cast crank?
Page: Previous  1, 2, 3  Next
mark tucker
mark tucker is offline
PostPosted: Tue Jun 07, 2011 11:08 am    Post subject: Reply with quote
my 2028 has a cast crank, but it only has about 50 -60,000 miles on it.
vugbug68
vugbug68 is offline
PostPosted: Tue Jun 07, 2011 12:55 pm    Post subject: Reply with quote
for the fairly inexpensive price of about $200 for a counterweighted forged crank, I dunno why anyone would use a cast crank in a vw engine. But thats just me
71 Super
66 Corvair
69 Baja Bug
DarthWeber
DarthWeber is offline
PostPosted: Tue Jun 07, 2011 1:06 pm    Post subject: Reply with quote
^^^I completely agree.^^^
vwracerdave
vwracerdave is offline
PostPosted: Tue Jun 07, 2011 1:24 pm    Post subject: Reply with quote
20 + years ago before the invasion of all the Chinese crap we have today, there was a time when a quality forged stroker crank cost $500 and cast stroker cranks cost $150. Back then cast stroker cranks were very common.
mark tucker
PostPosted: Tue Jun 07, 2011 2:50 pm    Post subject: Reply with quote
thus the reason for mine.the cast scat chineezze stroker crank.it gets the job done.and done well.does it compare to my crower crank??? yup it runs better............ the crower is in a box, a cardbord box,the cast is in a boxer!!!
DarthWeber
PostPosted: Tue Jun 07, 2011 3:08 pm    Post subject: Reply with quote
Eine tickende Zeitbombe. Wink
Bruce
Bruce is offline
PostPosted: Tue Jun 07, 2011 10:49 pm    Post subject: Reply with quote
DarthWeber wrote:
Bruce wrote:
Just because the Germans didn't know how to make a quality cast iron crank in the 1930s, doesn't mean the Mexicans couldn't do it in the 1990s.
Now THAT'S really funny!! Laughing Laughing
The reason the Germans abandoned the idea of using a cast crank in the 1930s is because they had too many of them breaking in their 23hp engines.
The Mexican engine produces double that, and they don't have any problems with broken cranks.
So yes, VW of Mexico did something the Germans couldn't do.
raygreenwood
raygreenwood is offline
PostPosted: Wed Jun 08, 2011 9:05 am    Post subject: Reply with quote
Where are you guys getting this?.....Cast cranks have been used in millions of vehicles....especially many V-8's and straight six's. They just did not have proper casting technology in 1938. Forging was well advanced.
If its designed properly and designed to have the support within the bearing blocks and has the correct mass in correct areas as well as correct overlap across the rod and main journal area there is no reason why cast cranks won't do well...in fact...its been done.Ray
DarthWeber
PostPosted: Wed Jun 08, 2011 9:26 am    Post subject: Reply with quote
Whenever this "proper casting technology" came about, 40's, 50's, 60's???, then why didn't VW change from forged to cast crankshafts as a cost saving measure? That would have been in VW's heyday and they were all about making a less costly, more profitable (from VW's viewpoint) automobile. Certainly by the 50's, iron casting technology was well known and available to all industrially developed countries. Or maybe the VW engineers just knew something we don't.
jeff68
jeff68 is offline
PostPosted: Wed Jun 08, 2011 9:40 am    Post subject: Reply with quote
Cast cranks definitely have their place. When I worked with the engineers at US automakers that were responsible for engine component design and manufacture I asked them specifically if, when, why, and about any problems they have with using cast crankshafts. First of all they use cast cranks in engine applications that don't see more than 6000 rpm. The engines I discussed with them were V-6 and V-8 configurations. The high output applications used forged cranks. They used Cast cranks to save money, they are much cheaper to manufacture. They had no problems with the cast cranks in non-performance applications. The OEM's don't manufacture their own cast cranks. One engineer asked me why I was asking about this. I explained I was wondering if it would be a good idea to use a cast crank in an old air cooled VW engine. He said that a forged crank would be better in a an aluminum alloy split case design as the split case doesn't provide the structural rigidity that a solid one piece block does. He said he would use a forged crank in that application.
I'd love to see tests on a forged versus modern cast crank, say an 82mm stroke in a high rpm / power application. Run them identically for say 50 thousand miles and compare case - bearing wear, power output etc. There are many that are running these (I think) but I'd love to see what results would show.
mark tucker
PostPosted: Wed Jun 08, 2011 2:14 pm    Post subject: Reply with quote
scat says 150 hp max on thier cast crank.
raygreenwood
PostPosted: Wed Jun 08, 2011 3:06 pm    Post subject: Reply with quote
Forging is not much more expensive than casting as far as cost per unit. Its just that that (a) if you do not have a forging press to start with...that is more expensive than a foundry. (b) The dies wear out faster with forging so there is some added expense....but day to day its not any harder to make one or the other.
The metalurgy of casting in the 1930's was not as easy to verify (alloy and grain structure) and certainly not as easy to QC as it is today.
"Basic"casting was cheap then and cheap now...but high precision casting certainly was not....of which a crankshaft would qualify as very high precision casting. By high precision...I mean exacting material blend, heat treating and grain structure
Have you ever seen the pictures of the forging presses in the Wolfburg plant...or anywhere for that matter? A 100 tons or so and 3-4 stories high...and built to last a 100 years. Why do you think they would switch to casting when they have those?
