clooney Samba Member
Posted: Sun Jul 03, 2011 10:39 am Post subject: CB cheater cam or engle 100 in a stock 1600 |
would there be any big difference iof i were to use these 2 cams in a stock 1600 motor?
reason i am asking is because my son dropped the only stock cam I have and it broke into 2, so i have to buy a cam anyway.
am i just wasting my time and better off to buy another stock cam?
motor will just be a stock 1600, new KS 85.5 pistons, stock crank, rods full flowed, mildly ported stock heads, dual 36 DRLAs. lightweight bug, stock ratios.
daily driver for my son. |
borninabus  Samba R&D Dept.
Joined: May 18, 2006 Posts: 4751 Location: Arizona Highways
Posted: Sun Jul 03, 2011 10:55 am Post subject: |
yes there will be a huge difference.
especially if you use them both
seriously though: the 100 has a great low end. the only thing i didn't like about mine was the not as smooth as stock idle. _________________ 88 Van WBX, A/T - 93 Multivan 5cyl 5M/T - 13 JSW TDI 6M/T - 2012 Touareg TDI Sport |
Posted: Sun Jul 03, 2011 10:58 am Post subject: |
borninabus wrote: |
seriously though: the 100 has a great low end. the only thing i didn't like about mine was the not as smooth as stock idle. |
yours had stock carburation and what compression? |
Posted: Sun Jul 03, 2011 11:26 am Post subject: Re: CB cheater cam or engle 100 in a stock 1600 |
that engine is screaming for an Engle 110 or Web 163 _________________ It's just advice, do whatever you want with it!
"Like" our Facebook page at
and get a 5% off code for use on one order for VW Parts ON OUR PARTS STORE WEBSITE, vwparts.aircooled.net |
Matthew Samba Member
Joined: January 29, 2004 Posts: 1760 Location: Eastern Tennessee
Posted: Sun Jul 03, 2011 11:28 am Post subject: |
If you are going to use dual carbs and an extractor exhaust, you certainly would benefit from using a bigger camshaft. The dual carbs would make it idle as smooth or smoother than stock with either cam you mentioned.
Don't forget the HD rocker shafts and single HD valve springs. _________________ 1965 Beetle sedan
Click to view image |
DarthWeber Samba Member
Joined: November 24, 2007 Posts: 7543 Location: Whittier,CA
Posted: Sun Jul 03, 2011 12:50 pm Post subject: Re: CB cheater cam or engle 100 in a stock 1600 |
After dropping the original cam and breaking it in two his son doesn't rate either of those cams.
jk  _________________
Mitey62 wrote: |
Swapped the Compufire for a Bosch blue and some points I had sitting around, started 1st crank. Took her out for a drive, pulls harder, more RPM, and runs smoother. I think I'll be sticking with points from now on. |
RockCrusher wrote: |
JB weld the case halves....that'll keep the fretting to a minimum.  |
bsairhead Samba Member
Joined: October 08, 2008 Posts: 4519 Location: viroqua wi.
Posted: Sun Jul 03, 2011 2:10 pm Post subject: |
So the son drops the cam and it breaks. Sounds like he did your engine a favor. |
Derek Cobb Annoying
Posted: Sun Jul 03, 2011 2:24 pm Post subject: |
"Dad, I dropped the Carburetor and broke it. Can we get those dual Webers now?"  |
Posted: Sun Jul 03, 2011 3:49 pm Post subject: |
ok . 110 it is.
can i stick with the stock compression? or do i need to bump it up?
with this cam in a stocker like this, what sort of RPM range i should be looking at? 5K? |
Posted: Sun Jul 03, 2011 3:51 pm Post subject: |
tighten the deck height to .040" and run it. _________________ It's just advice, do whatever you want with it!
Posted: Sun Jul 03, 2011 3:56 pm Post subject: |
This assumes there is no step in the head. If so remove the step as well. Total deck = distance from top of piston to flat area in combustion chamber. Alot of people just measure distance from top of piston to top of cylinder at TDC. _________________ 1965 Beetle sedan
spencerfvee Samba Member
Posted: Sun Jul 03, 2011 4:02 pm Post subject: Re: CB cheater cam or engle 100 in a stock 1600 |
guys he said all stock motor .come on a engle 110 cam for a stock motor that hes going to put around town in not ever one wants a race motor lol .my self i am running a cb cheater cam .love it it pulls great to 4,000 rpm if you want it to . pulls hills like there not there very street friendly cam . i have driven bugs with engle 100 cams . i like the cb cheater cam better .for a all stock motor .just my two cents spencerfvee......................
clooney wrote: |
Posted: Sun Jul 03, 2011 5:26 pm Post subject: |
clooney wrote: |
borninabus wrote: |
yes. stock 34PICT3 and 8.0 compression in a bus.
it pulled strong but I shoulda used a counterweighted crank.
it beat itself to death in about 60,000 miles. _________________ 88 Van WBX, A/T - 93 Multivan 5cyl 5M/T - 13 JSW TDI 6M/T - 2012 Touareg TDI Sport |
Posted: Sun Jul 03, 2011 5:44 pm Post subject: Re: CB cheater cam or engle 100 in a stock 1600 |
Spencer,
what part of "Dual 36 DRLAs with lightly ported heads" is "stock"? _________________ It's just advice, do whatever you want with it!
66brm Samba Member
Joined: January 25, 2010 Posts: 3676 Location: Perth Western Australia
Posted: Sun Jul 03, 2011 8:21 pm Post subject: |
Hell yeah w110 all day long, it'll love ya for it _________________ Aust. RHD 66 Type 1
Aust. RHD 57 Type 1 Oval
modok wrote: |
I am an expert at fitting things in holes, been doing it a long time |
Buellistic Samba Member
Joined: February 04, 2011 Posts: 357 Location: Albuquerque, New Mexico
Posted: Sun Jul 03, 2011 9:46 pm Post subject: |
This CB Cheater Cam. Is it the Eagle 2235? If so... damn!
I picked the 2235 in an attempt to not over-cam my 1776 build. Collector exhaust, Weber Progressive carb, 35.5/32 heads with cleaned up ports. |
modok Samba Member
Joined: October 30, 2009 Posts: 27719 Location: Colorado Springs
Posted: Sun Jul 03, 2011 9:48 pm Post subject: |
The cb cheater is the #2280
It is for a idle-4000 rpm range
If an engine has a better intake and you don't need torque down to idle, then might as well use a more radical cam. I believe the progressive is a rather large carb, so you might as well use a too big cam, that way it matches! |
Posted: Sun Jul 03, 2011 9:56 pm Post subject: |
Ah, okay cool. *wipes sweat off brow* :p |
modok Samba Member
Posted: Sun Jul 03, 2011 9:59 pm Post subject: |
Yeah, it should be awright
I have not tried that particular CB grind, but the numbers look pretty good. |
Posted: Thu Jul 07, 2011 12:55 am Post subject: |
ok thanks for all the advice. i am getting the 163.
what about pushrods? the stock aluminium is good enough or i need steel or chromoly?
if chromoly, which is good?
http://www.vwparts.net/BP4084.html |
