Installing new SVDA distributor questions??
Yondermtn
Yondermtn is offline
PostPosted: Sat Jul 31, 2010 7:37 am    Post subject: Installing new SVDA distributor questions?? Reply with quote
I'm installing a new aftermarket SVDA distributor w/pertronix on my 1977 bus. Stock 2.0L
1. What is the distributor tang? The instructions say to line the tang up with the shaft.
2. The notch mark for cyl. #1 on the new distributor seems to be on the opposite of the distributor as the same notch on the old distributor. Should I position the distributor so that this notch is in the same place as the former distributor? (in relation to engine case)
TomWesty
TomWesty is offline
PostPosted: Sat Jul 31, 2010 8:03 am    Post subject: Reply with quote
Quick search of forum revealed this. It may help. http://www.thesamba.com/vw/forum/viewtopic.php?t=99028&highlight=index+svda+distributor
clearsurf2001
Samba Vaccinator
clearsurf2001 is offline
This should get you started ...
http://www.aircooled.net/gnrlsite/resource/articles/instdist.htm
Get ready for the injection Smile
Make sure it is coherent. Rodney
mharney wrote:
I think Glenn has an EMPI crank in his engine.
Yondermtn
PostPosted: Sat Jul 31, 2010 8:27 am    Post subject: Reply with quote
Ok. TomWesty's link seems to be what is happening with my distributor. It seems as though it is 180 degrees different from the original.
It looks like I should install it with the same orientation as my stock dist., but I'll have to switch the plug wires on the cap. Correct?
Here is my old distributor with my thumb showing the #1 tdc mark.
My new dist. with index finger pointing to #1 tdc mark.
Here is a pic of my dist. orientation before I pulled the old one.
Mal evolent
Mal evolent is offline
PostPosted: Sat Jul 31, 2010 8:33 am    Post subject: Reply with quote
the tang is the offset flat bar that lines up with the slot that drives the rotor shaft.
an SVDA mounts 90 degrees from where an 009 mounts, because the vacuum advance cam would hit the case if they lined up the same
73 Beetle Baja, Ghia front brakes, Type 3 rear brakes, 2220 ( 94 X 80 ), Weber Progressive, Bosch SVDA, '97 Mustang seats
Baja Bugs for Volkswagen Virgins: Index
busdaddy
busdaddy is offline
PostPosted: Sat Jul 31, 2010 8:35 am    Post subject: Reply with quote
Well the bottom line is getting it in a position where the vacuum can has some room to move for adjustment, if your drive isn't in the right place don't worry. Set the engine to #1 with your old distributor then install the new one and put your own mark on with a sharpie where the rotor ends up, arrange the wires to suit.
Слава Україні!
Yondermtn
PostPosted: Sat Jul 31, 2010 8:41 am    Post subject: Reply with quote
Okay, thanks. Sounds like I'm on the right track.
Now my problem is that I can't get the distributor to seat all the way. I think it's because of the newer rubber seal on the shaft. I had a hard time getting the bracket over this seal too.
Any tricks to this? I don't want to force it too much, but I just can't seem to get it all the way seated.
busdaddy
busdaddy is offline
PostPosted: Sat Jul 31, 2010 8:56 am    Post subject: Reply with quote
The seal should have an almost flat profile, if you just can't get it in recycle your old one until you can find the correct one. IIRC Karl said they were available from Mercedes but try Germansupply first.
Just to make sure install the distributor with the seal removed and confirm the rotor position when it's fully seated so you know you've got it right once you battle with the seal.
Слава Україні!
Yondermtn
PostPosted: Sat Jul 31, 2010 10:52 am    Post subject: Reply with quote
Got the distributor in there and cranked the engine and it won't start. I'm pretty confused at this point. Mad
Amskeptic
Amskeptic is offline
PostPosted: Sat Jul 31, 2010 11:02 am    Post subject: Reply with quote
Check wires to coil. All correct?
