1971 VW Bus Turn Signals
Page: 1, 2, 3, 4  Next
vairken
vairken is offline
PostPosted: Thu Dec 15, 2011 3:28 pm    Post subject: 1971 VW Bus Turn Signals Reply with quote
Hi All,
My 1971 Transporter turn signals are not working. The light on the dash comes on green when either side is turned on but none of the lights work and it does not flash. Since NONE of them ( L,R, Front or Rear ) are working I am not inclined to think its a bulb situation. But what do I know ? I am a newbie. Where should I start ? Help before I get sideswiped. LOL. Oh yrah and they were working so this is new.
Ken
Portland
Amskeptic
Amskeptic is offline
PostPosted: Thu Dec 15, 2011 3:31 pm    Post subject: Re: 1971 VW Bus Turn Signals Reply with quote
vairken wrote:
Hi All,
Ken
Portland
Do your hazard flashers work?
Colin
www.itinerant-air-cooled.com
www.facebook.com/groups/324780910972038/
vairken
vairken is offline
PostPosted: Thu Dec 15, 2011 3:41 pm    Post subject: Reply with quote
Thanks Colin. Just checked and no they do not work . Pull out the knob and nothing
Amskeptic
PostPosted: Thu Dec 15, 2011 3:46 pm    Post subject: Reply with quote
Then let's go straight to the flasher relay. That should give you both turn indicators and hazards.
Homework: Find flasher relay location.
Colin
vairken
vairken is offline
PostPosted: Thu Dec 15, 2011 4:00 pm    Post subject: Reply with quote
Will do. Is a flasher relay something I can get at auto parts store or will I have to get it online from a dub supplier. And again thanks for your wisdom. Im learning.
Amskeptic
PostPosted: Thu Dec 15, 2011 4:26 pm    Post subject: Reply with quote
Universal flasher relays are available, but check online VW catalogues for part #s that may help you cross-reference. Bosch is the original brand.
It should be a three prong relay. But you need to see:
A) if you have one
B) if it is water-damaged
bigbore
bigbore is offline
PostPosted: Fri Dec 16, 2011 12:14 am    Post subject: Reply with quote
your just going to love it when you find out where it is. Wink I suggest unhooking the battery to be safe.
where its cold and snowy
grandpa pete
grandpa pete is offline
PostPosted: Fri Dec 16, 2011 9:14 am    Post subject: Reply with quote
Is it in the same place as a 69??? Confused i know where that is Laughing
63 two fold rag
66 sedan delivery Type 6
http://www.thesamba.com/vw/forum/viewtopic.php?t=569619&highlight=sedan+delivery
75bus4/me
75bus4/me is offline
PostPosted: Fri Dec 16, 2011 10:28 am    Post subject: Reply with quote
I found mine only after I took it out not knowing what it was cleaned all the connection and checking wires put it back in trying to get my brake lights and turn signal to work. Now I know what it is because it makes a clicking sound with the signals. Wink
1975 Bay Window {Big Red}
bigbore
bigbore is offline
PostPosted: Fri Dec 16, 2011 12:51 pm    Post subject: Reply with quote
No pete yours is in a way easy place to get to compared to the 71. I will give you a hint it sucks as bad ---no worse as getting to the fuse's
vairken
vairken is offline
PostPosted: Fri Dec 16, 2011 2:19 pm    Post subject: Reply with quote
It looks like it might be under the dash just behind the flasher knob. Have to remove my parcel tray to see closer. Am I in the right place? Feels like a little box behind the flasher knob. Hmmm.
vairken
vairken is offline
PostPosted: Fri Dec 16, 2011 2:26 pm    Post subject: Reply with quote
busdaddy
busdaddy is offline
PostPosted: Fri Dec 16, 2011 2:33 pm    Post subject: Reply with quote
You're cold, you need to move forward and to the left more Razz
Слава Україні!
justcruzin
justcruzin is offline
PostPosted: Fri Dec 16, 2011 2:49 pm    Post subject: Reply with quote
Well if it's anything like a 70 bus, I know the pain of getting to it. Mine is now zip tied to the front of where it actually belongs. I will put it back in it's spot eventually, but I want to clean all the connections first. Just been to lazy to tackle that project. Even though it is out in the open now, it is still hard to deal with it. Will make a nice rainy weekend project. Very Happy
Good luck with yours, just remember to disconnect the battery!
Kim
Sacramento, CA
1964 Split Window Bus
1966 Beetle Build Thread= http://www.thesamba.com/vw/forum/viewtopic.php?t=472933
1969 Delivery Van= http://www.thesamba.com/vw/forum/viewtopic.php?t=566282
1970 Westy Build Thread= http://www.thesamba.com/vw/forum/viewtopic.php?t=479538
1971 Squareback Build Thread = http://www.thesamba.com/vw/forum/viewtopic.php?p=6652459#6652459
1970 Single Cab, Samson = http://www.thesamba.com/vw/forum/viewtopic.php?p=8022609#8022609
vairken
vairken is offline
PostPosted: Fri Dec 16, 2011 3:38 pm    Post subject: Reply with quote
Thanks. I will definitely unhook the battery. If not I may be the idiot that fries the wiring trying to locate and change the flasher. Oh man please tell me its not on top the black plate covering the underside of the steering column. Ill find it eventually lol. Thanks for the hints guys.
Newbie who loves his Bus Gus
Amskeptic
PostPosted: Fri Dec 16, 2011 3:40 pm    Post subject: Reply with quote
As a crime against originality, I might get a 1973 bus fuse/relay box and use it on my 1970. I'll keep the wiring colors all OEM.
Colin Question
busdaddy
busdaddy is offline
PostPosted: Fri Dec 16, 2011 3:52 pm    Post subject: Reply with quote
Still cold Wink
Hint: If your headlights will change beam listen for where the click comes from when they do, both relays are neighbors.
Colin
That's crossed my mind too on more than one occasion, can't have too many fuses, but how would you mount it? In the stock location or where the 73 mounts?
Слава Україні!
bigbore
bigbore is offline
PostPosted: Fri Dec 16, 2011 3:57 pm    Post subject: Reply with quote
ok I will let the cat out of the bag I just happen to be working in the same spot on a 72 today. you have to lift the fuse panel CAREFULLY up and out this is why I say unhook the battery just incase you touch steel hell I do and I have been doing it for years you will see it hanging like a bat its the one in the middle.
busdaddy
busdaddy is offline
PostPosted: Fri Dec 16, 2011 5:21 pm    Post subject: Reply with quote
Way to go BB Rolling Eyes , we could have played this for quite a while more and Variken would have learned all sorts of things about his bus in the process, no one even got a chance to bring up the unmentionable B word yet Razz
Слава Україні!
justcruzin
PostPosted: Fri Dec 16, 2011 5:32 pm    Post subject: Reply with quote
Yep, that's the same location mine is at, currently! LOL
I found it was easier to get it out from behind the air duct thing by taking the metal cover off and then removing the plastic air ducting. Gives you a tad more room for wires to move around.
You can see mine in the background. I have it zip tied to the air duct with cardboard between the duct and the fusebox.
Kim
Sacramento, CA
Page 1 of 4
