foodeater Samba Member
Joined: July 13, 2007 Posts: 1318 Location: Newburgh, NY
Posted: Wed Feb 23, 2011 1:36 pm Post subject: |
With that type of window you'd want to be real sure that no one's arm or anything else is sticking out before opening the slider. _________________ 89 Bluestar-2.5 Subaru Powered-RIP
'84 Westy Tiico-daily driver-sold
'82 Caddy diesel-sold
'87 Vanagon Syncro-RIP
'81 diesel rabbit-sold
'82 Vanagon auto-RIP |
joetiger  Samba Member
Joined: January 27, 2005 Posts: 5264 Location: denver
Posted: Wed Feb 23, 2011 2:16 pm Post subject: |
I received a very fast response:
"To my knowledge, we've never built a replacement window for a Vanagon.
Replacement options would be predicated on the rough opening corner radii
dimensions and requirements for installation i.e. lock rubber gasket, inside
clamp ring, ect.
Peninsula Glass
Vancouver, WA" _________________ Joe T.
'02 Baja-ish Beetle "Bubbles"
Justice for Megan: https://linktr.ee/justiceformegantrussell |
otiswesty Samba Member
Joined: November 21, 2006 Posts: 1768 Location: Portland
Posted: Wed Feb 23, 2011 4:36 pm Post subject: |
If someone wants to get a factory VW rear slider driver's side window like the one I had for sale for 7 months, I may have access to one available for sale. The price would also be high at $450. Serious inquiries only by PM. _________________ 1978 Sage Green P22 Westfalia
1988 T3 Syncro Single cab
Just a regular guy |
rockfish Samba Member
Joined: February 13, 2007 Posts: 740 Location: Palo Alto, Calif.
syncrodoka Samba Member
Joined: December 27, 2005 Posts: 12347 Location: Santa Cruz, CA
Posted: Wed Feb 23, 2011 5:15 pm Post subject: |
rockfish- this thread is about the rear window sliders nearest the rear hatch, not the middle window sliders that we all have. Thanks |
spitsnrovers Samba Member
Joined: December 17, 2005 Posts: 940 Location: Calgary, Canada
Posted: Wed Feb 23, 2011 5:57 pm Post subject: |
Have you checked out www.griffco.ca/interest/ and look for the Westfalia link?
I also asked at a fabricator of RV windows - the answer was that they couldn't bend the tight radius needed for the VW openings. Hence the mod and kit that I came up with. _________________ '88 VW Westfalia
'75 Triumph Spitfire 1500 |
Wellington Samba Member
Joined: September 21, 2004 Posts: 2009 Location: Montreal
Posted: Thu Jun 09, 2011 6:19 pm Post subject: |
So this is life with young kids......time has gotten away from me. Originally started in 2007, two alterations later and four years, I think I finally got the ultimate windows!!! Rear sliders with screens. I can't wait till the first night's sleep with ventillation on the lower bed.
Since the window film tint starting to peel, and the center sliders need new felt seals, I redid them at the same time. I had new tinted glass cut and tempered for all sliders, had the frames stripped and anodized black.
I originally wanted to do the black window seals but found the quality was not as good as my originals, so I installed new chrome mouldings in the original window seals, I really like the look.
If anyone is interested in a SET, I'm considering offering them on an exchange basis. I will do a classified with deatails shortly. |
noganav Samba Member
Joined: January 06, 2006 Posts: 1236 Location: San Diego CA
Posted: Thu Jun 09, 2011 7:20 pm Post subject: |
Definitely interested in a set of back sliders. Would your method work with the 87-91 style vented back glass? |
fatboypaul Samba Member
Joined: August 24, 2004 Posts: 432 Location: Emeryville, Ca, SF Bay.
Posted: Thu Jun 09, 2011 8:00 pm Post subject: |
I would prefer the factory style latch that Wellington uses on his version over the SA middle of the glass style that GW is selling.
Taylor trying to be a catalog model He does do the look into the distance squinting pose quite well though.
ajdenette Samba Member
Joined: February 15, 2009 Posts: 768 Location: Hope Valley RI
Syncroincity Samba Member
Joined: April 15, 2007 Posts: 1557 Location: New York City
Posted: Thu Jul 28, 2011 9:14 pm Post subject: |
joetiger wrote: |
Thread Resurrection...
I was reading the Jalousie Window thread (having seen Winston's personally, they are quite impressive) I started thinking again about rear sliding windows. Has anybody tried RV replacement windows? I started looking around and saw this website;
I figured it was a dead end until I saw the shape of the example window on their order worksheet:
http://www.motionwindows.com/order-summary-worksheet.pdf
Their 900 series actually looks quite similar to the factory sliders... and it's a rubber gasket-style frame, so it'll install identically to a factory window. If they can do the bend radius we need, these should be an easy solution.
http://www.motionwindows.com/prod900.php
All one has to do is make some precise measurements of the window opening on the van, and fill out the order form with your preferences. If anyone has the rear windows out, and could post the measurements listed on the order form, we could get a definite answer and price estimate. Hardest part is gauging the radius of the corners. _________________ '86 Syncro CHC Top AAZ Turbodiesel
'04 Passat Variant 4Mo 5MT
Vanagon Build: http://www.thesamba.com/vw/forum/viewtopic.php?t=466866&highlight= |
thummmper Samba Member
Joined: November 25, 2009 Posts: 2015 Location: Meadow Valley, California Republic
Posted: Fri Jul 29, 2011 8:23 pm Post subject: |
I will eventually get windstar popouts annealed and cut to size and just use the hardware and seals on all four-- done. modern curved glass that flushes out to the skin. |
danfromsyr Samba Member
Joined: March 01, 2004 Posts: 15385 Location: Syracuse, NY
Posted: Mon Aug 01, 2011 8:58 am Post subject: |
Following the guide from Spitsnrovers I made my rear slider this past week.