To get a little grasp on just how far things have come and how iffy they worse back then....metalurgy wise....perhaps do a little reading on several metalurgical issues that were in the forefront back then (or at least came later).
(1) Do some reading about the HOR engined submarines (Hoovens,Owings and Roentsler). A large metalurgical scandal it took most of WW 2 to sort out. A whole series of boast built with a specific type of diesel that was so mysteriously unrelaiable that submarines transiting to Pearl harbor had to take entire sets of extra timing gear sets for all four engines. Many boats had 3 out 4 diesels break down. The cast gears were later after much research found to have a slightly off alloy and cooling pattern (heat treating/quenching)...which was not detectable by the QC methods of the day. It took until 1946 to figure this out.
(2) A few years back they wer able to compare a sample of the Titanics hull taken from a rivet hole knock out in the builders yard....and make a coupon of it....and do a charpy test. It was alwasy wondered why the iceburg did so much damage....it has been found and this is fact....that the steel on the Titanic was improperly cooled in the bloom...and had developed improper grain structure. It literally shattered under impact....and they brought of shards of it to verify.
There is ...or was...an investigation into the this whole issue...because a great many ships during WW 2 and slightly later were using steel made by the same uncontrolled quenching method. The question was how many ships sank during WW-2....from damage that should not have happened.
Yeah...little stupid side stories...but casting very precise items that "might" work as well as a forging...back in th3 30's, 40's and 50's....was not so easy. It was simpler just to use what you know would work...even though a forged crank was overkill for a VW...considering stock they don't go much over 5000 rpm...and until the type 4...they never broke 80 hp. Ray
jhoefer
jhoefer is offline
PostPosted: Wed Jun 08, 2011 3:16 pm    Post subject: Reply with quote
Exactly. They had already made the huge capital investment into forging. No point in throwing that away to go cast.
RockCrusher
RockCrusher is offline
PostPosted: Wed Jun 08, 2011 3:18 pm    Post subject: Reply with quote
To add to what Ray proffered here.....
Henry Ford was the 1st to cast a v-8 block. His engineers and metallurgists told him it was impossible to do and, in fact, there were huge difficulties and all the prototypes cracked while cooling. It was big trouble. I really don't know HOW they solved it but obviously FORD got the process under control for the blocks. VW didn't have any better or newer technology at the time.
2 cent deposit
[email protected] Please use email for all general inquiries.
I will be happy to speak to anyone who has a serious inquiry (meaning real potential business for RC enterprises) or a parts order. Due to machining noise causing missed calls all calls will be returned promptly.
DarthWeber
PostPosted: Wed Jun 08, 2011 4:40 pm    Post subject: Reply with quote
The Gene Berg Book of Technical Articles.
Everything anyone needs to know about cast vs. forged cranks is right in there. Flame on brothers.
modok
modok is offline
PostPosted: Wed Jun 08, 2011 5:13 pm    Post subject: Reply with quote
The main problems i see
-flywheel is held on by dowel pins and a big bolt, so we need the ability to press dowels into it and have strong tough threads
-crank is mainly supported by three main bearings, this does allow a lot more flex than most engines
BTW subaru uses forged cranks, as do most of the import four bangers
jeff68
jeff68 is offline
PostPosted: Thu Jun 09, 2011 7:10 am    Post subject: Reply with quote
The Berg articles about cast crankshafts have a lot of good information and will give you a lot of questions to ask when you're choosing which crank to buy.
Although the precision casting technology may produce a high quality, strong, durable and dependable crank, how many Chinese manufacturers of VW cranks are using this technology? How about the quality of the finish machine work? Are you getting a precision casting and quality finish machine work with a $250 to $300 crank? I'm not so sure and that's what the problem is, you don't know what you're getting.
[email protected]
john@aircooled.net is offline
PostPosted: Thu Jun 09, 2011 8:42 am    Post subject: Reply with quote
20 years ago there was a reason to use a cast crank (save a lot of $), because good forged cranks were $500+. Now, I would not even CONSIDER IT, because you can get a great crank for $300.
It's just advice, do whatever you want with it!
"Like" our Facebook page at
and get a 5% off code for use on one order for VW Parts ON OUR PARTS STORE WEBSITE, vwparts.aircooled.net
mark tucker
PostPosted: Thu Jun 09, 2011 9:58 am    Post subject: Reply with quote
click reerrrrrrrrrrrrr twang!!! can opened,and then there is the cast steel cranks!!!nodgulaur iron,etc there are so many varaition of material, even the forged versions come in somany different types,4130,4140,4110,5140,5110 and so on, and then the heat treetment or nitriding and what type of nitriding, how much aluminum is in the crank makes a difference on the nitriding & it,s effect. I think it is what you know and what you can afford and what you are sent.I was sent a 4040 crank from cip1 as a 4340 nitrided crank. I can tell the deferance, but I would bet there is a lot of guys who cant. does any body know what the material oe vw crank was made of??
DarthWeber
PostPosted: Thu Jun 09, 2011 10:09 am    Post subject: Reply with quote
I believe it was 1045??
Page 2 of 3
