What to use/do to clean engine?
jjjjjoey
jjjjjoey is offline
PostPosted: Mon Dec 13, 2010 6:13 pm    Post subject: What to use/do to clean engine? Reply with quote
So I took my 1500cc out of my 67 while the body work gets done.
Now that its out and sitting in my garage what is the best way to clean it? And where should I be careful not to get water in?
[/img]
________
67 Ghia n00b
DrakeB
DrakeB is offline
PostPosted: Mon Dec 13, 2010 6:25 pm    Post subject: Reply with quote
I know somebody said in the Type 3 forum not to use vinegar as it will eat the case up and in the process create highly volatile hydrogen gas.[/list]
Bondo? Bondo? We don't need no stinking Bondo!
How is it 'NOS' if it has been modified?
The Thread Killer.
70 140
70 140 is offline
PostPosted: Mon Dec 13, 2010 6:52 pm    Post subject: Reply with quote
spray it down with simple green, or some other bio-degradable citrus cleaner. Let is sit for a while, and use some pressurized water to rinse it off.
don't stick the hose down the carb, and you should be fine.
jjjjjoey
jjjjjoey is offline
PostPosted: Mon Dec 13, 2010 8:12 pm    Post subject: Reply with quote
No vinegar-check.
Will a waded up plastic bag seal those openings enough or should I try to plug it up with something more, like pieces of towel?
________
67 Ghia n00b
Z+9
Z+9 is offline
PostPosted: Mon Dec 13, 2010 10:44 pm    Post subject: Reply with quote
I bought some Marine Clean, I used it to clean the pans... This thing is a miracle in a box. I have used it to clean up the BBQ, bathtubs, toilets, concrete, you name it. Just spray, let it sit for 10-15 min and scrub with a tooth brush. Dawn power dissolver works good too, Walmart, $2.99
1956 Buick Century Coupe
1951 Ford F1
1974 VW Super Conv.
analogmax
analogmax is offline
PostPosted: Mon Dec 13, 2010 11:45 pm    Post subject: Reply with quote
I used some cleaner called purple power and then used heat paint for the final. The only thing I replaced was the push rod tubes.
Before:
After:
djkeev
djkeev is offline
PostPosted: Tue Dec 14, 2010 6:51 am    Post subject: Reply with quote
Before:
After:
Really, for the case and the heads the ONLY thing you did was wash it with Purple Power?!?
IF this is true, this is absolutely AMAZING!! I've never ever seen a cleaner get any engine this bright and clean and even! It looks like it was blasted.
You painted the silver right??
It is 100% obvious you painted the black.
Please confirm, Purple Power ONLY ?
Dave
Ghia
Vanagon
Beetle
TC/TeamEvil
TC/TeamEvil is offline
PostPosted: Tue Dec 14, 2010 7:32 am    Post subject: Reply with quote
I have to agree, Purple Power is pretty amazing. I've had similar results with it. Spray it on, maybe do a little brushing with a stiff bristle brush (sometimes not) and hose it off. Once dry, all ready for paint and detail.
Engine bays, undercarriages, front ends, works just as well.
Luck,
T
analogmax
PostPosted: Tue Dec 14, 2010 10:14 am    Post subject: Reply with quote
I just used purple power and a brush then painted the case and other parts with heat paint.
djkeev
djkeev is offline
PostPosted: Tue Dec 14, 2010 10:53 am    Post subject: Reply with quote
Thanks, that's what I suspected, it was way too clean to be just the naked case and heads in that photo!
We won't get into the argument extolling the pros and cons of painting these components. It's been done.
Dave
Ghia
Vanagon
Beetle
Jeckler
Jeckler is offline
PostPosted: Tue Dec 14, 2010 11:13 am    Post subject: Reply with quote
I used some generic Purple-Power-like stuff from Home Depot. I left the intake/exhausts open, but removed the rocker arms. The distributor and generator stand were still attached.
I knew I was starting it fairly soon after (6 months Smile ), so just blew out the intake and exhaust with compressed air, then hosed them down with WD40. It runs fine.
