Harveybacon Samba Member
Joined: April 10, 2011 Posts: 138 Location: Gainesville, FL
SGKent  Samba Member
Joined: October 30, 2007 Posts: 42958 Location: at the beach in Northern Wokistan
Posted: Thu May 19, 2011 8:21 pm Post subject: |
are you leaking brake fluid into it? _________________
Canned Water - the new California approved parts cleaner (except in a drought in which case rub it with sand).
George Carlin:
Skills@EuroCarsPlus:
"never time to do it right but always time to do it twice"  |
maximan1 Samba Member
Joined: January 07, 2008 Posts: 1354 Location: Anaheim, California
Posted: Fri May 20, 2011 8:48 am Post subject: |
You replaced the brake booster without replacing the master cylinder? I was under the impression that those went hand in hand, usually a brake booster goes out when the MC leaks brake fluid into it. _________________ 1978 Transporter, 2.0L FI |
Posted: Fri May 20, 2011 8:57 am Post subject: |
| maximan1 wrote: |
| You replaced the brake booster without replacing the master cylinder? I was under the impression that those went hand in hand, usually a brake booster goes out when the MC leaks brake fluid into it. |
well, no I didn't replace that. So is this something I should do then? They are only 35 bucks on MidAmericaMotorworks' site. All I did was send in booster for rebuild. They will take it back for free, and hopefully fix it. But really, even if MC was leaking, would it blow the newly rebuilt booster after only 30-40 miles again?! Thanks _________________ email: [email protected]
Facebook: http://www.facebook.com/groups/GainesvilleVDubClub
website: http://solemndesigns.com/GainesvilleVDub/?p=1
1971 Campmobile
M-Plate: http://www.vw-mplate.com/mplate-6571.htm |
ccpalmer Samba Member
Joined: September 17, 2006 Posts: 3851 Location: Ann Arbor, Michigan
Posted: Fri May 20, 2011 9:40 am Post subject: |
| Harveybacon wrote: |
| maximan1 wrote: |
well, no I didn't replace that. So is this something I should do then? They are only 35 bucks on MidAmericaMotorworks' site. All I did was send in booster for rebuild. They will take it back for free, and hopefully fix it. But really, even if MC was leaking, would it blow the newly rebuilt booster after only 30-40 miles again?! Thanks |
Little advice - stay away from MAMW. German MCs cost more but I'd say that's one place not to scrimp on parts. _________________ '71 Westy |
Posted: Fri May 20, 2011 9:51 am Post subject: |
| thanks, I just bought the bus for 900 and got 230 in credit to the place MAMW. so it's technically free, and I'm not skimping in theory, lol. Is there a way to check if there is a leak? I didn't notice any fluids when I replaced the part. The guys up at the import shop that sent out booster for me feel that the rebuild people could have just made error and there is no charge to send it back. I just need to know what to do to check the situation out. Thanks for the input guys! |
MAMW did buy OEVeeDub, so they do carry some real German parts but apparently not MCs yet. Maybe save that credit for other parts you'll be needing...
Note - Ouch I just checked German Supply where I got my ATP MC and the prices have skyrocketed... Wolfsburg West has them for $150 though and they say it will fit a '71 with a new reservoir... _________________ '71 Westy |
Posted: Fri May 20, 2011 9:55 am Post subject: |
| also, I need to know if it is going to harm anything to drive it like this. The brakes feel way better since rebuild. But started whining, and revving up when braking. It's not too hot here in FL right now, but would traveling like this hurt any other components? I mean it only revs up when stopping, so of course I'm not using the gas then anyways... Anything going to get worn out that I'm not thinking of? Thanks |
If it were me I'd just cap off the booster vacuum nipple and run without power brakes rather than risk a lean-running engine. _________________ '71 Westy |
aeromech Samba Member
Joined: January 24, 2006 Posts: 17759 Location: San Diego, California
Posted: Fri May 20, 2011 10:34 am Post subject: |
If I left the hose unplugged (no stick) would that be okay? still curious how vacuum works on this, would it being open hurt anything? Thanks!!
You can leave the hose open. When you pulled the booster did you replace all the vacuum hose? There are two pieces, one in front by the booster and one in back that you plugged. Replacement hose is widely available. Use Gates 27231 power brake booter hose. It's 15/32 inside diameter.
What about the check valve? Do you have one? Is it pointed the right way? _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW type 1 1962,63,65,69,72
VW Jetta
VW Passat
Posted: Fri May 20, 2011 11:02 am Post subject: |
| aeromech wrote: |
What about the check valve? Do you have one? Is it pointed the right way? |
Good to know I can have hose open, I'd like to check and see how that works out in a minute. (edit: worked out good, less "hard")
I replaced all hoses that needed it. they are all pretty new except small one, still in good shape. Thanks for heads up on where to get more hose.
I can't seem to find any check valve, unless inside booster. I have read about them, but have no evidence that there is one on my 71 bus. _________________ email: [email protected]
1971 Campmobile
Posted: Fri May 20, 2011 11:09 am Post subject: |
This is bad. You need a check valve. Also, you spoke about a small hose being in good shape. Which is that? These hoses can fail internally and look good on the outside. _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW Jetta
VW Passat
busdaddy Samba Member
Joined: February 12, 2004 Posts: 53221 Location: Surrey B.C. Canada, but thinking of Ukraine
The check valve is in the line between the firewall and the manifold (should be anyways).
I'm not so sure you can blame the master for the failure unless it's obviously leaking fluid, same with pushrod length and vacuum plumbing. If the end of the master is dry the only reason for a failure this soon is a bad rebuild (it happens to the best of shops sometimes). _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Tue May 24, 2011 6:08 am Post subject: |
WELL, i CAN REPLACE THE HOSES THAT HAVEN'T BEEN, JUST FOR PRECAUTION. i SEE NO CHECK VALVE INSIDE ENGINE COMPARTMENT.
Is it okay to drive without power, as I have it now? I don't want to mess anything up doing it this way either. Thanks |
Yes, the brake don't work well but you can get by. People do it all the time. _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW Jetta
VW Passat
Desertbusman Samba Member
Posted: Tue May 24, 2011 8:40 pm Post subject: |
| Is it okay to drive without power, as I have it now? I don't want to mess anything up doing it this way either. |
Sure. Unless you get into that situation that you need every bit of brake available. Then you might mess up the front end of your bus and the back end of some other vehicle. _________________ 71 Superbug
71 Westy |
gd420mj Samba Member
Posted: Fri May 27, 2011 3:50 pm Post subject: |
Since this thread is about rebuilt brake boosters... quick question.
I had mine rebuilt a few years ago by that guy in texas...I have not driven the bus much in those few years. Been garaged. However, even since last year, brakes are not quite right....
My question is this: When I depress the brake pedal, even just 1/2", the servo seems to suck air from the front vent on the push rod. I just pulled off the hose and was blowing into it. I pulled the brake pedal down and the servo immediately leaks air. Even if suck, pull vacuum, it still pull air.
IS THIS RIGHT? the engine revs then stalls out, sometimes it doesn't stall..But there is a vac leak.
So is this booster shot again, after only a few years and less then 5k miles?
I am replacing the MC right now so I will check for leaks. Check valve is in place and no gasoline in vacuum lines. (another cause if servo failure.)
SUcks, as I am driving to VA from NJ in morning to finally get in some much needed camping..
74 westy |