Put engine at TDC #1. Solid lifters? Confirm by checking that both #1 rocker arms have a little click of clearance. If they are both tight, rotate engine 360* and check again.
Look at the rotor under the distributor cap. Is it "locked into place" as in Successfully Engaged With The Distributor Drive Gear?
Wherever that rotor is pointing (ignore little notches on the distributor body), the wire in the cap just above it HAS to be #1 now. Install other wires 4-3-2-.
Try it now.
Colin
www.itinerant-air-cooled.com
www.facebook.com/groups/324780910972038/
Mal evolent
PostPosted: Sat Jul 31, 2010 11:13 am    Post subject: Reply with quote
how much won't it seat?
the height of the tang ( there's a hint there ), a quarter inch, ?
busdaddy
busdaddy is offline
PostPosted: Sat Jul 31, 2010 12:12 pm    Post subject: Reply with quote
How did you connect the wires from the new distributor?
Слава Україні!
Nica
Nica is offline
PostPosted: Sat Jul 31, 2010 12:18 pm    Post subject: Reply with quote
It probably didnt engage. That can be a PITA Rolling Eyes Make sure the shaft is engaged, try to move it, if you can move it more that a couple mm it didnt completely engage.
Yondermtn
PostPosted: Sat Jul 31, 2010 12:29 pm    Post subject: Reply with quote
Thanks again for the replies.
I threw the old dizzy back in and got it running and started the entire procedure over from square one.
The new dist. slid in much easier with a warm engine. BUT, I'm having the same issue. Won't start.
The pertronix has a red and a black wire. I have my red to positive side of coil and black to negative side of coil.
I've tried all possible firing orders.
I found that after cranking the engine, if I set the crank at TDC the rotor is in a different place each time. Also, I can move the rotor around by hand. Is this what Nica is talking about? My shaft not engaging?
It looks like it's seated pretty well as is.
Thoughts?
busdaddy
busdaddy is offline
PostPosted: Sat Jul 31, 2010 1:48 pm    Post subject: Reply with quote
Not seated well enough, turn the rotor as you drop in the distributor until you feel the drive engage the slot, then give it a good twist both ways to confirm it's engaged. You may have bent the clamp by now and it may be holding the distributor up away from the case, there should be no gap between the distributor, clamp and case.
Слава Україні!
Yondermtn
PostPosted: Sat Jul 31, 2010 1:56 pm    Post subject: Reply with quote
Okay. I got it seated correctly now. I could feel it drop in and now the rotor only turns a little bit with some springy resistance.
Still will not start. The rotor points 180 degrees(pointing towards #3 cylinder) from the original distributor. I have placed #1 wire where the rotor is pointing and then 4-3-2.
Now I'm perusing the Pertronix trouble shooting pages. Rolling Eyes
Mal evolent
PostPosted: Sat Jul 31, 2010 2:07 pm    Post subject: Reply with quote
I have had 2 pertronix. they lasted about 10 seconds each, connected correctly to a 3 ohm coil.
Yondermtn
PostPosted: Sat Jul 31, 2010 3:10 pm    Post subject: Reply with quote
Still no start. It has backfired a couple times while cranking, if that means anything.
I'm now thinking about pulling the pertronix out of the new distributor and putting some points in.
The reason I'm changing distributors is because I suspect my old one to be sticking. I can't get it to stay timed right and the idle will not return to normal all the time.
crDaniel
crDaniel is offline
PostPosted: Tue Oct 21, 2014 2:44 pm    Post subject: Im having the same issue! Reply with quote
This thread was describing my same problem exactly -- and then it ended! What was the solution...? And more importantly, how do I get my new Pertronix SVDA to work?
Randy in Maine
Randy in Maine is offline
PostPosted: Tue Oct 21, 2014 3:12 pm    Post subject: Reply with quote
From Speedy Jim and modified by Amskeptic
