Help me fix the dellorto dribble!
dalland
dalland is offline
PostPosted: Fri Oct 28, 2011 11:33 pm    Post subject: Help me fix the dellorto dribble! Reply with quote
Hello, I finally started my new engine yesterday and noticed that one of the barrels is filling with fuel when shut, I can see it comes from the transit ports.
The carbs is 45 drla.
It had been nice to live in usa and just send them to ACE, but since I live in Norway and have used up my money on the engine I hope someone could instruct me how to fix it.
So if anyone sit on some good information please share to our nice community. Rolling Eyes
modok
modok is offline
PostPosted: Fri Oct 28, 2011 11:40 pm    Post subject: Reply with quote
Here is the x-ray view
https://www.thesamba.com/vw/gallery/pix/721161.jpg
That plug circled in red in the middle has come loose, you must take out the plug on the outside, and hopefully the offending plug will just fall out of there.
Then you can either make a new one, or try to glue it in place again again
dalland
dalland is offline
PostPosted: Fri Oct 28, 2011 11:46 pm    Post subject: Reply with quote
thanks!
Do you have a picture of the outside, which port I have to drill into?
Just so I am shure. Wink
dalland
dalland is offline
PostPosted: Fri Oct 28, 2011 11:49 pm    Post subject: Reply with quote
One on this image?
modok
modok is offline
PostPosted: Fri Oct 28, 2011 11:52 pm    Post subject: Reply with quote
yes, the one above the transfer port cover
dalland
dalland is offline
PostPosted: Fri Oct 28, 2011 11:59 pm    Post subject: Reply with quote
Hehe, that dosn't seem that hard. Rolling Eyes
Do you know if anyone sells that plug that I have to drill?
I guess I can probably just push the little loose plug with a drill bit back into place..?
modok
modok is offline
PostPosted: Sat Oct 29, 2011 12:17 am    Post subject: Reply with quote
"Easy" is a bit strong, but with luck, it is "possible"
I immediately think of going through my boxes of thousands of various sized little metal thingies to find something just the right diameter and gluing it in with a dab of loktite, but that is just the habit of my creature
Make the best creative use of what you have
Bruce
Bruce is offline
PostPosted: Sat Oct 29, 2011 12:42 am    Post subject: Reply with quote
Has anyone heard of this happening to 40 DRLAs? Or is it only the 45s that suffer this problem?
modok
modok is offline
PostPosted: Sat Oct 29, 2011 12:44 am    Post subject: Reply with quote
they all do
the x-rated carb is a 40 DRLA
mharney
mharney is offline
PostPosted: Sat Oct 29, 2011 9:23 am    Post subject: Reply with quote
What's "hard" is making sure you don't screw up the passage, so you can make plugs that will fix it. I custom make the plugs from brass rod, grind them with a small taper, then fit them in.. the plugs must be made right or you will screw up the job by occluding the passage in the wrong place. I tap the outer access for a 5mm screw and use sealant on it in case it ever needs to be accessed again. The reason this tends to happen is water in the passage causing oxides to push the plug out.
mharney
mharney is offline
PostPosted: Sat Oct 29, 2011 9:25 am    Post subject: Reply with quote
modok wrote:
they all do
Porn Carb?
Bruce
Bruce is offline
PostPosted: Sat Oct 29, 2011 1:53 pm    Post subject: Reply with quote
Has anyone figured out a test to see if a carb is leaking at that plug, without having to install it on an engine and running it?
modok
modok is offline
PostPosted: Sat Oct 29, 2011 2:14 pm    Post subject: Reply with quote
yeah, easy
just fill the float bowl full of solvent and see if it leaks out
Bruce
Bruce is offline
PostPosted: Sat Oct 29, 2011 2:48 pm    Post subject: Reply with quote
Of course!
Referring to the porn:
If the plug is leaking, the fuel will travel from the float chamber down under the float chamber's floor, into the passage leading to the bottom of the main jet. Then it goes through the main jet and out the four holes at the bottom of the emulsion tube. From there it directed by the internal plug to go up through the idle jet, then down to the other side of that internal plug. It goes over then down to the transition ports, or it continues down to the idle mixture screw, and finally into the air stream.
So when this internal plug comes loose, fuel passes directly from the main jet/emulsion tube, then into the progression ports, bypassing the metering of the idle jet.
dalland
dalland is offline
PostPosted: Sat Oct 29, 2011 3:02 pm    Post subject: Reply with quote
Thanks everybody, but modok this was way to easy.
About 5 minutes in total and now it is just as "new"
Bruce
Bruce is offline
PostPosted: Sat Oct 29, 2011 3:12 pm    Post subject: Reply with quote
How exactly did you do it? Pics?
dalland
dalland is offline
PostPosted: Sat Oct 29, 2011 3:23 pm    Post subject: Reply with quote
Pulled the plug like this:
Here is the loose plug:
Just put it back in, tappet it some times and installed a normal screw.
Going to cut it down with a dremel tomorrow, (night time here now).
ljc767
ljc767 is offline
PostPosted: Fri Feb 02, 2018 3:47 pm    Post subject: Re: Help me fix the dellorto dribble! Reply with quote
I cant see the photos in your last 3 posts, can you please post them again?
slalombuggy
slalombuggy is offline
PostPosted: Fri Feb 02, 2018 6:17 pm    Post subject: Re: Help me fix the dellorto dribble! Reply with quote
This post thread is 6 1/2 years old and the guy who posted the picture hasn't been on for a few months.
brad
Wreck
Wreck is offline
PostPosted: Fri Feb 02, 2018 6:22 pm    Post subject: Re: Help me fix the dellorto dribble! Reply with quote
I just went through this , sorry no photos , I drilled the plugs and used a small self tapping screw to screw in then pull the plugs out , for the inner plug I used a straighten out picture hook.
Also from info posted before I used 4 and 5mm brass grub screws instead of lead plugs . you need to be careful that you don't screw the inner one in too far because it will cut off flow to the jet . I found out the hard way . I ended up placing a drill bit through where the idle jet seats and draws fuel to gauge how far to screw in inner screw if that makes any sense . I used blue thread locker . so far no problems .
