Weight? What does yours weigh?
BillWYellowstone
BillWYellowstone is offline
PostPosted: Tue Sep 20, 2011 8:17 pm    Post subject: Weight? What does yours weigh? Reply with quote
According to my title, my westy is 3522 lbs. I really wonder what it weighs, obviously a stop by a CAT scale will solve my question, but figure someone might already know what the rig would weigh.
Was the 3522 before conversion? Before loading up with all our stuff? My expectation was after conversion, with fluids.
Live Fulltime in motorhome
Have 86 Westy Camper 2.1 rebuilt
Work in Yellowstone NP year round.
GWTWTLW
GWTWTLW is offline
PostPosted: Tue Sep 20, 2011 8:39 pm    Post subject: Reply with quote
Mine is about 5200 with me and the gear that lives in there full time.
89 Syncro Westy - GW 2.5, now with a double knob job
@gwtwtlw
reluctantartist
reluctantartist is offline
PostPosted: Tue Sep 20, 2011 10:47 pm    Post subject: Reply with quote
Here is an interesting link that gives actual curb weights:
http://www.roadhaus.com/tires/load.html
1982 Westy, 1974 412 Variant... Yes, Aircooled's are great! Oh and I do have modern computer controlled vehicles too, but I just don't care about them.
Jake de Villiers
Jake de Villiers is offline
PostPosted: Tue Sep 20, 2011 11:00 pm    Post subject: Reply with quote
My tintop GL 7 passenger van weighs 3480 lbs, my Poptop Westy Weekender weighs 3900 lbs, and my mom's full Westy with AT weighed in at 4450 lbs.
With Dixie loaded up for a bluegrass festival weekend we usually weigh about 4500 lbs with the two of us aboard and the guitars, the double bass, the food and water, the beverage cooler and the rest of the stuff! Wink
'84 Vanagon GL 1.9 WBX
@jakedevilliersmusic1
www.crescentbeachguitar.com
www.thebassspa.com
rcook52459
rcook52459 is offline
PostPosted: Wed Sep 21, 2011 4:37 am    Post subject: Reply with quote
went though truck scales after camping trip scales said 4450lbs. 85 westy auto trans and tiico
85 westy tiico conversion.auto trans triumph TR250 1980 Suzuki GS1000l
Alaric.H
Alaric.H is offline
PostPosted: Wed Sep 21, 2011 4:48 am    Post subject: Reply with quote
I am coming in at 6000lbs at the scales it makes it kinda hard to push.
Jon_slider
Jon_slider is offline
PostPosted: Wed Sep 21, 2011 7:28 am    Post subject: Reply with quote
86 syncro westy with subaru 2.2, with me and my surf gear, 4750 lbs
87 syncro sesty with 2.5 AEL TDi, 2300 front axle 2700 rear axle = 5000 lbs, again with me in it and my surf gear.
if you go to the trouble to use a truck scale, I would be interested in your front and rear axle weights
Jake de Villiers
PostPosted: Wed Sep 21, 2011 8:22 am    Post subject: Reply with quote
Its no trouble to use a truck scale, they are right on the highway. I just drop in when the sign says 'Closed'.
Westy Weekender, 2.1 WBX and 4 speed with me up front and a bunch of tools etc:
Front - 2134 lbs
Rear - 2036 lbs
Westy Weekender, 2.1 WBX and 4 speed with the two of us on our way to a weekend festival with instruments, food and camping gear:
Front - 2400 lbs
Rear - 2060 lbs
I'll be interested to see what difference there is with the 2.5 Subaru engine and 5 speed but we haven't passed a closed scale yet! Wink
www.thebassspa.com
molson88
molson88 is offline
PostPosted: Wed Sep 21, 2011 11:49 am    Post subject: Reply with quote
Our '88 Westy with Subaru EJ22, fully loaded for camping, weighs in at 2100 kg (4630 lbs) with two people on board.
We can fit all four wheels at once on the local truck scales...
Cliff
99 Eurovan Camper (current)
88 Vanagon GL Camper with Subaru EJ22 (gone)
83 Vanagon Camper (best forgotten...)
2012 Audi Q5 3.2L
ShootingFish
ShootingFish is offline
PostPosted: Wed Sep 21, 2011 1:37 pm    Post subject: Reply with quote
Full fuel, full camping gear, full h2o and two adults and we come in at 4700#
SF
SF
Props aren't just for boats....