Andy
'63 Bug rebuild here.
Did you know that sellers can't charge a fee to accept PayPal?
bill may wrote:
I am the crabby old guy.
Knowledge is knowing that a tomato is a fruit.
Wisdom is knowing not to put it in fruit salad.
djkeev
djkeev is offline
PostPosted: Tue Dec 14, 2010 4:22 pm    Post subject: Reply with quote
Now this photo looks like a realistic view of an engine cleaned with a product. That is why I questioned if the flawless one was blasted or painted.
Looks like it worked good, you say Purple Power LIKE. What was it exactly?
dave
Ghia
Vanagon
Beetle
jjjjjoey
jjjjjoey is offline
PostPosted: Tue Dec 14, 2010 4:50 pm    Post subject: Reply with quote
Nice looking engines.
Was the Purple Power diluted with water or did anyone use the full strength straight from the container way....?
________
67 Ghia n00b
TC/TeamEvil
PostPosted: Tue Dec 14, 2010 5:08 pm    Post subject: Reply with quote
Full strength in an old plastic spray bottle.
Jasonscool
Jasonscool is offline
PostPosted: Tue Dec 14, 2010 5:35 pm    Post subject: Reply with quote
I have used toilet bowl cleaner in the past. As long it doesnt sit in a puddle in it over night it works great. It will actually etch the metal but not too much. The etch will give your high temp paint a better surface to adhere to. My .02
swhitcomb
swhitcomb is offline
PostPosted: Tue Dec 14, 2010 6:17 pm    Post subject: Reply with quote
I used Purple power also. My engine was COATED in oil. We took it apart down to a short block, replaced all the seals, purple power, and pressure washed it. I powder coated the tin, and intake.
The Ghia went from the way I got it a in Jan of 09:
Then the way it looked after I cleaned it up a little:
To how it looks now:
I'm not 100% done yet, but WOW. What an improvement.
My 71 Ghia Been in my family since 1980
My Patina 66
My 74 Ghia
07 Boxster
View user's profile Send private message Send e-mail Visit poster's website AIM Address Facebook Instagram Gallery Classifieds Feedback
swhitcomb
PostPosted: Tue Dec 14, 2010 6:31 pm    Post subject: Reply with quote
By the way the case was painted on my engine. I removed the paint. It was pealing and looked awful.
My Patina 66
My 74 Ghia
07 Boxster
Jeckler
Jeckler is offline
PostPosted: Tue Dec 14, 2010 10:40 pm    Post subject: Reply with quote
dave
Geez Dave, you gonna shine a light in my eyes during this interrogation too? Smile Don't I get a cup of coffee or something?
If the link works, it was this stuff. If the link doesn't work, it was ZEP Industrial Purple cleaner and degreaser. I diluted it, partly so it would last longer, and partly because I wanted my skin to last longer as well. I think it was 3 or 4 to 1.
This is what it looks like now, if anyone's wondering. Smile
Andy
djkeev
djkeev is offline
PostPosted: Wed Dec 15, 2010 6:48 am    Post subject: Reply with quote
Jeckler, no interrogation, we all have Home Depots, if this stuff works so great I want to know what it was so I can copy you. Purple Power LIKE doesn't sell product, ZEP Industrial Purple Cleaner does.
Your engine looks great! I don't like perfect looking engines, not real, too shiny and clean. Too clean makes me think of a used car lot where they glossy clear coated EVERYTHING under the hood, always makes me think, what are they hiding with all of that shine? The engine cases never looked that perfect silver when new. Also, If a car is 50 years old, I haven't any problem with it looking like it is a 50 year old well kept engine.
For me, yours has just the right amount of clean and shine. Maybe put the stickers back on the fan shroud and air cleaner but outside of that, excellent.
Dave
Ghia
Vanagon
Beetle
noexit
noexit is offline
PostPosted: Wed Dec 15, 2010 7:50 pm    Post subject: Reply with quote
dave
He did say in his original post that he painted it with heat paint...
