Is this a Schwimmwagen Central Lubrication Pump?
bugpartslou
bugpartslou is offline
PostPosted: Sun May 01, 2011 4:26 am    Post subject: Is this a Schwimmwagen Central Lubrication Pump? Reply with quote
Found this in a box of parts I picked up...is it a Schwimmwagen Central Lubrication pump? Cover says "Pumpe Und Kraftig Betatisen" (pump quickly?) Willy Vogel Berlin W 35 D.R.P., Dann Stussel Sofort Loslassen, triangular mount, works freely.
[/img]
Bruce
Bruce is offline
PostPosted: Sun May 01, 2011 10:38 pm    Post subject: Reply with quote
It looks like it might be the right one.
http://www.thesamba.com/vw/forum/viewtopic.php?t=416158
Gerrelt
Gerrelt is offline
PostPosted: Mon May 02, 2011 9:00 am    Post subject: Re: Is this a Schwimmwagen Central Lubrication Pump? Reply with quote
[/img]
Since nobody else replies, I'll use my best german to translate the text:
"Pumpe kurz und kraftig betatigen"
"press pump short and firm"
"Dann stussel sofort loslassen"
"Then let handle go immediately"
I am not sure about the translation of "stussel", it might not be called a handle, more like a button or something. It's the long thing that can be pressed in.
homepage
black1300
black1300 is offline
PostPosted: Mon May 02, 2011 11:27 am    Post subject: Re: Is this a Schwimmwagen Central Lubrication Pump? Reply with quote
The translation for "Stößel" is "tappet"
Whatsthatsmoke
Whatsthatsmoke is offline
PostPosted: Mon May 02, 2011 2:32 pm    Post subject: Reply with quote
This is not the right pump, it is a little different in shape and has a 45 degree exit, that should be vertical. The pump of the Mercedes 170 fits and has the same shape as on the vw166, only on the side it says 'PX' in the casting. The schwimmwagen reads 100003 on the side if I remember correctly, this is the only right type.
