Classicvibe Samba Member
Joined: August 03, 2009 Posts: 743 Location: Salt Lake City
dubbified Samba Member
Joined: March 03, 2010 Posts: 1508 Location: Redmond, WA
Posted: Tue Oct 11, 2011 10:28 am Post subject: |
That first link looks real good.
Watching this post to see what you use!
Hope you take pics of your progress, install.  |
r39o Samba Polizei
The factory had seat heaters too.
I noticed that all the parts for the VW system are sort of the same.
I noticed that most of the aftermarket stuff you showed looks a lot like the VW stuff.
Coincidence?
I located most of my heated seat stuff out of other VWs.
Just not the pads, yet. I have Recaro seats I want to put in and I can buy VW heated inserts from VW, but at a prcie. Factory pads for the factory seats may or may not still be available.
NOTE: Vanagons in Canada could have a heated driver seat. The control is hard and expensive to find. Plus it was for one seat only. You can make a later controller work just fine.
FYI: The heated VW heated seat parts are hard to find, but do integrate nicely, into the van.
EDIT: This is a LOW priority thing for me since we live in San Diego; who needs that, right? But, it is a nice thing to have, you just have to work at it for the once a year or so we actually might want it. _________________ "Use the SEARCH, Luke" But first visit the Vanagon FAQ!
danfromsyr Samba Member
Joined: March 01, 2004 Posts: 15410 Location: Syracuse, NY
Posted: Tue Oct 11, 2011 10:36 am Post subject: |
don't forget you can (should) install seat heaters in the back bench too.
not just for passanger comfort or while chilling in the mobile chalet..
but to preheat the beadding too  _________________
| Abscate wrote: |
| These are the reasons we have words like “wanker” |
PDXWesty Samba Member
Joined: April 11, 2006 Posts: 6344 Location: Portland OR
big swifty Samba Member
Joined: August 21, 2007 Posts: 255 Location: Formally in Republic of VT; now in Hollywood, FL
Posted: Tue Oct 11, 2011 4:39 pm Post subject: |
I have the Check brand in my Jetta and in The van. Thumbs up! _________________ Evan
1987 Vanagon Syncro // Westfalia pop-top graft // Factory new ALH. 11mm IP. AFN 110 RC 2,3,4 // S7 turbo// Titan P502's
2013 Golf 4d TDI. Deleted. Tunezilla Stage2.
1991 Jetta coupe TD. Giles Superpump. SOLD |
2doorsdown Samba Member
Posted: Tue Oct 11, 2011 6:15 pm Post subject: |
I don't see VW listed on the Check site. Do you remember what the kit ran you and did you get the DIY? Thanks again. Pre Heating the bed sounds like I'll make it on the wifes good side with this mod  |
Syncroincity Samba Member
Joined: April 15, 2007 Posts: 1557 Location: New York City
Posted: Wed Oct 12, 2011 5:47 pm Post subject: |
I installed the heatedseatkits set in my Subaru under leather, worked great, install is a breeze, they provide very nice wiring harnesses, all modular with plugs, all you do is provide +12v and a ground, and find a place to mount the switches.
Take the opportunity to machine wash or dry-clean your upholstery while it's off.  _________________ '86 Syncro CHC Top AAZ Turbodiesel
'04 Passat Variant 4Mo 5MT
Vanagon Build: http://www.thesamba.com/vw/forum/viewtopic.php?t=466866&highlight= |
insyncro Banned
Posted: Wed Oct 12, 2011 5:53 pm Post subject: |
I have installed carbon fiber heating elements to my stock Vanagon seats.
I wired them to the relay and control unit found in Canadian Syncros and Tristars.
Worked like a charm.
Really makes winter driving comfortable. |
Posted: Wed Oct 12, 2011 6:07 pm Post subject: |
Lux-51 DIY _________________ Evan
a914622 Samba Member
Joined: July 29, 2004 Posts: 951 Location: Westend of HWY2 , Wash
Posted: Wed Oct 12, 2011 8:00 pm Post subject: |
I just scored the stock top plastic part that holds the seat/heater switch. (only a buck fifty) you got to love the wrecking yard!!
Post pics on the way you go! I have a set of eurovan seats waiting to go in after a good wash and heaters.
jcl _________________ 87 gl powerd buy 2.5subaru
75 914 getting 2.2t subaru scratch that SVX subaru |
r39o Samba Polizei
Posted: Wed Oct 12, 2011 10:06 pm Post subject: |
| insyncro wrote: |
So those heating elements have a thermistor that works with the "relays?"
Which brand and model of element did you use? _________________ "Use the SEARCH, Luke" But first visit the Vanagon FAQ!
r39o Samba Polizei
Posted: Sun Oct 16, 2011 12:24 pm Post subject: |
I "discovered" our new Jetta V has heated seats. I never looked close before. The other day I drove it and it got cool in the evening. While playing with the controls (worse than a Vanagon!) I found the push button control in the middle of the hot / cold (left) and the vent control (right.) I noticed I only need two positions. Warm and Hot (and Off.)
