Tachometer question
bassam
bassam is offline
PostPosted: Thu Jun 16, 2011 5:21 am    Post subject: Tachometer question Reply with quote
I bought one of those tachometers you put on the dashboard. I tested it in the engine bay first. So needle does not go up very fast nor does it come back down fast either. I've never seen a tach on a vw before. but is that normal cuz the engine is a slow one or am i missing something?
1973 VW Squareback
Mike Fisher
Mike Fisher is offline
PostPosted: Thu Jun 16, 2011 5:30 am    Post subject: Reply with quote
A cheap generic tachometer is Unlikely to read correctly. Better hook up a good tachometer/dwell meter at the same time and compare the 2 tachometers.
69 FI/AT square Daily Driver
two 57 oval ragtops sold
'68 Karmann Ghia sold
blankmange
Type 3 Darksider
blankmange is offline
PostPosted: Thu Jun 16, 2011 5:34 am    Post subject: Re: Tachometer question Reply with quote
now you have...
póg mo thóin
Certified DHS Technician
Samba Member # 24517
FastyinaField
FastyinaField is offline
PostPosted: Fri Jun 17, 2011 12:35 am    Post subject: Reply with quote
And a second one for good measure:
Gizmobob
Gizmobob is offline
PostPosted: Fri Jun 17, 2011 8:45 am    Post subject: Reply with quote
When they aren't available... some just make your own. Cool
"And now, in the interest of equal time, here is a message from the National Institute of Pancakes: It reads, and I quote, "Fuck waffles." " - George Carlin
'61 Type 311-Black
'62 Type 311-Gulf Blue (Germany)
'62 Type 313-Anthracite (Germany)
'62 Type 311-Gulf Blue (Italy)
'63 Type 361-Anthracite (Sweden)
'64 Type 343-Pacific Blue/Blue-White (Germany)
Komissar
Komissar is offline
PostPosted: Fri Jun 17, 2011 9:58 am    Post subject: Reply with quote
I dont' have my type3 "at hand" to measure... what's the width of the clock face opening ? Or the width of the clock with or without the chrome bezel?
1965 Sunroof Beetle
1972 Type 3 Squareback
1978 Skoda 105S
OhHerrooo
OhHerrooo is offline
another for good measure
'67 Squareback
'69 Squareback
'68 Westfalia
'68 Squareback
OCT3 - Orange County Type 3's
www.evenkeelsurfshapes.com
supaninja
supaninja is offline
PostPosted: Fri Jun 17, 2011 10:03 am    Post subject: Reply with quote
Did somebody say tach?
Twisted Evil
http://i5.photobucket.com/albums/y163/chucky1974/ninja.gif
Nick
Megasquirted Type 4 powered Notch http://www.thesamba.com/vw/forum/viewtopic.php?t=427890&postdays=0&postorder=asc&start=0
Blog of Doom http://supaninjanick.wordpress.com/
View user's profile Send private message Send e-mail Yahoo Messenger Facebook Classifieds Feedback
VW-Variant-L
VW-Variant-L is offline
PostPosted: Fri Jun 17, 2011 7:33 pm    Post subject: Reply with quote
Clock and fuel gauge housing is 85mm, and with bezel the face is about 90mm, Cheers.
toddgsanford
toddgsanford is offline
PostPosted: Mon Jun 20, 2011 12:43 pm    Post subject: Reply with quote
to answer your original question most generic tachs are set up to run a 4,6, 0r 8 cylinder motor if the needle is very erratic check for a switch to adjust this setting. I have heard of people putting the Jiggler/vibrator like on the gas guage to accomplish a cleaner needle movement but have not tried this. the green wire on most generic tachs goes to the same point on your coil as your condensor. and there is a seperate power wire (red) as well. I have never seen one I could not get to work smoothly . Sun makes a tach the same size as the clock in most type 3 and I did the same to mine. Although Gizmobobs looks a whole lot more stock than mine. I will post a link to my phot bucket once I verify I have that pic up
Woreign
Woreign is offline
PostPosted: Mon Jun 20, 2011 12:48 pm    Post subject: Reply with quote
Twisted Evil
Why is your horn button Pink???? (Not there's anything wrong with that...)
supaninja
PostPosted: Mon Jun 20, 2011 12:52 pm    Post subject: Reply with quote
Woreign wrote:
Twisted Evil
Because pink is the new black Wink
Nick
baggabones
baggabones is offline
PostPosted: Tue Jun 21, 2011 5:15 am    Post subject: Reply with quote
How do you guys run the wire to coil (squareback) ?
blankmange
Type 3 Darksider
PostPosted: Tue Jun 21, 2011 6:38 am    Post subject: Reply with quote
I ran a long wire from the dash, along the tunnel (under the carpet) and out through the grommet under the rear seat in the battery compartment, and back into the engine bay...
póg mo thóin
Brent
Brent is offline
PostPosted: Tue Jun 21, 2011 7:38 am    Post subject: Reply with quote
Without the FI, I've been thinking of running the wire through the extra fuel line since I've got the pan off.
MOCHABILL
MOCHABILL is offline
PostPosted: Tue Jun 21, 2011 8:07 am    Post subject: Reply with quote
Recall seeing a post about using the unused red wire in the loom that is not used in manual trans models.
I know that my square has it in the engine wiring and in the wiring under the dash.
Bill
'71 Squareback FI
'07 Passat wagon 2.0
'03 Ranger 4door 4.0
68squareizm
68squareizm is offline
PostPosted: Tue Jun 21, 2011 9:30 am    Post subject: Re: Tachometer question Reply with quote
Dude are those 914 gauges?
blankmange wrote:
now you have...
blankmange
Type 3 Darksider
PostPosted: Tue Jun 21, 2011 9:56 am    Post subject: Re: Tachometer question Reply with quote
no - Type 3 gauges.. from Australia...
póg mo thóin
Bobnotch
Bobnotch is offline
PostPosted: Tue Jun 21, 2011 2:04 pm    Post subject: Reply with quote
Bill
Yup, that's what I used on my 71 Square-vert. Cool
Bob 65 Notch S with Sunroof
Tram wrote:
Tram wrote:
Komissar
Komissar is offline
PostPosted: Sun Jun 26, 2011 1:39 pm    Post subject: Reply with quote
I've just up-graded mine with a tachometer which looks "at home" in my dash...
It's a vintage Smiths (made in UK) vintage 70's something tach. it's a perfect fit into the clock opening.
With a redline that you can setup wherever you like Very Happy
Uploaded with ImageShack.us
1965 Sunroof Beetle
1978 Skoda 105S
