"Sled" Tin vs. HD Pushrod Tube Protectors
Page: Previous  1, 2, 3
BYeaton
BYeaton is offline
PostPosted: Sat Dec 04, 2010 3:11 pm    Post subject: Reply with quote
Oh okay. So they're kind of suspended by the 2 screws where the sled is attached to the case?
bartman
bartman is offline
PostPosted: Sun Dec 05, 2010 6:57 pm    Post subject: Reply with quote
http://www.thesamba.com/vw/forum/viewtopic.php?t=326793&highlight=tins
Here's how I did mine. Offers a lot of protection
BYeaton
BYeaton is offline
PostPosted: Sun Dec 05, 2010 8:26 pm    Post subject: Reply with quote
Wow those look really solid! You definitely answered my question about being able to mount them on the head somewhere.
Well played sir.
thefladge
thefladge is offline
PostPosted: Sun Dec 05, 2010 8:55 pm    Post subject: Reply with quote
Another solution: Modified water-cooled Vanagon push rod tube protectors.
1957 Vintage Baja Bug.
2110cc engine, 40 IDF Webers on Gene Berg manifolds, Engle 110 cam, Bugpack 40×35.5 Street Pro Heads, W8CC plugs, 12.5 pound Flywheel, Kennedy 1700 pound pressure plate.
AlteWagen
Troll
AlteWagen is offline
PostPosted: Sun Dec 05, 2010 10:19 pm    Post subject: Reply with quote
Part number please. If not what year and engine?
Thanks
bartman
bartman is offline
PostPosted: Mon Dec 06, 2010 12:04 am    Post subject: Reply with quote
thermostat fit under there?
thefladge
PostPosted: Mon Dec 06, 2010 5:18 am    Post subject: Reply with quote
I don't have the part numbers, but they should be the same on all gas powered, water cooled Vanagons. Mid-1983 to end of production.
Two of the tabs that attach to the exhaust studs have to be modified to fit a Type 1 engine.
These are very thick and strong.
The thermostat will not work with this.
GLHTurbo
GLHTurbo is offline
PostPosted: Mon Jan 03, 2011 11:17 am    Post subject: Reply with quote
Hey Glenn,
What are part #3 and #4 from the left on the top row? Trying to get my tins in order for my Chico motor. I have a set of industrial tins, need to get 2 lower sleds, and trying to figure out what else I need to source.
1957 Beetle
1966 Bus
bugninva
bugninva is offline
PostPosted: Mon Jan 03, 2011 11:19 am    Post subject: Reply with quote
those pieces attatch to the rear edge of the cylinder tin to keep the air flowing around the barrels....
[email protected] wrote:
With a show of hands, who has built over 1000 engines in the last 25 years? Anyone?
GEX has. Just sayin
GLHTurbo
GLHTurbo is offline
PostPosted: Mon Jan 03, 2011 11:43 am    Post subject: Reply with quote
gotcha.
You guys run these with this setup too?
1957 Beetle
1966 Bus
Glenn Premium Member
Mr. 010
Glenn is offline
PostPosted: Mon Jan 03, 2011 11:45 am    Post subject: Reply with quote
GLHTurbo wrote:
gotcha.
Yes, most important.
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
RockCrusher
RockCrusher is offline
You can run those but the cool tins work better......
[email protected] Please use email for all general inquiries.
I will be happy to speak to anyone who has a serious inquiry (meaning real potential business for RC enterprises) or a parts order. Due to machining noise causing missed calls all calls will be returned promptly.
bartman
bartman is offline
PostPosted: Mon Jan 03, 2011 11:49 am    Post subject: Reply with quote
You use those little deflectors with the sleds. cool tins replace them.
You cant use the sleds with the cool tins.
If you're running a thermostat, you need the sleds
GLHTurbo wrote:
Hey Glenn,
That thread of mine shows a pretty good closeup of parts #3 and #4 of your pic installed
Mr. 010
Glenn is offline
I guess we disagree on that. Cool Tins are Type 3 tins and in my opinion don't cool as well.
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
RockCrusher
PostPosted: Mon Jan 03, 2011 11:58 am    Post subject: Reply with quote
Ok Mr. Smarty pants.....then why do the call the "cool" tins? Think
I think we can agree to disagree. We (RC) do so many engines that are NOT for sedans that cool tins far outweigh gathering all the little bits and pieces that you still can't use with headers. If I were building anything like a stocker with heat I WOULD NOT use cool tins. Smile
Mr. 010
Glenn is offline
PostPosted: Mon Jan 03, 2011 12:05 pm    Post subject: Reply with quote
Back in the 80's JSC (Johnny's Speed and Chrome) bought something like 80,000 of them and started to market them as "Super Cool Tins".
If you're talking about using them on open bay vehicles like Bajas and Dune Buggys then maybe. But on Sedans they do not cool better than the stock Type 1 tins.
Super Cool tins are actually Type 3 tins and are designed to be used with the Type 3 pancake fan shroud.
This has been debated many times and I won't be revisiting that again.
If they work for you then that's just fine and dandy.
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
RockCrusher
PostPosted: Mon Jan 03, 2011 12:09 pm    Post subject: Reply with quote
The smarty pants was supposed to be a joke in case it didn't come off that way... Smile Surprised
Mr. 010
Glenn is offline
PostPosted: Mon Jan 03, 2011 2:25 pm    Post subject: Reply with quote
No harm, no foul.... Wink
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
Page 3 of 3
