1500 'S' M249 Option
Aaron M265
Aaron M265 is offline
PostPosted: Fri Dec 04, 2009 6:48 pm    Post subject: 1500 'S' M249 Option Reply with quote
VW 1500 ‘S’ M249 Option
I decided to put this document together a while back after seeing some information posted by Scott Taylor on his fantastic VW+VW1500 blog.
My 1964 1500 'S' (C # 315 031 871, E # 0 682 209) came equipped with this option, however when I quizzed VW in Germany, they had little back ground information on what this option was.
Thus I was compelled to pull all the information together (with Scott's help) and here we have it.
I hope you enjoy it.
Overview
This document outlines the specifications and performance figures for VW 1500 ‘S’ vehicles produced during 1964 & 1965, fitted with the M249 option.
The M249 option substituted the 1500 ‘N’ flat-top pistons for the 1500 ‘S’ high-compression dome-top pistons, effectively lowering the compression from 8.5:1 to 7.8:1 and allowing the use of regular fuel.
They looked outwardly identical to the standard 1500 ‘S’ engines except for a metal plate attached to the crankcase breather stand and a letter ‘N’ stamped on the case (*1).
To avoid confusion, the standard high-compression 1500 ‘S’ engine cases were stamped ‘R’ (*2), as this chart from the VW Workshop Manual shows:
(*1)- ‘N’ stamped into VW 1500 ‘S’ M249 engines (63.5 bhp) adjacent to Engine #
(*2)- ‘R’ stamped into VW 1500 ‘S’ engines (66 bhp) adjacent to Engine #
(from 18 February 1965, Chassis # 315 124 961, Engine # 0 878 040)
Note:
A twin-carburettor engine with flat crown pistons is available for use in countries where premium fuel with an octane rating of more than 95 (Res. F1) is not available.
This engine requires fuel with a rating of at least 90 octane and has an aluminium plate with the wording
M249
90 Octane
fixed to the two front screws of the breather mounting.
Part No’s.
Engine, complete 311 100 021J
Piston 83 mm dia. 311 107 101J
Twin-carburettor Engine
Capacity 1493cc (as before)
Compression ratio 7.8:1
Maximum output (DIN) 52 bhp at 4200 rpm
(SAE, with air cleaner) 63.5 bhp at 4800 rpm
Maximum torque (DIN) 10.4 mkg (75.2 ft. lbs) at 2400 rpm
(SAE, with air cleaner) 11.1 mkg (80.2 ft. lbs) at 3000 rpm
Ignition timing 10’ before TDC (as before)
Performance
Maximum and cruising speed approx 132 kph (81 mph) (sedan & variant) 142 kph (88 mph) (Karmann)
At an engine speed of approx 4150 rpm (sedan & variant) 4450 rpm (Karmann)
Road speed at 4200 engine rpm:
1st gear approx 31 kph (19 mph) (sedan & variant) 31 kph (19 mph) (Karmann)
2nd gear approx 58 kph (36 mph) (sedan & variant) 58 kph (36 mph) (Karmann)
3rd gear approx 90 kph (56 mph) (sedan & variant) 90 kph (56 mph) (Karmann)
4th gear approx 133 kph (82 mph) (sedan & variant) 133 kph (82 mph) (Karmann)
Reverse approx 30 kph (18 mph) (sedan & variant) 30 kph (18 mph) (Karmann)
Hill climbing ability, on good roads, with two occupants:
1st gear approx 44.0% (sedan) 44.0% (Karmann) 37.0% (variant 375 kg) 36.0% (variant 465 kg)
2nd gear approx 22.5% (sedan) 22.5% (Karmann) 19.0% (variant 375 kg) 18.0% (variant 465 kg)
3rd gear approx 13.5% (sedan) 13.5% (Karmann) 11.0% (variant 375 kg) 10.5% (variant 465 kg)
4th gear approx 7.5% (sedan) 8.0% (Karmann) 6.5% (variant 375 kg) 6.0% (variant 465 kg)
*) With half payload
Acceleration times (through the gears)
from 0 - 80 kph (50 mph) approx 13 seconds (sedan & variant) 13 seconds (Karmann)
from 1 - 100 kph (62 mph) approx 21 seconds (sedan & variant) 20 seconds (Karmann)
from 80 – 100 kph (50 – 62 mph approx 8 seconds (sedan & variant) 7 seconds (Karmann)
Fuel Consumption
Average fuel consumption (tested in
Accordance with German regulations) per 100 km 8.1 litres 8.2 litres
(Imp. 35 mpg; US. 29 mpg) (34.5; 28.6)
Fuel rating 90 Octane (Res. F1)T-1
10
Aaron
http://1500notchback.blogspot.com/
Need to contact me? Email is faster than a PM - [email protected]
For T3 Panel Van information:
http://www.thesamba.com/vw/forum/viewtopic.php?t=389465
Russ Wolfe
Russ Wolfe is offline
PostPosted: Fri Dec 04, 2009 7:11 pm    Post subject: Reply with quote
I note that the picture you post looks like it still has the "4R3" distributor.
My 64 1500S did not have any of the extra stampings in the engine number. It was an all original 1500S that the engine had never been out of.
I have the original factory documents verifying that the engine is original to the chassis.
Gary: OK. Ima poop.
t3kg
t3kg is offline
PostPosted: Fri Dec 04, 2009 11:56 pm    Post subject: Reply with quote
There's no doubt that your 1500S is all original. Almost all of the 1500S's built had the normal setup like yours. It's only the relative few that were ordered with M249 that got the tag, which signified flat top pistons in an otherwise normal 1500S engine. I think the extra N or R stamping was only used from February 1965 to the beginning of the 1966 model year. Aaron, does your car have the N stamp next to the engine number?