Success, and Canine approved..
maybe now Scout won’t get banged up trying to put her head out the sliding door slider window.
I made this to be installed backwards to allow the rearmost section to slide, trying to keep Scout to the rear cushion while travelling.
If being made for rear passenger comfort, then make the window to slide in the front half..
*Note the new 3seams on the leading edge where OE has just the middle.
The cuts & shortening MUST be done on the fixed piece to securely retain the frame & glass in the groove.
*Note next time I’ll move the new upper&lower seam a little more central to the fixed window.
Hardboard underlay spacer to fit into Glass groove in Rubber window seal
Thin Stainless steel sheet overlay to protect the MDF hardboard backer, left straight edge along the frame,
This does allow a little of the lower curve to show, but the Glass rubber will cover that.
Inside view of the MDf hardboard backer in installed window
Note that none of the MDf is visible, but I did seal the SS edge with silicone to prevent seepage.
I found these paint can openers VERY handy for removing & installing the new frame,
They allowed me to slip it in between the frame and the lip and pull the rubber seal flap a little (1/8in) at a time..
Was slow progress but any progress leads to success.
I would slip in with the hook away from rubber, then twist 180* and use hook to pry/pull small lip of rubber over body frame lip..
Abscate wrote: |
Posted: Mon Aug 01, 2011 9:33 am Post subject: |
^^^ that looks great, good idea to open in the rear for the dog also _________________ 1978 Sage Green P22 Westfalia
dobryan Samba Member
Joined: March 24, 2006 Posts: 17178 Location: Brookeville, MD
Posted: Wed Aug 03, 2011 9:46 am Post subject: |
I should add note that I already had a fixed rear piece of solid glass to use as a guide & template.
if you don't have a spare, then you'll need to remove your rear glass in order to match up the outer profile to make your filler piece.
my pieces went in tight, so I could recommend to make it slightly smaller than the OEM glass. say 1/8" or so to allow easier install of the rubber seal.. the window is held in afterall by the whole perimiter of the seal so even if it's a little loose, it'll set in and seal fine.
to make a rear portion slider like mine above
I used the Drivers side slider section from a Passanger van (50/50 window)
and a Drivers side fixed section from a Westfalia (30/70 window)
If you were going to make a rear slider window with the front half that opens, you would want the donating parts from the Passanger side.
*unless you were also making one of these for the driver's rear corner.
this did cause some confusion to my at times befuddled mind. but in the end It worked out.
If you're in doubt of ability to make a filler piece, then the $70 kit offered by spitsnrovers might not be a bad deal.
http://www.griffco.ca/interest/vw/slider.htm
Hmm, looks like his just shortens a single stock Passanger van 50/50 middle window. allowing more overlap and less window opening than the mix&match of 2 donor windows (1westy/1pass van) but I had already pulled my Driverside middle window to install the Bay Jalousie window for more ventillation & rain protection.
Quote: |
But here is my version.
The route I chose was to shorten a standard Vanagon sliding-door slider-window, and keep the corners at the original radii. This would eliminate the need to rebend the anodized aluminum channel to fit the two non-square corners at the rear of the window, and having to splice a piece of channel into the back end to account for the longer diagonal.
In this version a black plastic filler was made to replace the vent unit that was originally there.
A modification kit consisting of the machined black plastic filler piece, new fuzzy weather strip and 10 page instructions with measurements and photos is available for $70. Contact me by emailing Mail Us. Payment can be made by PayPal
*edit, Hmm looking at each closer the allowable window opening is the same if you use Westy &Pass glass or just shorten the Pass frame with both Pass window pieces. the only differance is there is more of an overlap, the amount of opening is determined by when the sliding portion (Pass slider glass) hits the rubber bumper in the shortened frame. which is the same in both versions.. so no need to use a Westy short piece other than asthetics or personal choice.
these images are of just a modified pass van slider. showing opening & overlapp.
Open
Closed
mine closed
Abscate wrote: |
chojinchef Samba Member
Posted: Wed Mar 14, 2012 8:01 pm Post subject: |
But, and correct me if I am wrong, is that not from a later SA build? Which means the window sizes are larger than out North American versions? Still out of my price range one way or another.
LP _________________ Its a mistress; an expensive, whiney, needy bitch of a mistress. She is a chunky, dirty girl with bad skin, little motivation and yet she always makes me smile. She sure has been around before shacking up with me. She has a direct line to my wallet, plays with my emotions, is consistantly jovial yet with a sarcastic and sardonic side, is consistant in her inconsistancy, and every once in a while gives me a great ride and a fantastic memory. |
Posted: Wed Mar 14, 2012 8:12 pm Post subject: |
That is for a regular vanagon by the location of the slider latch on the bottom like we are all used to.
The SA sliding windows have a latch in the center of the sliding window and they look different.
Too rich for my blood too. |
