rubbachicken Samba Member
Posted: Thu Sep 15, 2011 4:00 pm Post subject: replacement westie propane tank, where from |
i'm now about to {i hope} to buy a vanagon westie, the propane cylinder has rusted out, i've looked through the classifieds and cannot see one forsale
where might i be able to find one
thanks |
PDXWesty Samba Member
Joined: April 11, 2006 Posts: 6344 Location: Portland OR
Posted: Thu Sep 15, 2011 4:05 pm Post subject: |
thanks, i've not heard of either vendor before
Posted: Thu Sep 15, 2011 4:15 pm Post subject: |
People have restored them with good success, but I can't find the posts right now. The power of the search is not strong with me today... _________________ 89 Westy 2.1 Auto |
DAIZEE Samba Member
Joined: January 26, 2010 Posts: 7552 Location: Greater Toronto Area Ontario West Side
Posted: Fri Sep 16, 2011 5:05 am Post subject: |
Frank Condelli (?spelling) is importing bigger ones. He's in the Ottawa, Ontario area. _________________ '09 2.5L Jetta 5 cylinder, 5 spd, super turbo, see thread in H2O Cooled Jetta, etc...
84 Vanagon GL Wolfsburg Westy WBX 4 speed (sold) |
SCM Samba Member
Joined: January 26, 2011 Posts: 3476 Location: Bozeman MT
Posted: Fri Sep 16, 2011 8:11 am Post subject: |
| rubbachicken wrote: |
| thanks, i've not heard of either vendor before |
You'll have them on speed dial once you get your Westy home.
FWIW, I replaced my propane tank with a unit from GoWesty. The install went pretty smoothly although I had a bit of a struggle re-flaring one of the propane lines. It had previously been spliced and that caused a clearance issue with the flaring tool. All told it took a couple hours to get it hooked up.
However, for some reason I can no longer go to my local U-haul propane dispensary. The nozzle they use (which works on my Weber grill and the old propane tank) doesn't fit the new tank. _________________ '91 Westfalia GL Automatic (GTA "Turbo" Rebuild w/Peloquin) and 2.3L GoWesty Engine |
Ahwahnee Samba Member
Joined: June 05, 2010 Posts: 10295 Location: Mt Lemmon, AZ
Posted: Fri Sep 16, 2011 10:22 am Post subject: |
| SCM wrote: |
| You'll have them on speed dial once you get your Westy home. |
Yes, they will figure prominently in your monthly VISA statement.
| Quote: |
| FWIW, I replaced my propane tank with a unit from GoWesty. |
Me too. There are some who restore these which may save some bucks but I saw the chance for a new tank as a life-of-the-van purchase.
| Quote: |
| ...However, for some reason I can no longer go to my local U-haul propane dispensary. The nozzle they use (which works on my Weber grill and the old propane tank) doesn't fit the new tank. |
That is odd. The fitting on my GoWesty tank is the same as the original fitting. I have had attendants search for the correct adaptor among their collection of brass and declare they didn't have one -- until I point out that they needed no adaptor at all, the hose with no adaptor fitted is correct for the tank.
I get at least 14 days of camping on a full tank with the refrigerator running exclusively on propane. A bigger tank will get you more but you will probably sacrifice some ground clearance to have it. |
SCM Samba Member
Posted: Fri Sep 16, 2011 11:43 am Post subject: |
| Ahwahnee wrote: |
| That is odd. The fitting on my GoWesty tank is the same as the original fitting. |
Hmm, maybe the attendant didn't know what he was doing that day. I'll have to give it another try when the time comes to refill.
Good to know about how long your tank lasts. I suspect we'll be surprised with no stove action one of these days although we've just about given up on the 'fridge. Between food and beer we end up bringing a cooler anyway and it just got to be easier to use the fridge for non-perishables. _________________ '91 Westfalia GL Automatic (GTA "Turbo" Rebuild w/Peloquin) and 2.3L GoWesty Engine |
r39o Samba Polizei
Posted: Sun Sep 18, 2011 3:00 pm Post subject: |
| PDXWesty wrote: |
| People have restored them with good success, but I can't find the posts right now. The power of the search is not strong with me today... |
See the FAQ!
I have done it a couple of times. It is and is not worth it.
The OP states his tank is rusted out. There fore it is done.
Time to find another.
Just type "propane" in to the classifieds search.
The tanks do come for time to time.
It costs me $75 to have one cleaned and powder coated with lots of zinc under it. It is better protected than the factory thin coat of paint.
So add up the costs and it may be just less issue to buy a new one for around $350.
For me, I now have a couple to work with for my install into my Multivan. Makes sense for me to have fun, but if the core tank from the OP is really that bad, he should consider another one. _________________ "Use the SEARCH, Luke" But first visit the Vanagon FAQ!
r39o Samba Polizei
Posted: Sun Sep 18, 2011 3:05 pm Post subject: |
| SCM wrote: |
{snip]
It has something to do with the ACME / something else I forget combination fitting.
You can buy a new fill cheap. Look in the FAQ under propane and look where I have bought them from. _________________ "Use the SEARCH, Luke" But first visit the Vanagon FAQ!
r39o Samba Polizei
Posted: Sun Sep 18, 2011 3:07 pm Post subject: |
| Ahwahnee wrote: |
See:
http://www.thesamba.com/vw/forum/viewtopic.php?t=479091 _________________ "Use the SEARCH, Luke" But first visit the Vanagon FAQ!
crazyvwvanman Samba Member
Joined: January 28, 2008 Posts: 10462 Location: Orbiting San Diego
Posted: Sun Sep 18, 2011 3:53 pm Post subject: |
There are 2 common types of fitting on various age Westy tanks as well as other tanks. My local propane vendor has the other adapter stored right at the pump and simply looks at the tank to make sure the pump hose has the right end for a given tank. I have Westy tanks of both fitting type, mixed on the same van even. It causes no big issues, even when he has to switch hose ends when he moves from one side of that van to the other. Find a smarter filling station.
Mark
| SCM wrote: |
FWIW, I replaced my propane tank with a unit from GoWesty. .....
