sit higher than the corner...granted the apron isn't mounted, but that's how it sits even bolted on...again, the decklid, shut, has harldy any room on top and bottom, and my decklid is bowed out, that hsould tell you how much smaller the hole is than the decklid.
shot of the decklid (which it has been established that isn't correct either perhaps that's part of the problem)
shouldn't i have a crank start apron??? _________________ proud owner of a defunct 1979 sunroof kombi
Brian Denning, as seen on Gearz TV |
sled Samba Member
Posted: Sun May 02, 2010 10:14 am Post subject: |
yes _________________ drive your split. |
slow36hp scott wimberley
Joined: August 09, 2004 Posts: 3113 Location: mukilteo washington
Posted: Sun May 02, 2010 10:25 am Post subject: |
whether or not you should have a crank apron was determined at the top of the post .all correctness aside you have other problems as those parts should be able to work properly. your apron mounts most likely are bent plausibly guessing when a rear collision took out your original apron and decklid. |
Freezzr Samba Member
Joined: August 12, 2005 Posts: 300 Location: The Netherlands
Posted: Thu Feb 10, 2011 11:58 am Post subject: |
Hi! I have a 65 deluxe bus and got a 58 rear apron from my friend, it looks like a fit. Is the only difference the crank start hole or are there more differences? |
RobzKombi Samba Member
Posted: Thu Feb 10, 2011 6:09 pm Post subject: |
Just to add to the confusion, I have a 12-12-1958 build date Kombi which I would consider an early 1959 model and my apron has no hole for a crank start. |
Posted: Thu Feb 10, 2011 7:40 pm Post subject: |
Does the difference between stale air and fresh air 40 horse engine tins enter into this somewhere? _________________ Founder and Chairman Emeritus, ECMSAS