My old March 1965 Squareback had the N:
I WAS THERE! The 2017 Type 3 Rally / September 29–October 1 / Cayucos, CA
2014: The 2014 Type 3 Rally / October 3–5 / Cayucos, CA
2011: 50 Years of the VW Type 3 / September 29–October 1 / California Central Coast
BerT3
BerT3 is offline
PostPosted: Sat Dec 05, 2009 1:10 am    Post subject: Reply with quote
I do have a white paint stamp with that code in front of the fan housing on my T34 !
NO tag
I might have a photo somewhere
BerT3
Russ Wolfe
PostPosted: Sat Dec 05, 2009 9:15 am    Post subject: Reply with quote
M249 also stands for automatic trans in the later cars.
That would explain Bert's markings.
Gary: OK. Ima poop.
BerT3
BerT3 is offline
PostPosted: Sat Dec 05, 2009 9:23 am    Post subject: Reply with quote
The car in question a my '66 manual with a '65 S specification engine
BerT3
Aaron M265
PostPosted: Sat Dec 05, 2009 4:22 pm    Post subject: Reply with quote
No mine doesn't Scott as my car is a September 64 model. As you correcrly pointed out, the 'N' or 'R' stamping was only from February 65.
Yes VW also re-used the M249 code for automatic transmissions later in life but that's irrelevant here.
My car has the M249 alumimium tag still attached to the breather stand too.
Aaron
T3+4_Mike
T3+4_Mike is offline
PostPosted: Sun Jun 05, 2011 9:50 am    Post subject: Reply with quote
I know that this is an old post, but I stumbled upon it while searching for some information on my car. I just bought a 1965 Notchback 1500S. The original motor has been swapped out with my gues a factory rebuilt one as the first litter is a U, but thats besides the point. What I was wondering is, I noticed while cleaning up the front apron, there was a sticker that said "90 Oktan" on it. I was wondering if this car originally came with the M249 option motor? I have not seen one of those stickers before as none of my other cars have one. If it did, how hard would it be to find one? Thanks for any information.
1 rusty low vin-ed 1967 squareback- very long restoration project
1973 412 4-door sedan, basket case to say the least
1967 fastback, rat rod build
1969 fastback,
1965 Notchback, The mother's summer car now! http://www.thesamba.com/vw/forum/viewtopic.php?t=477439
1986 Jetta Diesel 5spd, Was the beater, now currently undergoing an overhaul
1995 Chevrolet Caprice, The daily driver and tow rig
"You say it's rotted out, I say its weight reduction, better fuel economy Very Happy "
t3kg
t3kg is offline
PostPosted: Sun Jun 05, 2011 6:43 pm    Post subject: Reply with quote
Can you post a picture of it?
AzzA
AzzA is offline
PostPosted: Mon Jun 06, 2011 5:37 pm    Post subject: Reply with quote
When you say "sticker", you mean metal label like in the photos above yeah?
Mine has one too. Thanks to this thread I've learnt what it means.
Cheers
__my Aussie '65 1500s notch project__
T3+4_Mike
PostPosted: Mon Jun 06, 2011 8:03 pm    Post subject: Reply with quote
I'm sorry, It wasn't the 90 oktan sticker on mine, I had it confused with another car, I think my buddies 914. Mine has a sticker that says super/premium! wich would be 90 or higher though? None of my other cars have it.
http://www.thesamba.com/vw/forum/album_page.php?pic_id=814222
1969 fastback,
t3kg
t3kg is offline
PostPosted: Mon Jun 06, 2011 9:02 pm    Post subject: Reply with quote
I think all 1965 1500S Type 3s and 34s got the Super/Premium sticker.
t3kg
t3kg is offline
PostPosted: Mon Jun 06, 2011 9:06 pm    Post subject: Reply with quote
Cheers
Cool, another one found. Was your car built after February 1965? If so, does it have the letter N stamped near the engine number?
Joerg Fischer
Joerg Fischer is offline
PostPosted: Thu Jun 09, 2011 6:44 am    Post subject: Reply with quote
Hello from Germany,
since there were certain problems with the 1500S engines, later in the sixties VW replaced broken original 54hp 1500S engine always with the/a 52 hp-version.
Regards
Jörg
t3kg
t3kg is offline
PostPosted: Thu Jun 09, 2011 12:46 pm    Post subject: Reply with quote
Thanks Jörg, that's interesting, I wasn't aware of that.
must50302
must50302 is offline
PostPosted: Tue Feb 05, 2013 9:38 am    Post subject: Reply with quote
I have this option on my car!! Just found out a few weeks ago!
this is my porject link:
http://www.thesamba.com/vw/forum/viewtopic.php?t=447718
t3kg
t3kg is offline
PostPosted: Tue Feb 05, 2013 3:36 pm    Post subject: Reply with quote
Cool, what's your engine number? Is there a letter "N" stamped near the engine number on the case?
must50302
PostPosted: Tue Feb 05, 2013 3:38 pm    Post subject: Reply with quote
I will have to check when I get home from work today!
must50302
PostPosted: Mon Mar 25, 2013 11:05 pm    Post subject: Reply with quote
No "N" stamped on the engine. My engine number is 0755120
W1K1
W1K1 is offline
PostPosted: Tue Mar 26, 2013 6:01 am    Post subject: Reply with quote
Mine is stamped behind the flywheel,
sept 64 production 0693298 engine #
1973 super 2110cc
1965 squareback 1500E-sold
1971 bay window westy- EJ2.5 subi swap