'88 2WD ALH-TDI Westy Red Vanagon
'90 Syncro 16 Doka Yellow Vanagon
Jon_slider
PostPosted: Wed Sep 21, 2011 10:16 pm    Post subject: Reply with quote
> Front - 2400 lbs
> Rear - 2060 lbs
Thats unusual, a 54% front, 46 %rear split
I have the same split, reversed, 46%front 54% rear,
If I put 10 psi more on the heavy rear axle tires they come up to the same height, axle to ground on a tape measure, as the front axle tires..
Jake de Villiers
PostPosted: Wed Sep 21, 2011 11:04 pm    Post subject: Reply with quote
Jon_slider wrote:
> Front - 2400 lbs
> Rear - 2060 lbs
Not unusual at all, its how they were built. You'll notice that if you take the two adults out of the front seats (200 + 140) the weight distribution is 50/50.
All the two wheel drive vans I've put over the scales show the same forward weight bias: its why they *SUCK* in the snow or on any slippery surface. My passenger van is even more biased without the closet and upper rear storage.
Your Syncros have the gas tank over the rear wheels, not to mention a heavier transaxle. I'm betting that the 2.2 is a lot less rear heavy than the TDI - there's a 250 lb weight difference there.
www.thebassspa.com
Last edited by Jake de Villiers on Wed Sep 21, 2011 11:09 pm; edited 1 time in total
1621
1621 is offline
PostPosted: Wed Sep 21, 2011 11:05 pm    Post subject: Reply with quote
At last check, my 85 Westy sat at an even 5000lbs. This is with a 1.8T conversion, big wheels and tires, full tank, a full load of stuff, and a crap load of add-ons and do-dads. I ain't no featherweight either.
'85 Westy
Jon_slider
PostPosted: Thu Sep 22, 2011 7:21 am    Post subject: Reply with quote
http://www.roadhaus.com/tires/guideline.html
2WD Vanagon or Camper
GVWR 5160 lbs
GAWR Front 2646 lbs = 48% front
GAWR Rear 2866 lbs = 52% rear
4WD Syncro Vanagon or Camper
GVWR 5512 lbs
GAWR Front 2866 lbs = 49% front
GAWR Rear 3042 lbs = 51% rear
Jake de Villiers
PostPosted: Thu Sep 22, 2011 8:20 am    Post subject: Reply with quote
GVWR 5160 lbs
GVWR 5512 lbs
That;s maximum load Jon, not unladen weight, and has no relevance to the subject at hand.
www.thebassspa.com
PDXWesty
PDXWesty is offline
PostPosted: Thu Sep 22, 2011 8:24 am    Post subject: Reply with quote
Here's another couple of posts on the subject:
http://www.thesamba.com/vw/forum/viewtopic.php?t=362549
http://www.thesamba.com/vw/forum/viewtopic.php?t=240065
I've weighed in at anywhere between 5000-6200 lbs when packed for a trip with gear and passengers.
89 Westy 2.1 Auto
Jon_slider
PostPosted: Thu Sep 22, 2011 8:34 am    Post subject: Reply with quote
Rolling Eyes
You can lead a horse to water, but you cant make him Think!
thummmper
thummmper is offline
PostPosted: Thu Sep 22, 2011 9:17 am    Post subject: Reply with quote
3460# round town--add 400# for me and my gear for the sequoias.
2.2 suby gl 1990
a ford excursion nears 10k. my cousins 4 door smokarado is 9k empty.
travelling light is the new awareness.
Jake de Villiers
PostPosted: Thu Sep 22, 2011 12:45 pm    Post subject: Reply with quote
Rolling Eyes
Umm, that's what I was trying to say! An empty 3/4 ton pickup truck with driver has the majority of its weight on the front wheels, whereas fully loaded it is the rear which is carrying most of the weight. This has no relevance to the weight distribution of my Vanagons as posted.
www.thebassspa.com
IdahoDoug
IdahoDoug is offline
PostPosted: Tue Dec 02, 2014 10:56 pm    Post subject: Reply with quote
Rolled over a scale today. 2WD Wolfsburg automatic with about 50lbs of stuff in it and my 180lb carcass weighed 3620. So, 3390 curb weight. That was low on fuel, too. For reference, I pulled the A/C out of mine a while ago - all overhead ducts and the compressor.