I mention this as I may not really need to integrate the variable factory system which uses a thermistor to keep temperature at what you set via the (EXPENSIVE) controller.
In other words an after market setup may well be all I really need. (I won't use it a whole lot here in So Cal anyways.)
Any input? _________________ "Use the SEARCH, Luke" But first visit the Vanagon FAQ!
insyncro Banned
Posted: Sun Oct 16, 2011 1:38 pm Post subject: |
| r39o wrote: |
| insyncro wrote: |
Which brand and model of element did you use? |
Yes and well above most budgets around here.
They are available on eBay.de |
r39o Samba Polizei
Posted: Sun Oct 16, 2011 2:49 pm Post subject: |
| insyncro wrote: |
| r39o wrote: |
| insyncro wrote: |
The VW factory elements for my Recaros are about $90 each which is not too bad, I think compared to what the aftermarket ones cost. I can get the factory ones wholesale in the US last time I checked.
But, the control and "relays" are quite expensive to purchase new, but thankfully you can get them out of other model VWs used. Not like they are falling off trees, but you can get them.
Knowing myself I just put them on high or low. The variable feature of the stock VW is sort of lost on me.
BUT, I do have everything to do the job now and forgot to order the pads until this thread came up. _________________ "Use the SEARCH, Luke" But first visit the Vanagon FAQ!
creative native Samba Member
Posted: Sat Dec 03, 2011 2:11 pm Post subject: |
| At this point, I believe I have all components to install the heated seat/seats in my 1986 Westfalia. I have the VW rheostat, raised upper column cover in brown, #59 heated seat relay. I believe all I need now are the heated pad elements and the wiring harness. Does anybody know where I can find these or the VW part numbers? I've been told that the heated seat wiring harness from an early 90's Jetta MK is the same...can anybody here verify that? If I should find the wiring harness, but not the heated pads, does anybody here know if aftermarket heated pads will work? I will appreciate any information and help! |
Jaraqui Samba Member
Joined: March 20, 2007 Posts: 4 Location: Oakland, CA
Posted: Sat Dec 22, 2012 5:27 pm Post subject: r39o |
Digging through the archives, I saw this conversation you had with 'insyncro' about seat heaters.
I'm about to re-assemble my driver's seat after a rebuild and cleaning, and have a complete OEM heated seat setup (rheostat, column shroud, harness, '59' controller. I bought aftermarket heating elements.
According to Bentley, there's a temp sensor in the OEM seat element that plugs into the 6-pin under seat connector. The aftermarket elements I have only have power and ground leads.
Did you figure out whether you needed thermistor-controlled heating elements to use the VW harness? I couldn't determine whether the temp sensor is needed from Insyncro's comments.
Thanks for any guidance, and Happy Holidays.
David K
| r39o wrote: |
| insyncro wrote: |
| r39o wrote: |
| insyncro wrote: |
BUT, I do have everything to do the job now and forgot to order the pads until this thread came up. |
_________________ --------------------
Moglet
'90 Westy Syncro, EJ-22, other bell's & whistles
268K miles
Faithful companion since 1996
Next stop, Ushuaia? |
plummerdesign Samba Member
Posted: Sun Dec 30, 2012 10:15 pm Post subject: |
Seat heaters are on my list. On the Westy, both seats rotate. So what is the best way to keep from damaging the wiring leads when turning the seats?
Cheers,
Jeffery
(Westfalia travel/camping videos at YouTube link below) _________________ It is old and green and it makes me grin.
1984 Westfalia 1.9 |
r39o Samba Polizei
Posted: Mon Dec 31, 2012 11:26 am Post subject: |
| plummerdesign wrote: |
Cheers,
Jeffery
(Westfalia travel/camping videos at YouTube link below) |
I have swivels, heaters and Recaro seats waiting to be installed.
I am thinking of putting a hole in the middle of the swivels to allow the cable to go through, if it is possible.
Otherwise you need a long enough service loop and the cable tied away so it does not get caught. In this case, I do not know what a good routing is.
This is a topic I sort of forgot about.... _________________ "Use the SEARCH, Luke" But first visit the Vanagon FAQ!
Posted: Mon Dec 31, 2012 11:28 am Post subject: |
I am doing this soon, and was going to drill a hole in the center of the swivel with a grommet on each piece of metal it goes through. Not sure how many pieces we have to go through yet or if the middle is an option at all. _________________ It's just advice, do whatever you want with it!
"Like" our Facebook page at
and get a 5% off code for use on one order for VW Parts ON OUR PARTS STORE WEBSITE, vwparts.aircooled.net |
