bassam Samba Member
Posted: Thu Jun 16, 2011 5:21 am Post subject: Tachometer question |
I bought one of those tachometers you put on the dashboard. I tested it in the engine bay first. So needle does not go up very fast nor does it come back down fast either. I've never seen a tach on a vw before. but is that normal cuz the engine is a slow one or am i missing something? _________________ 1973 VW Squareback |
Mike Fisher Samba Member
Joined: January 30, 2006 Posts: 18046 Location: Eugene, OR
Posted: Thu Jun 16, 2011 5:30 am Post subject: |
A cheap generic tachometer is Unlikely to read correctly. Better hook up a good tachometer/dwell meter at the same time and compare the 2 tachometers. _________________ https://imgur.com/user/FisherSquareback/posts
69 FI/AT square Daily Driver
two 57 oval ragtops sold
'68 Karmann Ghia sold
blankmange Type 3 Darksider
Joined: July 17, 2004 Posts: 11498 Location: Bloßer Stahl-preapocalyptic MidCoast
Posted: Thu Jun 16, 2011 5:34 am Post subject: Re: Tachometer question |
bassam wrote: |
I've never seen a tach on a vw before. |
now you have... _________________ póg mo thóin
Certified DHS Technician
Samba Member # 24517 |
FastyinaField Samba Member
Joined: December 25, 2009 Posts: 48 Location: New Hampshire
Posted: Fri Jun 17, 2011 12:35 am Post subject: |
And a second one for good measure:
Gizmobob Samba Member
Joined: December 06, 2006 Posts: 1001 Location: Apple Valley, CA
Posted: Fri Jun 17, 2011 8:45 am Post subject: |
When they aren't available... some just make your own.
_________________ "And now, in the interest of equal time, here is a message from the National Institute of Pancakes: It reads, and I quote, "Fuck waffles." " - George Carlin
'61 Type 311-Black
'62 Type 311-Gulf Blue (Germany)
'62 Type 313-Anthracite (Germany)
'62 Type 311-Gulf Blue (Italy)
'63 Type 361-Anthracite (Sweden)
'64 Type 343-Pacific Blue/Blue-White (Germany) |
Komissar Samba Member
Joined: May 18, 2008 Posts: 894 Location: Bucharest, Romania
Posted: Fri Jun 17, 2011 9:58 am Post subject: |
I dont' have my type3 "at hand" to measure... what's the width of the clock face opening ? Or the width of the clock with or without the chrome bezel? _________________ 1965 Sunroof Beetle
1972 Type 3 Squareback
1978 Skoda 105S |
OhHerrooo Samba Member
Joined: September 12, 2010 Posts: 1291 Location: Costa Mesa, CA
supaninja Samba Member
VW-Variant-L Samba Member
Joined: March 09, 2006 Posts: 160 Location: Victoria, Australia
Posted: Fri Jun 17, 2011 7:33 pm Post subject: |
Komissar wrote: |
I dont' have my type3 "at hand" to measure... what's the width of the clock face opening ? Or the width of the clock with or without the chrome bezel? |
Clock and fuel gauge housing is 85mm, and with bezel the face is about 90mm, Cheers. |
toddgsanford Samba Member
Posted: Mon Jun 20, 2011 12:43 pm Post subject: |
to answer your original question most generic tachs are set up to run a 4,6, 0r 8 cylinder motor if the needle is very erratic check for a switch to adjust this setting. I have heard of people putting the Jiggler/vibrator like on the gas guage to accomplish a cleaner needle movement but have not tried this. the green wire on most generic tachs goes to the same point on your coil as your condensor. and there is a seperate power wire (red) as well. I have never seen one I could not get to work smoothly . Sun makes a tach the same size as the clock in most type 3 and I did the same to mine. Although Gizmobobs looks a whole lot more stock than mine. I will post a link to my phot bucket once I verify I have that pic up |
Woreign Samba Member
Joined: June 04, 2006 Posts: 2841 Location: Crestview FL
Posted: Mon Jun 20, 2011 12:48 pm Post subject: |
supaninja wrote: |
Did somebody say tach?
Why is your horn button Pink???? (Not there's anything wrong with that...) |
baggabones Samba Member
Joined: October 13, 2004 Posts: 71 Location: wales, uk
Posted: Tue Jun 21, 2011 5:15 am Post subject: |
How do you guys run the wire to coil (squareback) ? |
Posted: Tue Jun 21, 2011 6:38 am Post subject: |
baggabones wrote: |
I ran a long wire from the dash, along the tunnel (under the carpet) and out through the grommet under the rear seat in the battery compartment, and back into the engine bay... _________________ póg mo thóin
Brent Samba Member
Joined: April 28, 2010 Posts: 1622 Location: San Tan Valley, AZ
Posted: Tue Jun 21, 2011 7:38 am Post subject: |
baggabones wrote: |
Without the FI, I've been thinking of running the wire through the extra fuel line since I've got the pan off. |
MOCHABILL Samba Member
Joined: June 12, 2008 Posts: 584 Location: BY THE BAY
Posted: Tue Jun 21, 2011 8:07 am Post subject: |
baggabones wrote: |
Recall seeing a post about using the unused red wire in the loom that is not used in manual trans models.
I know that my square has it in the engine wiring and in the wiring under the dash.
Bill _________________ '71 Squareback FI
'07 Passat wagon 2.0
'03 Ranger 4door 4.0 |
68squareizm Samba Member
Joined: December 07, 2007 Posts: 179 Location: Huntington Beach
Posted: Tue Jun 21, 2011 9:30 am Post subject: Re: Tachometer question |
Dude are those 914 gauges?
blankmange wrote: |
bassam wrote: |
now you have... |
Posted: Tue Jun 21, 2011 9:56 am Post subject: Re: Tachometer question |
68squareizm wrote: |
no - Type 3 gauges.. from Australia... _________________ póg mo thóin
Bobnotch Samba Member
Joined: July 06, 2003 Posts: 23441 Location: Kimball, Mi
Posted: Tue Jun 21, 2011 2:04 pm Post subject: |
MOCHABILL wrote: |
baggabones wrote: |
Bill |
Yup, that's what I used on my 71 Square-vert.  _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
Posted: Sun Jun 26, 2011 1:39 pm Post subject: |
I've just up-graded mine with a tachometer which looks "at home" in my dash...
It's a vintage Smiths (made in UK) vintage 70's something tach. it's a perfect fit into the clock opening.
With a redline that you can setup wherever you like
Uploaded with ImageShack.us _________________ 1965 Sunroof Beetle
1978 Skoda 105S |
